app_twi_perform() returns 0x03 == NRF_ERROR_INTERNAL.
Reset board with button does not help.
After Power Cycle can update EEPROM successfully.
Accessing FTM buffer with proprietary smartphone app.
NRF52832 built with nRF SDK 12.3.
So you need to power cycle the DK (which also power cycles the EEPROM, I guess?) in order for it to work?
What happens if you try to initialize the EEPROM twice without power cycling it in between?
If you look at the unmodified twi_master_using_app_twi_pca10040 example from SDK12.3.0, you should see:
static void twi_config(void)
uint32_t err_code;
nrf_drv_twi_config_t const config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
.clear_bus_init = false
APP_TWI_INIT(&m_app_twi, &config, MAX_PENDING_TRANSACTIONS, err_code);
Can you try to change .clear_bus_init = false to .clear_bus_init = true?
See if that helps, and let me know if it doesn't.
Edvin
Hello Edvin,
unfortunately that solution did not work.
The best answer came from ST forum:
https://community.st.com/s/question/0D73W000001MsCn/
Problem was that "it is not possible to write into EEPROM if FTM is activated".
And logical solution was to deactivate FTM before interacting with EEPROM.
Anyway, I appreciate your involvement as a good sign of a great customer support.
