nrf8240 Signature validation failed during testing
Hi ,
i am using nrf52840 dk board. and using 17.1 sdk for examples code.
i am trying to customize open bootloader code and trying to validate the signature of a input data by using nrf_dfu_validation_signature_check() API.
Note: - i am having my own public and signature data, which i fed to this function.
But i am getting "NRF_DFU_RES_CODE_INVALID_OBJECT" in return from the above API.
Below i attcahed the calling function with input parameters.
static uint8_t m_message[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";
const size_t m_message_len = 36; // Skipping null termination
Regards
  • Hi Einar,
    in this command , these version number will it effect the process or its just the version just assigning here?
    And in application part which hex file i need to pass whether its a bootloader hex file or my application hex file which will run after bootloader?
    Regards
    Rohit Saini
  • Hi Rohit,
    The version numbers for application and bootloader does not matter in itself, other than that downgrade protection ensures that you need to use increasing numbers. So when you set 1, a DFU image which is not higher will not be accepted (this can be adjusted by sdk_config.h macros, though). This data will be programmed to the bootloader settings page and is read whenever there is a DFU procedure. This is just the starting point though. If you update to for instance application version 3, the number in the settings page on the device would then be changed to 3.
    The bl-settings-version is a bit different, and depends on the SDK version of the bootloader. As you use SDK 17.1 it should always be set to 2. This is to match the data structure and content that is used by the bootloader version you use.
    You normally only need to pass the hex file of the application when generating bootloader settings page. If you also want SD boot validation you need to pass the SoftDevice hex file as well.
    Einar
  • Thanks Einar,
    one last thing is the below commands are ok for programming
    1. Erase the entire flash
    nrfjprog.exe --family NRF52 --eraseall
    2.Program the MBR
    nrfjprog --reset --program mbr_nrf52_2.4.1_mbr.hex  --family NRF52 --sectoranduicrerase
    3.Program the Bootloader Settings
    nrfjprog --program settings.hex -f NRF52 -r
    4. Program the Bootloader
    nrfjprog --reset --program open_bootloader_usb_mbr_pca10056.hex --family NRF52 --sectoranduicrerase
    5. Program Blinky App
    nrfjprog --reset --program blinky_pca10056.hex --family NRF52 --sectoranduicrerase
    Regards
    No, these sets of commands are not OK. The specific problem is that the bootloader start address is stored in the UICR, and that is part of the bootloader hex file. When you later program the application with the "--sectoranduicrerase" option, the UICR is deleted again. In this specific case it would be enough to just skip "--sectoranduicrerase" from step 5, but as you start with an erase all there is no need to use this anywhere, so I suggest you remove this option from all the commands.
