how to do simple data transfer using bluetooth serail terminal?
how to measure power consumption in nrf52840 development kit using power profiler kit?
venkatesha kj said:will online power profiler requires power profiler kit ?
No, the online power profiler only makes estimates of power consumption for the specified scenario. Please keep in mind that these estimates assume no other operations are happening on your DK concurrently with the radio activity.
venkatesha kj said:where actually transmission power set api called and how to change the transmission power?
You may set the TX power through the sd_ble_gap_tx_power_set function. This should be called as part of the advertising / scanning initialization, before advertising / scanning has begun. Connections will inherit the power level configured during initialization of advertising / scanning.
venkatesha kj said:how to measure power consumption in nrf52840 development kit using power profiler kit?
If you wish to measure the current consumption of the nRF52840 DK you should follow the Current Measurement section of its Product Specification.
I see that you have made a separate ticket for this. Please do not post duplicates of your questions, and please create new tickets for issues that diverge from your existing ticket - such as power consumption, in this case.
venkatesha kj said:this was the function to assign the buttons to appropriate bsp events but in that function why default event passed ? which means all the buttons assinged to default events then how come button1 assigned to bsp_event_wakeup?
This is only for the general bsp.c case, the application actually uses the bsp_btn_ble case which is what the button overview you are referencing is referring to. Please take a look at the bsp_btn_ble.c 's bsp_btn_ble_init function.
Karl
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
// init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
//init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
init.config.ble_adv_fast_timeout = 0;
in advertisement initialisation where actually tx power was set?
If you do not specify it explicitly it will use the default value of +0 dBm.
You may re-configure this at the end of the advertising_init function.
Karl
int8_t tx_power_level = 4;
uint32_t err_code;
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, tx_power_level);
i have set the transmit power to 4dbm but in nrf connect app rssi level was -45dbm when i am near to the device will the tx power set to 4dbm or not? and am using s140 can i set Supported tx_power values: -40dBm, -20dBm, -16dBm, -12dBm, -8dBm, -4dBm, 0dBm, +3dBm and +4dBm.
* In addition, on some chips following values are supported: +2dBm, +5dBm, +6dBm, +7dBm and +8dBm. any of the tx power level?
