How to build a maximum-length beacon (without using extended advertising)?
The discussion in https://devzone.nordicsemi.com/f/nordic-q-a/79364/maximum-number-of-bytes-that-can-be-used-in-beacon-advertising suggests that we should be able to populate 27 bytes of a beacon, with the remainder consisting of Manufacturer ID, length, and a type byte.  However, none of the examples suggest how to actually do this. we were using extended beacons but ran into a use case where the recipient only had BLE 4.2 so now it's about how many bytes we can squeeze out of traditional beacons...
My experiments with using ble_advdata_manuf_data_t and calling ble_data_encode() suggest that I can only directly affect the contents of a much smaller number of bytes without getting an NRF_ERROR_DATA_SIZE error.
I then tried just manually put in the 2 bytes of Manufacturer ID, a type (??) and a length (31 or 27?) then put in data, without calling ble_data_encode(). What I got back was BLE_ERROR_GAP_UUID_LIST_MISMATCH, so apparently that's not quite the correct approach.  Suggestions would be most welcome.
Thanks!
    The maximum size of the manufacturer specific data in a normal advertising packet is 24 bytes. With this, the entire advertising packet will be 31 bytes, which is the maximum. You can refer to this code which is a stripped down version of the beacon example that just use a maximum sized manufacturer specific array (you can drop it into the beacon example in SDK 17.1.0 to test yourself).
     * Copyright (c) 2014 - 2021, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_beacon_main main.c
     * @ingroup ble_sdk_app_beacon
     * @brief Beacon Transmitter Sample Application main file.
     * This file contains the source code for an Beacon transmitter sample application.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nordic_common.h"
    #include "bsp.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "ble_advdata.h"
    #include "app_timer.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_COMPANY_IDENTIFIER 0x0059                                      /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
    #define MANUF_DATA_LENGTH               24
    #define APP_BLE_CONN_CFG_TAG            1                                  /**< A tag identifying the SoftDevice BLE configuration. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
    #define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
    #define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
    #define DEAD_BEEF                       0xDEADBEEF                         /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
    static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
    static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
    /**@brief Struct that contains pointers to the encoded advertising data. */
    static ble_gap_adv_data_t m_adv_data =
        .adv_data =
            .p_data = m_enc_advdata,
            .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
        .scan_rsp_data =
            .p_data = NULL,
            .len    = 0
    /**@brief Dummy manufacturer specific data */
    static uint8_t m_manuf_data[MANUF_DATA_LENGTH] = {
        0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F,
        0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
        ble_advdata_manuf_data_t manuf_specific_data;
        manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
        manuf_specific_data.data.p_data = (uint8_t *) m_manuf_data;
        manuf_specific_data.data.size   = MANUF_DATA_LENGTH;
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type             = BLE_ADVDATA_NO_NAME;
        advdata.flags                 = flags;
        advdata.p_manuf_specific_data = &manuf_specific_data;
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        NRF_LOG_INFO("Advertising data length after encoding: %u", m_adv_data.adv_data.len);
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
        ret_code_t err_code;
        err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for initializing logging. */
    static void log_init(void)
    /**@brief Function for initializing LEDs. */
    static void leds_init(void)
        ret_code_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    /**@brief Function for initializing timers. */
    static void timers_init(void)
            nrf_pwr_mgmt_run();
     * @brief Function for application main entry.
        // Initialize.
        log_init();
        timers_init();
        leds_init();
        power_management_init();
        ble_stack_init();
        advertising_init();
        // Start execution.
        NRF_LOG_INFO("Beacon example started.");
        advertising_start();
        // Enter main loop.
        for (;; )
            idle_state_handle();
