Cannot recover nrf52840 with nrfjprog
We have this unit with an nrf52840, it suddenly refused to respond to `nrfjprog --recover`.
This is the second unit this happens with.
The power seems ok (we can see on UART that the unit runs its firmware).
Attached is the log file from nrfjprog.
We tested several cables, several SEGGER J-link programmers, several USB connectors, from Ubuntu or MacOS, ...
Other units are fine, it's just this one and one more.
I've tried these, none of it worked:
- `nrfjprog --rbp ALL`
- JLinkExe with Cortex-M4, SWD, 4000 kHz. On the faulty unit, it stops at "Cannot connect to target.". On working units, it comes further (fails later, presumably because of approtect).
- I have a recollection, when this happened the last time, of trying to write to DP registers with JLinkExe. It was not possible. I don't recall the commands.
$ nrfjprog --version
nrfjprog version: 10.14.0 external
JLinkARM.dll version: 7.54c
What is going on, how can I solve it?
  • Apparently, attaching log files does not work well here.
    Here it comes in plain text:
    [2021-Nov-22 11:26:36] [ info] --------------------------------------------------------------------------------
    [2021-Nov-22 11:26:36] [ info] nrfjprog --recover --log
    [2021-Nov-22 11:26:36] [ info] nrfjprog version 10.14.0 external
    [2021-Nov-22 11:26:36] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
    [2021-Nov-22 11:26:36] [ info] Library loaded, loading member functions.
    [2021-Nov-22 11:26:36] [ info] Member functions succesfully loaded.
    [2021-Nov-22 11:26:36] [debug] [ Client] - open
    [2021-Nov-22 11:26:36] [debug] [ Client] - start
    [2021-Nov-22 11:26:36] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence b6b3a807-6cf7-4e87-b3e5-7d61cd016de9.
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2021-Nov-22 11:26:36] [debug] [ JLink] - Logger sink registered in JLink logger
    [2021-Nov-22 11:26:36] [debug] [ nRFXX] - open
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - open_dll
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2021-Nov-22 11:26:36] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.54.3.
    [2021-Nov-22 11:26:36] [trace] [ Client] - Command open executed for 2 milliseconds with result 0
    [2021-Nov-22 11:26:36] [debug] [ Client] - enum_emu_snr
    [2021-Nov-22 11:26:36] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2021-Nov-22 11:26:36] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - dll_version
    [2021-Nov-22 11:26:36] [ info] [SeggerBackend] - Segger dll version 7.54.c loaded.
    [2021-Nov-22 11:26:36] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
    [2021-Nov-22 11:26:36] [debug] [ nRFXX] - enum_emu_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - is_connected_to_emu
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - enum_emu_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - ---just_get_num_emus
    [2021-Nov-22 11:26:36] [trace] [ Client] - Command enum_emu_snr executed for 171 milliseconds with result 0
    [2021-Nov-22 11:26:36] [debug] [ Client] - connect_to_emu_with_snr
    [2021-Nov-22 11:26:36] [trace] [ Worker] - Command enum_emu_snr executed for 171 milliseconds with result 0
    [2021-Nov-22 11:26:36] [debug] [ nRFXX] - connect_to_emu_with_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2021-Nov-22 11:26:36] [debug] [SeggerBackend] - Segger logging enabled.
    [2021-Nov-22 11:26:37] [trace] [ JLink] - Firmware: J-Link ARM V8 compiled Nov 28 2014 13:44:46
    [2021-Nov-22 11:26:37] [trace] [ JLink] - Hardware: V8.00
    [2021-Nov-22 11:26:37] [trace] [ JLink] - S/N: 268006363
    [2021-Nov-22 11:26:37] [trace] [ JLink] - OEM: SEGGER-EDU
    [2021-Nov-22 11:26:37] [trace] [ JLink] - Feature(s): FlashBP, GDB
    [2021-Nov-22 11:26:37] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2021-Nov-22 11:26:37] [trace] [ JLink] - WEBSRV Starting webserver
    [2021-Nov-22 11:26:37] [trace] [ JLink] - WEBSRV Webserver running on local port 19080
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 120.009ms returns "O.K."
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_HasError()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_Lock()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.296ms returns 0
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.022ms returns 0x01
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.017ms returns 0x00
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.004ms returns 0x00
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.015ms returns 0
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.985ms returns 0x00
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_SetSpeed(2000)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.206ms
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_GetSN()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.002ms returns 268006363
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - read_debug_port_idr
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - read_debug_port_register
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - coresight_configure
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 1.754ms returns 0
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.254ms returns -1
    [2021-Nov-22 11:26:37] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.208ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.273ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.259ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.257ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.242ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.192ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.194ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.211ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.228ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.308ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.207ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.210ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.206ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.199ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.187ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.202ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.205ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.186ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.204ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ Client] - Command connect_to_emu_with_snr executed for 362 milliseconds with result -102
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.219ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.191ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.209ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.005ms
    [2021-Nov-22 11:26:37] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 362 milliseconds with result -102
    [2021-Nov-22 11:26:37] [debug] [ nRFXX] - close
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - is_connected_to_emu
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_IsOpen()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.002ms returns 0x01
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - close
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - disconnect_from_emu
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - is_connected_to_device
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_IsConnected()
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.002ms returns FALSE
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.196ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.223ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.229ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.233ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.342ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.198ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.201ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.195ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.185ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.260ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - - 0.230ms returns -1
    [2021-Nov-22 11:26:37] [trace] [ JLink] - JLINK_Close()
    [2021-Nov-22 11:26:37] [debug] [SeggerBackend] - Segger Backend closed.
    [2021-Nov-22 11:26:37] [debug] [ nRFXX] - nRF family DLL closed
    [2021-Nov-22 11:26:37] [trace] [ Client] - Command close executed for 34 milliseconds with result 0
    [2021-Nov-22 11:26:37] [debug] [ Client] - terminate
    [2021-Nov-22 11:26:37] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2021-Nov-22 11:26:37] [trace] [ Worker] - Command close executed for 34 milliseconds with result 0
    [2021-Nov-22 11:26:37] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2021-Nov-22 11:26:37] [trace] [ Worker] - Executed 5 commands for 569 milliseconds
    [2021-Nov-22 11:26:37] [debug] [ Client] - Worker process exited with code: 0
    [2021-Nov-22 11:26:37] [debug] [ Client] - Child process terminated with result 0
    [2021-Nov-22 11:26:37] [trace] [ Client] - Executed 5 commands for 569 milliseconds
  • is it possible that you flashed something onto the chip that makes it go to deep sleep so fast after the reset that the debugger is unable to make a connection to it?
    > nrfjprog --recover -f nrf52
    is the last hope, if it did not work then it is possible you somehow bricked the chip.
  • > nrfjprog --recover -f nrf52
    I've tried that, with and without the family. I understand it might be bricked, that's what I thought when it happened the first time. But this is the second time in a week, I want to investigate what is happening, so it does not happen more times!
  • Please check if one of these steps help you. Also check if your input power source that is connected to the chip if it has any spikes at times.
