i want to do simple data transfer and why blueetooth serial terminal was not be able to detect the device?
how to do simple data transfer using bluetooth serail terminal?
  • Have you verified that your code ever enters into the BSP_EVENT_KEY_2 case?
    Please check the error code returned by your call to ble_nus_data_send. If you do not check the returned error code you will never be alerted if the function call fails unexpectedly.
    Please also make sure to have DEBUG defined in your preprocessor defines, like shown in the included image:
    This will make your logger output a detailed error message whenever a non-NRF_SUCCESS error code is passed to an APP_ERROR_CHECK.
    Karl
  • thanks karl its wprking and one more thing what is the minimum data rate i can set in BLE?
    i know only 1mbps and 2mbps are the possible but will it be possible to set below 1mbps data rate?
  • static void advertising_init(void)
        int8_t tx_power_level = 8;
        ble_advertising_init_t init;
        ble_gap_adv_params_t adv_params;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
       // init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        //init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
        init.config.ble_adv_fast_timeout  = 0;
        adv_params.primary_phy = BLE_GAP_PHY_1MBPS;
        adv_params.secondary_phy = BLE_GAP_PHY_1MBPS;
        adv_params.duration = APP_ADV_DURATION;
        adv_params.p_peer_addr = NULL;
        adv_params.filter_policy = BLE_GAP_ADV_FP_ANY;
        adv_params.interval = APP_ADV_INTERVAL;
       // err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
       // APP_ERROR_CHECK(err_code);
      //  err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, tx_power_level);
    i did like this to change the phy rate to 1mbps will this is the right way?
    Great, I am happy to hear that!
    I am not sure what you are asking about here, are you asking in regards to reducing the power consumption, or to practically send as little as possible? I will assume the former and say that; you will actually save power by using the 2 M PHY over the 1 M PHY because the RADIO will only be used for half the time.
    Yes, this will make your device advertise on the 1 M PHY. When a central scans on the 1 M PHY and initiates a connection with the device the connection will also be on 1 M PHY (it inherits the PHY of the scanner/advertiser).
    If you have more questions that diverge from your original ticket I would recommend that you open a new ticket for these questions, to keep the forum tidy and easy to navigate.
    Karl
