CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y is only capturing partial packets
I have CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y.  And when I capture and convert to wireshark trace I might see a couple of random packets captured.  I am doing 2 separate TLS connects() and handshakes.  So I would definitely expect to see much more than a few random packets.
Here is my prj.conf:
CONFIG_THREAD_MONITOR=y
CONFIG_NRF_MODEM_LIB=y                # implies CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n       # The application will take care of initializing Modem in main.c
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y                  # Will provide BSD name support. e.g. setsockopt() instead of nrf_setsockopt()
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_NATIVE=n                   # We are using socket offload, so set this to no
CONFIG_BUILD_WITH_TFM=y
# Memory size for k_malloc()
CONFIG_HEAP_MEM_POOL_SIZE=16384
# 4096 is the default
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_MODEM_KEY_MGMT=y               # Application wants to make calls to store keys
CONFIG_LTE_LINK_CONTROL=y             # Enable the API's to setup and configure the LTE link
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n    # The application will take care of initializing the LTE stuff in main.c
CONFIG_NEWLIB_LIBC=y                  # Use the "new" libc
CONFIG_SAMPLE_TFM_MBEDTLS=y
CONFIG_CJSON_LIB=y
CONFIG_HTTP_CLIENT=y
# MbedTLS and security
CONFIG_NORDIC_SECURITY_BACKEND=y            # Required when commenting out BUILD_WITH_TFM
CONFIG_MBEDTLS_VANILLA_BACKEND=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
CONFIG_NET_SOCKETS_OFFLOAD_TLS=n
CONFIG_MBEDTLS_ENABLE_HEAP=y
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=8192
CONFIG_MBEDTLS_HEAP_SIZE=44000
CONFIG_MBEDTLS_TLS_LIBRARY=y
CONFIG_MBEDTLS_PKCS1_V15=y
CONFIG_MBEDTLS_RSA_C=y
CONFIG_MBEDTLS=y                              # Required when commenting out CONFIG_NORDIC_SECURITY_BACKEND
# CONFIG_USE_SEGGER_RTT=y
# CONFIG_RTT_CONSOLE=y
# CONFIG_UART_CONSOLE=n
# Event management which handles network-related events (like ip address change, or net iface up/down for examples)
# CONFIG_NET_MGMT=y
# CONFIG_NET_MGMT_EVENT=y
# CONFIG_NET_SOCKETS_NET_MGMT=y
Thank you
/Loren
