ZigBee Groups Handler Bug
I am using nRF Connect SDK 1.7.0 and wrote a light-bulb-device. It has two identical dimmer-endpoints and I reconized there is a bug with the ZCL Groups cluster.
For example:
Adding a group to endpoint number 1 (ZB_ZCL_CMD_GROUPS_ADD_GROUP).
Now asking endpoint number 2 (the other one) for its list of groups
It should return an empty list as the group was added to the first one. (ZB_ZCL_CMD_GROUPS_GET_GROUP_MEMBERSHIP)
-> It actually returns the group of the other endpoint
From what I checked in the library it looks like internal there is only one list of groups for all endpoints together.
The GET_GROUP_MEMBERSHIP command will always return the complete list, without checking the group membership of each endpoint before returning the items.
The Cluster Library says:
4422 If the group count field of the command frame has a value of 0 indicating that the group list field is empty,
4423 the entity SHALL respond with all group identifiers of which the entity is a member.
The "get group membership " command is unicasted to the endpoint. So I would expect the endpoint to be "the entity". And when the endpoint answers its group list it should only list those who the endpoint is part of.
The Library actually sends all groups known to the device - which looks wrong to me (as if the device would be seen as "the entity").
Is there a workaround for this problem?
I know how to override the command handler to implement an own handler for the ZB_ZCL_CMD_GROUPS_GET_GROUP_MEMBERSHIP command, but how to access the list of groups from application-level? Commands like zb_apsme_get_group_membership_request don't seem to be accessible from application? I only find zb_aps_is_endpoint_in_group but checking for 0-0xFFFF is not really an option...
Thanks & best regards,
Alex
  • Hi Alex
    We will look into this, and return to you by the end of Monday
    Sigurd Hellesvik
  • Hi Alex,
    Can you share how you are implementing this, especially how you add the endpoint to a group and how you send the get group membership command? Can you also get a sniffer log of when you send the get group membership command and upload it here as a pcap file?
    When I tested this myself, only the endpoint with a group membership sent a Get Group Membership Response command.
    Marte
  • Hi Marte,
    I have modified a devboard as send-tool for sending packets to my DUT-device.
    Please find Sniffer logs of what I am doing attached. Key for wireshark ist "7a2cc0bb6504e93b7a55ff79d45569f0".
    recommended filter in wireshark: ((!(wpan.frame_type == 0x2)) && !(zbee_aps.type == 0x2)) && !(zbee_nwk.cmd.id == 0x08)
    I think the sniffer log is explaining my problem best:
    Starting with two identical dimmer endpoints (ep10 and ep11):
    - First I verify both are in no group.
    - add group id 1 to ep10
    - add group id 2 to ep10
    - add group id 2 to ep11
    - get group membership of ep10 (sending with group count 0 - means return all groups of the entity)
    -> ep10 has both groups as expected
    - get group membership of ep11 (sending with group count 0 - means return all groups of the entity)
    -> ep11 also has both groups!?? -> BUG!
    - remove the additinal shown group 1 from ep11
    -> ep11 says error that group 1 is not found (on this endpoint)
    - verify group membership with get group membership of ep11 (sending with group count 0 - means return all groups of the entity)
    -> still says both groups are present on this endpoint
    Alex
    Groups_7a2cc0bb6504e93b7a55ff79d45569f0.pcapng
  • Hi Alex,
    Thank you for providing the sniffer log, it was very helpful in seeing the behavior you described. I have been able to confirm this on my side, and I also saw that when groupcasting a command the endpoint that was not part of the group the command was sent to would respond with an ACK to the command.
    I will report this internally to our developers.
    Marte
  • Hi Marte,
    Great when you can reproduce it now. Looking forward to a workaround for this.
    I can change zcl_groups.c to get this fixed but as far as I know this would be "changing the library" which is part of the "certified platform" which would make the certification process complicated?
    Where do I actually find out which files belong to the certified platform and which files may be changed?
    Alex
