how to do simple data transfer using bluetooth serail terminal?
how much time the device will take to advertise the data? and how do i calculate?
This depends on your advertising configuration and payload. You could use the Online Power Profiler to estimate how long each advertising / transfers will take.
Karl
| Sleep | 1 | Push | BSP_EVENT_WAKEUP |
| Sleep | 2 | Push | BSP_EVENT_CLEAR_BONDING_DATA |
| Startup | 2 | Hold | BSP_EVENT_CLEAR_BONDING_DATA |
| Startup | 4 | Hold | BSP_EVENT_DFU |
| Awake | 2 | Long Push | BSP_EVENT_WHITELIST_OFF |
| Connected | 1 | Long push | BSP_EVENT_DISCONNECT |
| Not Connected | 1 | Release | BSP_EVENT_SLEEP |
for (num = 0; ((num < BUTTONS_NUMBER) && (err_code == NRF_SUCCESS)); num++)
err_code = bsp_event_to_button_action_assign(num, BSP_BUTTON_ACTION_PUSH, BSP_EVENT_DEFAULT);
this was the function to assign the buttons to appropriate bsp events but in that function why default event passed ? which means all the buttons assinged to default events then how come button1 assigned to bsp_event_wakeup?
will online power profiler requires power profiler kit ?
where actually transmission power set api called and how to change the transmission power?
