Hi guys
I am working on a project need to pass the ADS1231 read data through BLE. But I haven't done so far. I just try to read the ADS1231 value first. Referring to some source online, I have my data read functions as below, and they work fine without BLE environment.
/* *** jousis's gitlab open source code for reference *** <Scale FeatherWing> *** https://gitlab.com/jousis/scale-featherwing/-/tree/master/Firmware/nRF52832/ScaleTest */ #include <stdint.h> #include "ADS1231.h" #define SCL_PIN 15 #define DOUT_PIN 16 #define SPEED_PIN 29 #define PWDN_PIN 7 void ADS1231_init(void){ // set scl_pin output nrf_gpio_cfg_output(SCL_PIN); // set dout_pin input nrf_gpio_cfg_input(DOUT_PIN, NRF_GPIO_PIN_PULLUP); // set pwdn_pin nrf_gpio_cfg_output(PWDN_PIN); // reset ADS1231 ADS1231_powerOn(); setSpeed(0); // should controled by } void ADS1231_powerOn(void){ nrf_gpio_pin_clear(PWDN_PIN); // make pwdn_pin low, to reset the ADC nrf_delay_us ( 52 ); // Datasheet p15. At least 26us ( Security Factor: 2*26us = 52us ) nrf_gpio_pin_set(PWDN_PIN); nrf_gpio_pin_clear(SCL_PIN); // initial state // should be safeguarding } int32_t ADS1231_readADC(void){ int32_t adcvalue = 0, digit = 0; int i=0; for(i=0; i<24; i++){ // 24 pulses nrf_gpio_pin_set(SCL_PIN); nrf_delay_us(1); digit = nrf_gpio_pin_read(DOUT_PIN); adcvalue = (adcvalue << 1) + digit; nrf_gpio_pin_clear(SCL_PIN); nrf_delay_us(1); } nrf_gpio_pin_set(SCL_PIN); // keep dout high // 25th pulse nrf_delay_us(1); nrf_gpio_pin_clear(SCL_PIN); // yield() to confirm dout is high //adcvalue = (adcvalue << 8) / 256; return adcvalue; } void setSpeed(uint8_t sps){ if(sps>0){ nrf_gpio_pin_set(SPEED_PIN); } else{ nrf_gpio_pin_clear(SPEED_PIN); } } uint32_t * ADS1231_readADCbyte(void){ static int32_t value[24] = {0}; int i=0; for(i=0; i<24; i++){ // 24 pulses nrf_gpio_pin_set(SCL_PIN); nrf_delay_us(1); value[i] = nrf_gpio_pin_read(DOUT_PIN)+48; nrf_gpio_pin_clear(SCL_PIN); nrf_delay_us(1); } nrf_gpio_pin_set(SCL_PIN); // keep dout high // 25th pulse nrf_delay_us(1); nrf_gpio_pin_clear(SCL_PIN); // yield() to confirm dout is high //adcvalue = (adcvalue << 8) / 256; return value; }
main.c
int main(void) { uint32_t err_code; APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); //NRF_LOG_DEFAULT_BACKENDS_INIT(); bsp_board_init(BSP_INIT_LEDS); uart_init(); ADS1231_init(); int32_t adcValue; uint32_t* adcByte; printf("\r\nUART example started.\r\n"); while (1) { #ifdef adcByte adcByte = ADS1231_readADCbyte(); for(int i=0; i<24; i++){ while(app_uart_put(adcByte[i])); //printf("%d", adcByte[i]); } printf("\r\n"); //printf("ADC value: %x", adcValue); //NRF_LOG_FLUSH(); #else adcValue = ADS1231_readADC(); printf("ADC value: %d\r\n", adcValue-load_cell_offset); #endif nrf_delay_ms(100); } }
Then I try to use timer interrupt to call the ADS1231_readADC()
#include "nrf_drv_spi.h" #include "app_util_platform.h" #include "nrf_gpio.h" #include "nrf_delay.h" #include "boards.h" #include "app_error.h" #include <string.h> #include "nrf_log.h" #include "nrf_log_ctrl.h" #include "nrf_log_default_backends.h" // ADS #include "ADS1231.h" // UART #include "nrf.h" #include "bsp.h" #include "nrf_uart.h" #include "nrf_uarte.h" #include "app_uart.h" // ISR #include "app_timer.h" #define MAX_TEST_DATA_BYTES (15U) /**< max number of test bytes to be used for tx and rx. */ #define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */ #define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */ #define UART_HWFC APP_UART_FLOW_CONTROL_DISABLED #define load_cell_offset 0 APP_TIMER_DEF(ads1231_timer_id); int8_t rx[100] = {0}; void uart_error_handle(app_uart_evt_t * p_event) { if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR) { APP_ERROR_HANDLER(p_event->data.error_communication); } else if (p_event->evt_type == APP_UART_FIFO_ERROR) { APP_ERROR_HANDLER(p_event->data.error_code); } } static void uart_init(void){ uint32_t err_code; const app_uart_comm_params_t comm_params = { RX_PIN_NUMBER, TX_PIN_NUMBER, RTS_PIN_NUMBER, CTS_PIN_NUMBER, UART_HWFC, false, NRF_UART_BAUDRATE_115200 }; APP_UART_FIFO_INIT(&comm_params, UART_RX_BUF_SIZE, UART_TX_BUF_SIZE, uart_error_handle, APP_IRQ_PRIORITY_LOWEST, err_code); APP_ERROR_CHECK(err_code); } static void ads1231_timer_handler(void * p_context) { ret_code_t err_code; //static uint32_t * ADC_data; int32_t ADCValue; //ADC_data = ADS1231_readADCbyte(); ADCValue = ADS1231_readADC(); printf("ADC value: %d",ADCValue); } static void timers_init(void) { // Initialize timer module. ret_code_t err_code = app_timer_init(); APP_ERROR_CHECK(err_code); // Create timers. err_code = app_timer_create(&ads1231_timer_id, APP_TIMER_MODE_REPEATED, ads1231_timer_handler); APP_ERROR_CHECK(err_code); } int main(void) { uint32_t err_code; APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); //NRF_LOG_DEFAULT_BACKENDS_INIT(); bsp_board_init(BSP_INIT_LEDS); uart_init(); timers_init(); ADS1231_init(); err_code = app_timer_start(ads1231_timer_id, APP_TIMER_TICKS(100), NULL); APP_ERROR_CHECK(err_code); int32_t adcValue; uint32_t* adcByte; printf("\r\nUART example started.\r\n"); while (1) { } }
The program can be compiled and run, the interrupt also worked. But I can't get the correct value from ADS1231. The clock cycles I made by ADS1231_readADC() didn't work, so all the data I get were in high mode. That means, normally ADS1231 has 24 bits data, and now they were all in 1 mode.
I guess the problem may caused by the timer confliction, but I am not sure about it. Please give me some guide. This is my first nRF52832 project, I have really no idea how to deal with this problem. Thank you very much.
