how to get the RRSI of the central device? i am using sdk 17.1.0 and s140 soft device
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
sd_ble_gap_rssi_start(m_conn_handle,1,0);
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, 4);
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_RSSI_CHANGED:
rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
// No implementation needed.
i try to get the rssi of the central device that is my phone but it shows 0xffffcd
  • static void ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    uint32_t err_code;
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt; // ADDED BY ME
    err_code = sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle,BLE_GAP_RSSI_THRESHOLD_INVALID,0); //ADDED BY ME
    APP_ERROR_CHECK(err_code); //ADDED BY ME
    err_code = app_timer_start(my_timer_id,APP_TIMER_TICKS(5000),0); //ADDED BY ME
    } break;
    i am trying to get the rssi value when the device is connected i am getting like below will it be in dbm or need to convert to dbm?
    info> app: RSSI: 198
    <info> app: RSSI: 199
    <info> app: RSSI: 202
    <info> app: RSSI: 201
    <info> app: RSSI: 196
    <info> app: RSSI: 200
    <info> app: RSSI: 198
    <info> app: RSSI: 195
    <info> app: RSSI: 197
    <info> app: RSSI: 191
    <info> app: RSSI: 185
    <info> app: RSSI: 186
    <info> app: RSSI: 188
    <info> app: RSSI: 190
    <info> app: RSSI: 194
    <info> app: RSSI: 193
    <info> app: RSSI: 192
    <info> app: RSSI: 187
    <info> app: RSSI: 183
    <info> app: RSSI: 205
    <info> app: RSSI: 206
    <info> app: RSSI: 203
    <info> app: RSSI: 180
    <info> app: RSSI: 178
    <info> app: RSSI: 181
    What has the value0xffffcd? How do you get the RSSI and which type does your rss variable have, and how do you print/interpret it? The rssi field in the ble_gap_evt_rssi_changed_t struct is a signed 8 bit integer (int8_t).
    I suggest you do something like this, which should give you correct values (something like "<info> app: RSSI: -33" in the log):
                int8_t rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
                NRF_LOG_INFO("RSSI: %d", rssi);
            } break;
    Values are in dBm.
  • static void timeout_handler(void *timeoutpointer)
                uint8_t rssi;
                uint8_t channel;
                uint32_t err_code = sd_ble_gap_rssi_get(m_conn_handle,&rssi,&channel);
    i have initialise the rssi variable as int right?
    No, it is not right. You are using uint8_t, which is unsigned. But the data here is signed, so rssi should be int8_t (not starting with "u"). The channel is uint_t, so that is correct.
  • if i want to know the rrsi of the central device when the device was not connected then how do i get that?
