Temperature code into Light Lightness Server code
Hi
I am using sht85 to detect temperature/humidity in my Light lightness server code
 In the original server code, by pressing 1 or 2 you get to either decrease or increase the lightness level respectively. I modified the code so that when number 3 is pressed, both temperature and humidity will be display in the J-Link
This is the code for button number 3
 if(button_number == 3)
              int32_t temperature, humidity;
               int32_t temp_read, hum_read;
                  char temp_str[5];
                  char hum_str[5];
           int8_t ret = sht3x_measure_blocking_read(SHT3X_I2C_ADDR_DFLT,
                                                 &temperature, &humidity);
               if (ret == STATUS_OK) {
                temp_read = temperature / 1000;
                hum_read = humidity / 1000;
                itoa(temp_read, temp_str,10);
                 itoa(hum_read, hum_str, 10);
          __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Temperature: %d\n", temp_str);
         __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Humidity: %d\n", hum_str);
However, The display in J-Link is not what I had expected
The temperature and Humidity values are extremely high. Is there something I am doing wrong in the code? If so, please advise on what to change. Thank you!
