how to get the RRSI of the central device? i am using sdk 17.1.0 and s140 soft device
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected");
sd_ble_gap_rssi_start(m_conn_handle,1,0);
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, 4);
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_GAP_EVT_RSSI_CHANGED:
rssi = p_ble_evt->evt.gap_evt.params.rssi_changed.rssi;
// No implementation needed.
i try to get the rssi of the central device that is my phone but it shows 0xffffcd
  • Let me try to clarify. To measure RSSI you need to receive a signal from the device you want to measure. As you are a peripheral device and the other is a central there are no advertisement packets. The only packets the central sends to you is when in a connection (starting with the connection indication packet), and if the central performs active scanning (which means that it sends a scan resquest packet, asking for the peripheral to reply with a scan response packet). There are no other situations where the central sends data to you, and thus no other situations where you can measure the RSSI (which by definition is the signal strengt you receive).
