Hi, I cannot compile the sample of VL53L0X with VSC. I have the following error: 'DT_N_INST_0_st_vl53l0x_P_label' undeclared (first use in this function) Do I need to add specific information related to my Icarus card?
By reworking the sample with other examples, I passed this error but I'm stuck on another point:In the file /opt/nordic/ncs/v1.7.0/zephyr/drivers/sensor/vl53l0x/vl53l0x.c DEVICE_INST_DEFINE (0, vl53l0x_init, NULL, & vl53l0x_driver, NULL, POST_KERNEL, CONFIG_SENSOR_INIT_PRIORITY, & vl53l0x_api_funcs);give me this first error (then others same style): error: expected declaration specifiers or '...' before numeric constant
Does somebody have an idea ? Thanks for help
I did no other change to the example (zephyr/samples/sensor/vl53l0x/) other than create the folder "boards" and place the overlay file in that folder.
I configured for board actinius_icarus_ns…
You'll need to add the vl53l0x to your device tree overlay.
That is usually done by adding a board specific overlay, in my_application/boards/$board.overlay.
Here's what I added to the board overlay file:
&i2c2 { status = "okay"; vl53l0x@29 { compatible = "st,vl53l0x"; reg = <0x29>; label = "VL53L0X"; }; };
Håkon
thanks for help !
I added an overlay file (actinius_icarus.overlay) in a folder boards.
Whitout success, have you made any other changes ? on the call of device_get_binding ?
I configured for board actinius_icarus_ns (therefore the overlay was in path path/to/zephyr/samples/sensor/vl53l0x/boards/actinius_icarus_ns.overlay)
Remember to re-create your build after adding new changes to the device tree (ie. delete the build and regenerate it).
Merci, ça a fonctionné.Il fallait également créer l'application en mode Workspace et non freestanding.
Thanks !
