I'm running nRF Connect Extension Pack on macOS within VS Code
Whenever a Build or Pristine Build has finished the terminal shows this message:
Terminal will be reused by tasks, press any key to close it.
when hitting Enter or any other key, the whole window manager is crashing du to an error in Electron.
Even remote connections like ssh will be closed, so it is not possible to fetch more logs.
Visual Studio
Version: 1.62.3
Commit: ccbaa2d27e38e5afa3e5c21c1c7bef4657064247
Date: 2021-11-17T07:59:13.865Z
Electron: 13.5.2
Chrome: 91.0.4472.164
Node.js: 14.16.0
V8: 9.1.269.39-electron.0
OS: Darwin x64 21.1.0
Translated Report (Full Report Below)
Process: Electron [35264]
Path: /Applications/Visual Studio Code.app/Contents/MacOS/Electron
Identifier: com.microsoft.VSCode
Version: 1.62.3 (1.62.3)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 502
Date/Time: 2021-11-19 10:06:34.3134 +0100
OS Version: macOS 12.0.1 (21A559)
Report Version: 12
Bridge OS Version: 6.0 (19P548)
Anonymous UUID: 3B02E2BF-F6F1-8A74-B257-593D094BFACF
Sleep/Wake UUID: 93960400-79CF-458A-9F24-0785953BEB91
Time Awake Since Boot: 310000 seconds
Time Since Wake: 3473 seconds
System Integrity Protection: enabled
Notes:
dyld_process_snapshot_get_shared_cache failed
Crashed Thread: 0
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007ff817b985f3
Exception Codes: 0x0000000000000001, 0x00007ff817b985f3
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [35264]
VM Region Info: 0x7ff817b985f3 is not in any region. Bytes after previous region: 140372812076532 Bytes before following region: 33959606797
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
Memory Tag 255 4d001c4000-4d001ff000 [ 236K] r-x/rwx SM=PRV
---> GAP OF 0x7fb2ffc01000 BYTES
VM_ALLOCATE 7fffffe00000-7fffffe01000 [ 4K] r--/r-- SM=ALI
Error Formulating Crash Report:
Thread 0 Crashed:
0 ??? 0x7ff817b985f3 ???
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00000000000089c0 rbx: 0x00007fa428f14e70 rcx: 0x00007ff817b985f3 rdx: 0x0000000000000001
rdi: 0x0000700005729048 rsi: 0x0000000000050000 rbp: 0x0000700005728620 rsp: 0x00007000057285f0
r8: 0x000000000042be98 r9: 0xffffffff00000000 r10: 0x00007ff8593bf6b0 r11: 0x0000000000000206
r12: 0x0000600002ab48b8 r13: 0x0000000000000003 r14: 0x0000600002ab48b8 r15: 0x00007fa428f14e70
rip: 0x00007ff817b985f3 rfl: 0x0000000000010206 cr2: 0x00007ff817b985f3
Logical CPU: 1
Error Code: 0x00000014 (no mapping for user instruction read)
Trap Number: 14
Binary Images:
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=127.2M resident=0K(0%) swapped_out_or_unallocated=127.2M(100%)
Writable regions: Total=10.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.9M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 128K 1
CG backing stores 2880K 4
CG image 72K 3
ColorSync 228K 26
CoreAnimation 248K 15
CoreGraphics 8K 1
CoreUI image data 1404K 11
Foundation 64K 2
Kernel Alloc Once 8K 1
MALLOC 312K 15
MALLOC guard page 48K 10
Mach message 40K 9
Memory Tag 253 32.0G 99
Memory Tag 255 2044K 12
VM_ALLOCATE 2108K 14
__DATA 9.9M 19
__DATA_CONST 112K 5
__LINKEDIT 5540K 18
__TEXT 121.9M 17
dyld private memory 1024K 1
mapped file 174.4M 34
shared memory 188K 16
TOTAL 32.3G 333
Full Report
{"app_name":"Electron","timestamp":"2021-11-19 10:06:35.00 +0100","app_version":"1.62.3","slice_uuid":"ab3cb5d1-eb3f-388f-8c63-416a00da1aaa","build_version":"1.62.3","platform":1,"bundleID":"com.microsoft.VSCode","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.0.1 (21A559)","incident_id":"62829D2F-4B44-45E1-9A78-B72C664A68A8","name":"Electron"}
"uptime" : 310000,
"procLaunch" : "2021-11-19 10:06:31.8142 +0100",
"procRole" : "Unspecified",
"version" : 2,
"userID" : 502,
"deployVersion" : 210,
"modelCode" : "MacBookPro15,1",
"procStartAbsTime" : 313140704348320,
"coalitionID" : 62852,
"osVersion" : {
"train" : "macOS 12.0.1",
"build" : "21A559",
"releaseType" : "User"
"captureTime" : "2021-11-19 10:06:34.3134 +0100",
"incident" : "62829D2F-4B44-45E1-9A78-B72C664A68A8",
"bug_type" : "309",
"pid" : 35264,
"procExitAbsTime" : 313140790719503,
"cpuType" : "X86-64",
"procName" : "Electron",
"procPath" : "\/Applications\/Visual Studio Code.app\/Contents\/MacOS\/Electron",
"bundleInfo" : {"CFBundleShortVersionString":"1.62.3","CFBundleVersion":"1.62.3","CFBundleIdentifier":"com.microsoft.VSCode"},
"storeInfo" : {"deviceIdentifierForVendor":"36C90C61-62D3-581C-B69C-CD91F0488646","thirdParty":true},
"parentProc" : "launchd",
"parentPid" : 1,
"coalitionName" : "com.microsoft.VSCode",
"crashReporterKey" : "3B02E2BF-F6F1-8A74-B257-593D094BFACF",
"responsiblePid" : 34460,
"wakeTime" : 3473,
"bridgeVersion" : {"build":"19P548","train":"6.0"},
"sleepWakeUUID" : "93960400-79CF-458A-9F24-0785953BEB91",
"sip" : "enabled",
"vmRegionInfo" : "0x7ff817b985f3 is not in any region. Bytes after previous region: 140372812076532 Bytes before following region: 33959606797\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n Memory Tag 255 4d001c4000-4d001ff000 [ 236K] r-x\/rwx SM=PRV \n---> GAP OF 0x7fb2ffc01000 BYTES\n VM_ALLOCATE 7fffffe00000-7fffffe01000 [ 4K] r--\/r-- SM=ALI ",
"isCorpse" : 1,
"exception" : {"codes":"0x0000000000000001, 0x00007ff817b985f3","rawCodes":[1,140703526651379],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x00007ff817b985f3"},
"termination" : {"flags":1024,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":35264},
"vmregioninfo" : "0x7ff817b985f3 is not in any region. Bytes after previous region: 140372812076532 Bytes before following region: 33959606797\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n Memory Tag 255 4d001c4000-4d001ff000 [ 236K] r-x\/rwx SM=PRV \n---> GAP OF 0x7fb2ffc01000 BYTES\n VM_ALLOCATE 7fffffe00000-7fffffe01000 [ 4K] r--\/r-- SM=ALI ",
"extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
"faultingThread" : 0,
"threads" : [{"triggered":true,"id":4377138,"threadState":{"r13":{"value":3},"rax":{"value":35264},"rflags":{"value":66054},"cpu":{"value":1},"r14":{"value":105553161046200},"rsi":{"value":327680},"r8":{"value":4374168},"cr2":{"value":140703526651379},"rdx":{"value":1},"r10":{"value":140704625718960},"r9":{"value":18446744069414584320},"r15":{"value":140343038266992},"rbx":{"value":140343038266992},"trap":{"value":14,"description":"(no mapping for user instruction read)"},"err":{"value":20},"r11":{"value":518},"rip":{"value":140703526651379,"matchesCrashFrame":1},"rbp":{"value":123145393702432},"rsp":{"value":123145393702384},"r12":{"value":105553161046200},"rcx":{"value":140703526651379},"flavor":"x86_THREAD_STATE","rdi":{"value":123145393705032}},"frames":[{"imageOffset":140703526651379,"imageIndex":0}]}],
"usedImages" : [
"size" : 0,
"source" : "A",
"base" : 0,
"uuid" : "00000000-0000-0000-0000-000000000000"
"vmSummary" : "ReadOnly portion of Libraries: Total=127.2M resident=0K(0%) swapped_out_or_unallocated=127.2M(100%)\nWritable regions: Total=10.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=10.9M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nCG backing stores 2880K 4 \nCG image 72K 3 \nColorSync 228K 26 \nCoreAnimation 248K 15 \nCoreGraphics 8K 1 \nCoreUI image data 1404K 11 \nFoundation 64K 2 \nKernel Alloc Once 8K 1 \nMALLOC 312K 15 \nMALLOC guard page 48K 10 \nMach message 40K 9 \nMemory Tag 253 32.0G 99 \nMemory Tag 255 2044K 12 \nVM_ALLOCATE 2108K 14 \n__DATA 9.9M 19 \n__DATA_CONST 112K 5 \n__LINKEDIT 5540K 18 \n__TEXT 121.9M 17 \ndyld private memory 1024K 1 \nmapped file 174.4M 34 \nshared memory 188K 16 \n=========== ======= ======= \nTOTAL 32.3G 333 \n",
"legacyInfo" : {
"threadTriggered" : {
"trialInfo" : {
"rollouts" : [
"rolloutId" : "60da5e84ab0ca017dace9abf",
"factorPackIds" : {
"deploymentId" : 240000008
"rolloutId" : "607844aa04477260f58a8077",
"factorPackIds" : {
"SIRI_MORPHUN_ASSETS" : "6103050cbfe6dc472e1c982a"
"deploymentId" : 240000066
"rolloutId" : "5ffde50ce2aacd000d47a95f",
"factorPackIds" : {
"deploymentId" : 240000076
"rolloutId" : "5fc94383418129005b4e9ae0",
"factorPackIds" : {
"deploymentId" : 240000162
"rolloutId" : "601d9415f79519000ccd4b69",
"factorPackIds" : {
"SIRI_TEXT_TO_SPEECH" : "6194416dea7ed64a7812a429"
"deploymentId" : 240000322
"rolloutId" : "602ad4dac86151000cf27e46",
"factorPackIds" : {
"SIRI_DICTATION_ASSETS" : "614a34c5eae97a2111628dc5"
"deploymentId" : 240000271
"experiments" : [
"reportNotes" : [
"dyld_process_snapshot_get_shared_cache failed"
Process: Electron [29219]
User ID: 502
Date/Time: 2021-11-19 10:00:08.3535 +0100
Report Version: 12
Time Since Wake: 3087 seconds
Notes:
Crashed Thread: 0
Terminating Process: exc handler [29219]
VM Region Info: 0x7ff817b985f3 is not in any region. Bytes after previous region: 140617625212404 Bytes before following region: 33959606797
Memory Tag 255 14001c4000-14001ff000 [ 236K] r-x/rwx SM=PRV
---> GAP OF 0x7febffc01000 BYTES
Thread 0 Crashed:
rax: 0x0000000000007223 rbx: 0x00007fc0fc8662d0 rcx: 0x00007ff817b985f3 rdx: 0x0000000000000001
rdi: 0x0000700012a6f048 rsi: 0x0000000000050000 rbp: 0x0000700012a6e620 rsp: 0x0000700012a6e5f0
r8: 0x00000000004235ec r9: 0xffffffff00000000 r10: 0x00007ff8593bf6b0 r11: 0x0000000000000206
r12: 0x00007fc0ff72dd88 r13: 0x0000000000000003 r14: 0x00007fc0ff72dd88 r15: 0x00007fc0fc8662d0
Logical CPU: 9
Trap Number: 14
Binary Images:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
Writable regions: Total=104.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=104.0M(100%)
VIRTUAL REGION
CG image 72K 6
ColorSync 228K 26
CoreAnimation 304K 15
CoreGraphics 8K 1
CoreUI image data 1772K 13
Dispatch continuations 96.0M 1
Foundation 64K 2
MALLOC 324K 18
MALLOC guard page 72K 16
Mach message 40K 7
SQLite page cache 128K 2
VM_ALLOCATE 60K 13
__DATA 9.9M 19
__DATA_CONST 112K 5
__LINKEDIT 5540K 18
__TEXT 121.9M 17
libnetwork 128K 8
mapped file 174.5M 36
shared memory 184K 18
TOTAL 417.0M 260
Full Report
{"app_name":"Electron","timestamp":"2021-11-19 10:00:11.00 +0100","app_version":"1.62.3","slice_uuid":"ab3cb5d1-eb3f-388f-8c63-416a00da1aaa","build_version":"1.62.3","platform":1,"bundleID":"com.microsoft.VSCode","share_with_app_devs":0,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.0.1 (21A559)","incident_id":"14069921-3302-4FFF-952B-CC48577738D1","name":"Electron"}
"uptime" : 310000,
"procLaunch" : "2021-11-19 10:00:07.9851 +0100",
"version" : 2,
"userID" : 502,
"procStartAbsTime" : 312756860245025,
"coalitionID" : 62145,
"osVersion" : {
"build" : "21A559",
"captureTime" : "2021-11-19 10:00:08.3535 +0100",
"incident" : "14069921-3302-4FFF-952B-CC48577738D1",
"bug_type" : "309",
"pid" : 29219,
"procExitAbsTime" : 312756924441889,
"parentPid" : 1,
"responsiblePid" : 27619,
"wakeTime" : 3087,
"sip" : "enabled",
"vmRegionInfo" : "0x7ff817b985f3 is not in any region. Bytes after previous region: 140617625212404 Bytes before following region: 33959606797\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n Memory Tag 255 14001c4000-14001ff000 [ 236K] r-x\/rwx SM=PRV \n---> GAP OF 0x7febffc01000 BYTES\n VM_ALLOCATE 7fffffe00000-7fffffe01000 [ 4K] r--\/r-- SM=ALI ",
"isCorpse" : 1,
"termination" : {"flags":1024,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":29219},
"vmregioninfo" : "0x7ff817b985f3 is not in any region. Bytes after previous region: 140617625212404 Bytes before following region: 33959606797\n REGION TYPE START - END [ VSIZE] PRT\/MAX SHRMOD REGION DETAIL\n Memory Tag 255 14001c4000-14001ff000 [ 236K] r-x\/rwx SM=PRV \n---> GAP OF 0x7febffc01000 BYTES\n VM_ALLOCATE 7fffffe00000-7fffffe01000 [ 4K] r--\/r-- SM=ALI ",
"threads" : [{"triggered":true,"id":4344665,"threadState":{"r13":{"value":3},"rax":{"value":29219},"rflags":{"value":66054},"cpu":{"value":9},"r14":{"value":140466896166280},"rsi":{"value":327680},"r8":{"value":4339180},"cr2":{"value":140703526651379},"rdx":{"value":1},"r10":{"value":140704625718960},"r9":{"value":18446744069414584320},"r15":{"value":140466847113936},"rbx":{"value":140466847113936},"trap":{"value":14,"description":"(no mapping for user instruction read)"},"err":{"value":20},"r11":{"value":518},"rip":{"value":140703526651379,"matchesCrashFrame":1},"rbp":{"value":123145615238688},"rsp":{"value":123145615238640},"r12":{"value":140466896166280},"rcx":{"value":140703526651379},"flavor":"x86_THREAD_STATE","rdi":{"value":123145615241288}},"frames":[{"imageOffset":140703526651379,"imageIndex":0}]}],
"usedImages" : [
"size" : 0,
"source" : "A",
"base" : 0,
"vmSummary" : "ReadOnly portion of Libraries: Total=127.2M resident=0K(0%) swapped_out_or_unallocated=127.2M(100%)\nWritable regions: Total=104.0M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=104.0M(100%)\n\n VIRTUAL REGION \nREGION TYPE SIZE COUNT (non-coalesced) \n=========== ======= ======= \nAccelerate framework 128K 1 \nCG backing stores 2880K 4 \nCG image 72K 6 \nColorSync 228K 26 \nCoreAnimation 304K 15 \nCoreGraphics 8K 1 \nCoreUI image data 1772K 13 \nDispatch continuations 96.0M 1 \nFoundation 64K 2 \nKernel Alloc Once 8K 1 \nMALLOC 324K 18 \nMALLOC guard page 72K 16 \nMach message 40K 7 \nMemory Tag 255 2044K 12 \nSQLite page cache 128K 2 \nVM_ALLOCATE 60K 13 \n__DATA 9.9M 19 \n__DATA_CONST 112K 5 \n__LINKEDIT 5540K 18 \n__TEXT 121.9M 17 \ndyld private memory 1024K 1 \nlibnetwork 128K 8 \nmapped file 174.5M 36 \nshared memory 184K 18 \n=========== ======= ======= \nTOTAL 417.0M 260 \n",
"legacyInfo" : {
"trialInfo" : {
"rollouts" : [
"factorPackIds" : {
"factorPackIds" : {
"factorPackIds" : {
"factorPackIds" : {
"factorPackIds" : {
"factorPackIds" : {
"experiments" : [
"reportNotes" : [
