Hell there
Can I find an SDK that is supported on Nrf52805 chip? Or can I get any proper guidance on program of nrf52805 (the module MS46SFIi) together with Segger Studio.
Hell there
The nRF52805 is supported out of the box in nRF Connect SDK (see nRF52805 > Compatibility Matrix > SDKs and SoftDevices), but you can also use the nRF5 SDK by porting a nRF52832 example as explained in Developing for the nRF52805 with nRF5 SDK.
We do not have any guides for MS46SF11, but there is a similar case here: Problem with getting started with software development on nRF52805 where this module is used. However, this is for the nRF5 SDK. For developing for nRF52805, you can use a nRF52 DK with a nRF52832 SoC to simulate the nRF52805. In nRF Connect SDK this is done by using nrf52dk_nrf52805 as build target (see nRF52805 emulation on nRF52 DK). You can use SEGGER Embedded Studio with both nRF Connect SDK and nRF5 SDK, see nRF Connect SDK » Getting started and Getting started with nRF5 SDK and SES (nRF51 & nRF52 Series).
Marte
Hi, I have a question. I've been using pin P0.04, and it works fine, but pin P0.05 doesn't do anything. I have two modules, and they both do the same thing. Is this normal?
I cannot find anything in our datasheet or the datasheet for MS46SF11 indicating that there should be any problems using P0.05.
This ticket is more than 5 years old. Please create a new ticket with more information about the issue. Thank you.
Marte
