Timer operation, uneven delays
Hello everyone, I combined work with a timer and an example from ble_app_aurt pca10040 s132, the problem is that the timer does not work evenly, yes, I know about the low priority of the timer, but this does not explain why delays of 182μs can last for several seconds!
static void timer_init()
    NVIC_SetPriority(TIMER1_IRQn, 2);
	NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;
	NRF_TIMER2->PRESCALER = 1;
	NRF_TIMER2->BITMODE = (TIMER_BITMODE_BITMODE_16Bit << TIMER_BITMODE_BITMODE_Pos);
/**@snippet [Handling the data received over UART] */
	for(;;) {
char str[8];
int p=13;
NRF_TIMER2->TASKS_CLEAR = 1;
NRF_TIMER2->TASKS_START = 1;
    int abc=5;             ///delay check
    abc = abc + 1;
    NRF_TIMER2->TASKS_CAPTURE[0] = 1;
int k;
k = NRF_TIMER2->CC[0];
int f = k;
       sprintf (str, "%d", f);
   uint16_t length = (uint16_t)p;
int x = 5;
        if(x>0)
        {  //Read GPIO
         ble_nus_data_send (&m_nus, &str[0], &length, m_conn_handle);
        else {
        NRF_LOG_INFO("Debug logging for UART over RTT started 888.");
    I see a couple of potential issues with the sparse code you have supplied. First of all, you are not checking the error codes returned by SDK functions such as ble_nus_data_send. I do not think that is the reason as to why you are seeing uneven timer interrupts, but it is in general not a good practice which certainly will spawn other issues later in your development.
    Furthermore it seems that you have an infinite for-loop in your uart_handler. This is also bad practice, because you will never return to the main context, and you will block all equal-to-or-lower priority interrupts in your program.
    Please fix these things, and provide more information / more of the code if this does not resolve your issues.
    Karl
