Hello fellow bit jugglers!
We are developing an application for a nRF52805 on a nRF52-DK board, using NCS.
NCS version: 1.7.1
Zephyr version: 2.6.99-ncs1-1 (commit 18e072b03270436fcd58312217fa8f362abb5ccd)
BLE controller: Zephyr
IDE: SEGGER studio
OS: Windows 8
The problem we face is that we can't get dynamic TX power (TX power in dBm selectable during runtime) running under the following conditions:
- use the Zepyhr controller, not the standard Nordic controller (we need to use the Zepyhr controller due to RAM shortage)
- use extended advertising (also a given for our application)
We noted this behaviour in our application, but to demonstrate it with a minimal reproducable example, I modified the sample bluetooth/hci_pwr_ctrl.
The only changes we made to the example were:
The exact changes are attached. (Final files + git patch)
The problem we face is that the extended message appears in the nRF connect app, but the RSSI value does not change significantly (around -46 dBm).
When I change the controller back to Nordic controller (by removing CONFIG_BT_LL_SW_SPLIT=y), the RSSI value steadily decreases, as expected.
I guess the problem must be somewhere inside the Zepyhr controller, but I was not able to trace the calls through the various layers there (Ticker, Mayfly, lll, ...)
Any idea?
Cheers
Pat
/* main.c - Application main entry point */ /* * Copyright (c) 2019 Andrei Stoica * * SPDX-License-Identifier: Apache-2.0 */ #include <zephyr/types.h> #include <stddef.h> #include <sys/printk.h> #include <sys/util.h> #include <sys/byteorder.h> #include <bluetooth/bluetooth.h> #include <bluetooth/hci.h> #include <bluetooth/hci_vs.h> #include <bluetooth/conn.h> #include <bluetooth/uuid.h> #include <bluetooth/gatt.h> #include <bluetooth/services/hrs.h> static struct bt_conn *default_conn; static uint16_t default_conn_handle; static const struct bt_data ad[] = { BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)), BT_DATA_BYTES(BT_DATA_UUID16_ALL, BT_UUID_16_ENCODE(BT_UUID_HRS_VAL)), }; #define ADV_OPTIONS (BT_LE_ADV_OPT_EXT_ADV | \ BT_LE_ADV_OPT_USE_IDENTITY | \ BT_LE_ADV_OPT_USE_NAME | \ BT_LE_ADV_OPT_USE_TX_POWER) #define BT_LE_EXT_ADV_CUSTOM_FAST \ BT_LE_ADV_PARAM(ADV_OPTIONS, \ BT_GAP_ADV_FAST_INT_MIN_2, \ BT_GAP_ADV_FAST_INT_MAX_2, NULL) #define DEVICE_NAME CONFIG_BT_DEVICE_NAME #define DEVICE_NAME_LEN (sizeof(DEVICE_NAME) - 1) #define DEVICE_BEACON_TXPOWER_NUM 8 static struct k_thread pwr_thread_data; static K_THREAD_STACK_DEFINE(pwr_thread_stack, 512); static const int8_t txp[DEVICE_BEACON_TXPOWER_NUM] = {4, 0, -3, -8, -15, -18, -23, -30}; static void read_conn_rssi(uint16_t handle, int8_t *rssi) { struct net_buf *buf, *rsp = NULL; struct bt_hci_cp_read_rssi *cp; struct bt_hci_rp_read_rssi *rp; int err; buf = bt_hci_cmd_create(BT_HCI_OP_READ_RSSI, sizeof(*cp)); if (!buf) { printk("Unable to allocate command buffer\n"); return; } cp = net_buf_add(buf, sizeof(*cp)); cp->handle = sys_cpu_to_le16(handle); err = bt_hci_cmd_send_sync(BT_HCI_OP_READ_RSSI, buf, &rsp); if (err) { uint8_t reason = rsp ? ((struct bt_hci_rp_read_rssi *)rsp->data)->status : 0; printk("Read RSSI err: %d reason 0x%02x\n", err, reason); return; } rp = (void *)rsp->data; *rssi = rp->rssi; net_buf_unref(rsp); } static void set_tx_power(uint8_t handle_type, uint16_t handle, int8_t tx_pwr_lvl) { struct bt_hci_cp_vs_write_tx_power_level *cp; struct bt_hci_rp_vs_write_tx_power_level *rp; struct net_buf *buf, *rsp = NULL; int err; buf = bt_hci_cmd_create(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL, sizeof(*cp)); if (!buf) { printk("Unable to allocate command buffer\n"); return; } cp = net_buf_add(buf, sizeof(*cp)); cp->handle = sys_cpu_to_le16(handle); cp->handle_type = handle_type; cp->tx_power_level = tx_pwr_lvl; err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_WRITE_TX_POWER_LEVEL, buf, &rsp); if (err) { uint8_t reason = rsp ? ((struct bt_hci_rp_vs_write_tx_power_level *) rsp->data)->status : 0; printk("Set Tx power err: %d reason 0x%02x\n", err, reason); return; } rp = (void *)rsp->data; printk("Actual Tx Power: %d\n", rp->selected_tx_power); net_buf_unref(rsp); } static void get_tx_power(uint8_t handle_type, uint16_t handle, int8_t *tx_pwr_lvl) { struct bt_hci_cp_vs_read_tx_power_level *cp; struct bt_hci_rp_vs_read_tx_power_level *rp; struct net_buf *buf, *rsp = NULL; int err; *tx_pwr_lvl = 0xFF; buf = bt_hci_cmd_create(BT_HCI_OP_VS_READ_TX_POWER_LEVEL, sizeof(*cp)); if (!buf) { printk("Unable to allocate command buffer\n"); return; } cp = net_buf_add(buf, sizeof(*cp)); cp->handle = sys_cpu_to_le16(handle); cp->handle_type = handle_type; err = bt_hci_cmd_send_sync(BT_HCI_OP_VS_READ_TX_POWER_LEVEL, buf, &rsp); if (err) { uint8_t reason = rsp ? ((struct bt_hci_rp_vs_read_tx_power_level *) rsp->data)->status : 0; printk("Read Tx power err: %d reason 0x%02x\n", err, reason); return; } rp = (void *)rsp->data; *tx_pwr_lvl = rp->tx_power_level; net_buf_unref(rsp); } static void connected(struct bt_conn *conn, uint8_t err) { char addr[BT_ADDR_LE_STR_LEN]; int8_t txp; int ret; if (err) { printk("Connection failed (err 0x%02x)\n", err); } else { default_conn = bt_conn_ref(conn); ret = bt_hci_get_conn_handle(default_conn, &default_conn_handle); if (ret) { printk("No connection handle (err %d)\n", ret); } else { /* Send first at the default selected power */ bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr)); printk("Connected via connection (%d) at %s\n", default_conn_handle, addr); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, &txp); printk("Connection (%d) - Initial Tx Power = %d\n", default_conn_handle, txp); set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, BT_HCI_VS_LL_TX_POWER_LEVEL_NO_PREF); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, &txp); printk("Connection (%d) - Tx Power = %d\n", default_conn_handle, txp); } } } static void disconnected(struct bt_conn *conn, uint8_t reason) { printk("Disconnected (reason 0x%02x)\n", reason); if (default_conn) { bt_conn_unref(default_conn); default_conn = NULL; } } static struct bt_conn_cb conn_callbacks = { .connected = connected, .disconnected = disconnected, }; static void bt_ready(int err) { static struct bt_le_ext_adv *ptAdv; /* Create a non-connectable, scannable advertising set */ int32_t s32Err = bt_le_ext_adv_create(BT_LE_EXT_ADV_CUSTOM_FAST, NULL, &ptAdv); if (s32Err) { printk("Failed to create advertising set!\n"); return; } s32Err = bt_le_ext_adv_start(ptAdv, BT_LE_EXT_ADV_START_DEFAULT); if (s32Err) { printk("Failed to start advertising (%d)!\n", s32Err); return; } printk("Dynamic Tx power Beacon started\n"); } static void hrs_notify(void) { static uint8_t heartrate = 90U; /* Heartrate measurements simulation */ heartrate++; if (heartrate == 160U) { heartrate = 90U; } bt_hrs_notify(heartrate); } void modulate_tx_power(void *p1, void *p2, void *p3) { int8_t txp_get = 0; uint8_t idx = 0; while (1) { if (!default_conn) { printk("Set Tx power level to %d\n", txp[idx]); set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV, 0, txp[idx]); k_sleep(K_SECONDS(5)); printk("Get Tx power level -> "); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV, 0, &txp_get); printk("TXP = %d\n", txp_get); idx = (idx+1) % DEVICE_BEACON_TXPOWER_NUM; } else { int8_t rssi = 0xFF; int8_t txp_adaptive; idx = 0; read_conn_rssi(default_conn_handle, &rssi); printk("Connected (%d) - RSSI = %d\n", default_conn_handle, rssi); if (rssi > -70) { txp_adaptive = -20; } else if (rssi > -90) { txp_adaptive = -12; } else { txp_adaptive = -4; } printk("Adaptive Tx power selected = %d\n", txp_adaptive); set_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, txp_adaptive); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_CONN, default_conn_handle, &txp_get); printk("Connection (%d) TXP = %d\n", default_conn_handle, txp_get); k_sleep(K_SECONDS(1)); } } } void main(void) { int8_t txp_get = 0xFF; int err; default_conn = NULL; printk("Starting Dynamic Tx Power Beacon Demo\n"); /* Initialize the Bluetooth Subsystem */ err = bt_enable(bt_ready); if (err) { printk("Bluetooth init failed (err %d)\n", err); } printk("Get Tx power level ->"); get_tx_power(BT_HCI_VS_LL_HANDLE_TYPE_ADV, 0, &txp_get); printk("-> default TXP = %d\n", txp_get); bt_conn_cb_register(&conn_callbacks); /* Wait for 5 seconds to give a chance users/testers * to check that default Tx power is indeed the one * selected in Kconfig. */ k_sleep(K_SECONDS(5)); k_thread_create(&pwr_thread_data, pwr_thread_stack, K_THREAD_STACK_SIZEOF(pwr_thread_stack), modulate_tx_power, NULL, NULL, NULL, K_PRIO_COOP(10), 0, K_NO_WAIT); k_thread_name_set(&pwr_thread_data, "DYN TX"); while (1) { hrs_notify(); k_sleep(K_SECONDS(2)); } }
