nRF5340 power consumption on bt_le_adv_stop()
Hi Nordic Semi
I have implemented a basic BLE peripheral on a nRF5340 using the nRF Connect SDK 1.7.0.0.
The product we are developing have strict power consumption requirements.
I thus want to limit the BLE advertising period and upon expiration only allow bonded devices to connect.
The advertise expiration, I have implemented by means of a timer (K_TIMER_DEFINE(..)).
Upon expiration of this timer I call bt_le_adv_stop().
During advertisement I see a power use in the range of 4 mA.
When I call bt_le_adv_stop() the power use increate to 7 mA.
I can limit this to 5.5. mA, by calling pm_power_state_force((struct pm_state_info){PM_STATE_SUSPEND_TO_IDLE,0,0}); But the power use remains higher that while advertising.
Can you assist me in normalizing the power use after calling bt_le_adv_stop() ?
Regards Tonny
  • Hi Tonny,
    Try disabling serial communication by adding CONFIG_SERIAL=n to prj.conf. Do you still get the same current?
    What is the current consumption before you start advertising?
    Would you be able to share a code snippet? We will try to reproduce this.
    Håkon
  • Hi Håkon
    CONFIG_SERIAL was already set to n.
    I have isolated the BLE related code in the code below.
    The example advertises for 15 sec. and then calls bt_le_adv_stop();
    When debugging this code I can see what happens: calling bt_le_adv_stop() cause the MCU to restart.
    Try setting a breakpoint in main and in onAdvertiseTimeout.
    When I debug the sample, the breakpoint in main is hit after bt_le_adv_stop() is called.
    Regards Tonny
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <sys/printk.h>
    #include <sys/byteorder.h>
    #include <zephyr.h>
    #include <drivers/gpio.h>
    #include <soc.h>
    #include <bluetooth/bluetooth.h>
    #include <bluetooth/hci.h>
    #include <bluetooth/conn.h>
    #include <bluetooth/uuid.h>
    #include <bluetooth/gatt.h>
    #include <bluetooth/gatt_dm.h>
    #include <settings/settings.h>
    #include <pm/pm.h>
    //### PREDECLARATIONS
    ssize_t onBleWrite(struct bt_conn *conn, const struct bt_gatt_attr *attr,
    					 const void *buf, uint16_t len, uint16_t offset,
    					 uint8_t flags);
    static void onCccCfgchanged(const struct bt_gatt_attr *attr, uint16_t value);
    static void onAdvertiseTimeout(struct k_timer *timer);
    //### GLOBALS AND MACROS
    #define DEVICE_NAME             CONFIG_BT_DEVICE_NAME
    #define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
    static bool pipeClientRegistered = false;
    static struct bt_uuid_128 serviceUuid = BT_UUID_INIT_128(
    	BT_UUID_128_ENCODE(0x12345678, 0x1234, 0x6789, 0xACA8, 0x123456789ABC));
    static const struct bt_uuid_128 pipeCharacteristicUuid = BT_UUID_INIT_128(
    static struct bt_gatt_attr serviceAttributes[] = {
        BT_GATT_PRIMARY_SERVICE(&serviceUuid),
        BT_GATT_CHARACTERISTIC(&pipeCharacteristicUuid.uuid,
            BT_GATT_CHRC_NOTIFY | BT_GATT_CHRC_WRITE_WITHOUT_RESP,
            BT_GATT_PERM_READ | BT_GATT_PERM_WRITE, NULL, onBleWrite, NULL),
        BT_GATT_CCC(onCccCfgchanged, BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
    static struct bt_gatt_service bleService = BT_GATT_SERVICE(serviceAttributes);
    // Manufacturer specific data
    static uint8_t msd[] = {
    	0xA0, 0x02,
    	0xB0 /* Some data ... */
    // Advertise packet
    static const struct bt_data advertiseData[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    	BT_DATA(BT_DATA_MANUFACTURER_DATA, msd, sizeof(msd))
    //### UTILS
    static const char *phy2str(uint8_t phy)
    	switch (phy) {
    	case 0: return "No packets";
    	case BT_GAP_LE_PHY_1M: return "LE 1M";
    	case BT_GAP_LE_PHY_2M: return "LE 2M";
    	case BT_GAP_LE_PHY_CODED: return "LE Coded";
    	default: return "Unknown";
    K_TIMER_DEFINE(advertiseTimer, onAdvertiseTimeout, NULL);
    //### CONNECTION STATUS CALLBACKS
    static void onConnected(struct bt_conn *conn, uint8_t err)
    	if (err) {
    		printk("Connection failed (err 0x%02x)\n", err);
    		return;
    static void onDisconnected(struct bt_conn *conn, uint8_t reason)
    	printk("Disconnected from %s (reason 0x%02x)\n", addr, reason);
    static void onSecurityChanged(struct bt_conn *conn, bt_security_t level,
    			     enum bt_security_err err)
    	if (!err) {
    		printk("Security changed: %s level %u\n", addr, level);
    	} else {
    		printk("Security failed: %s level %u err %d\n", addr, level,
    			err);
    //### CONNECTION PARAMERTER NEGOTIATION CALLBACKS
    static bool onBleParameterRequest(struct bt_conn *conn, struct bt_le_conn_param *param)
    	printk("Connection parameters update request received.\n");
    	printk("Minimum interval: %d, Maximum interval: %d\n",
    	       param->interval_min, param->interval_max);
    	printk("Latency: %d, Timeout: %d\n", param->latency, param->timeout);
    	return true;
    static void onBleParamtereupdated(struct bt_conn *conn, uint16_t interval,
    			     uint16_t latency, uint16_t timeout)
    	printk("Connection parameters updated.\n"
    	       " interval: %d, latency: %d, timeout: %d\n",
    	       interval, latency, timeout);
    static void onBlePhyUpdated(struct bt_conn *conn,
    			   struct bt_conn_le_phy_info *param)
    	printk("LE PHY updated: TX PHY %s, RX PHY %s\n",
    	       phy2str(param->tx_phy), phy2str(param->rx_phy));
    static void onBleDataLengthUpdated(struct bt_conn *conn,
    				   struct bt_conn_le_data_len_info *info)
    	printk("LE data len updated: TX (len: %d time: %d)"
    	       " RX (len: %d time: %d)\n", info->tx_max_len,
    	       info->tx_max_time, info->rx_max_len, info->rx_max_time);
    static struct bt_conn_cb connectionCallbacks = {
    	.connected = onConnected,
    	.disconnected = onDisconnected,
    	.security_changed = onSecurityChanged,
    	.le_param_req = onBleParameterRequest,
    	.le_param_updated = onBleParamtereupdated,
    	.le_phy_updated = onBlePhyUpdated,
    	.le_data_len_updated = onBleDataLengthUpdated};
    //### CONNECTION AUTHORISATION CALLBACKS
    static void onAuthorizationCancel(struct bt_conn *conn)
    	printk("Pairing cancelled: %s\n", addr);
    static void onPairingConfirm(struct bt_conn *conn)
    	bt_conn_auth_pairing_confirm(conn);
    	printk("Pairing confirmed: %s\n", addr);
    static void onPairingComplete(struct bt_conn *conn, bool bonded)
    	printk("Pairing completed: %s, bonded: %d\n", addr, bonded);
    static void onPairingFailed(struct bt_conn *conn, enum bt_security_err reason)
    	printk("Pairing failed conn: %s, reason %d\n", addr, reason);
    static struct bt_conn_auth_cb connectionAuthorizationCallbacks = {
    	.cancel = onAuthorizationCancel,
    	.pairing_confirm = onPairingConfirm,
    	.pairing_complete = onPairingComplete,
    	.pairing_failed = onPairingFailed
        pipeClientRegistered = (value == BT_GATT_CCC_NOTIFY) ? true : false;
    	printk("Notification status changed: %d\n", pipeClientRegistered);
    					 uint8_t flags)
    	printk("Received: %d bytes\n", len);
    	// Loopback data
    	bt_gatt_notify(conn, &serviceAttributes[1], buf, len);
    	return len;
    	bt_le_adv_stop();
    	// Stopping advertising leads to increased power consumption for some reason.
    	// Forcing the MCU into power save helps on the problem but does not completely solve it.
    	// See issue: https://github.com/zephyrproject-rtos/zephyr/issues/3192
    	// pm_power_state_force((struct pm_state_info){PM_STATE_SUSPEND_TO_IDLE,0,0});
    //### MAIN
    void main(void)
    	int err;
    	printk("Starting GATT Discovery Manager example\n");
    	err = bt_enable(NULL);
    	if (err) {
    		printk("BLE init failed with error code %d\n", err);
    		return;
    	// Load application settings where bonding information is stored.
    	// Regarding info log statement "bt_hci_core: No ID address. App must call settings_load,
    	// see link: https://lists.zephyrproject.org/g/devel/topic/is_bluetooth_sample/28575293.
    	if (IS_ENABLED(CONFIG_SETTINGS)) {
    		printk("Loading settings\n");
    		settings_load();
    	err = bt_gatt_service_register(&bleService);
    	if (err) {
    		printk("BLE service registration failed %d\n", err);
    		return;
    	bt_conn_cb_register(&connectionCallbacks);
    	if (err) {
    		printk("Failed to register connection callbacks.\n");
    		return;
    	err = bt_conn_auth_cb_register(&connectionAuthorizationCallbacks);
    	if (err) {
    		printk("Failed to register authorization callbacks.\n");
    		return;
    	k_timer_start(&advertiseTimer, K_SECONDS(15), K_HOURS(15));
    	err = bt_le_adv_start(BT_LE_ADV_CONN, advertiseData, ARRAY_SIZE(advertiseData),
    			      NULL, 0);
    	if (err) {
    		printk("Advertising failed to start (err %d)\n", err);
    		return;
    	printk("Advertising successfully started\n");
  • Hi Håkon
    I found the answer.
    bt_le_adv_stop() cannot be called from a k_timer handler that executes in timer irq context.
    The Zephyr documentation states: Use a timer to initiate an asynchronous operation ..
    A bit fluffy, but it gave a hint.
    The solution was (as also specified in the documentation) to dispatch the timeout to a Worker Queue, and
    have a handler call bt_le_adv_stop() from its worker context.
    static void onAdvertiseTimeoutIrq(struct k_timer *timer)
    	k_work_submit(&advertiseTimeoutWork);
    static void onAdvertiseTimeoutWork(struct k_work *work)
    	bt_le_adv_stop();
  • Hi Tonny, great to hear you figured it out.
