Hello sir,
I am using the nrf52832 Dev board and try to send the data through custom value update then the following error occurs as ERROR 8 [NRF_ERROR_INVALID_STATE].How to solve the following above error .
Hello sir,
Hi.
Have you debugged your application?
Could you be a little more specific in which function is returning the INVALID_STATE error?
Br,
Joakim
Hello sir,
I have created two services through each one i have been sending the data.Through one services i have been sending the data properly through send_notification() and the function is used as ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value). The data is send through custom value update function and shown in nrfconnect app when i enable the notifications. Through another services i have been tried to send the data using the ble_cus_custom_value_update(ble_cus_t * p_cus, uint8_t custom_value) but have used different instances. I tried to get the data through nrfconnect app when notifications is enabled then the data is not showing in app.when i use the read command then the data is showing properly but enable to get the data through notifications.
In second services also i have enable read,write and notify properly but enable to get the data through notifications but get through read command only through nrfconnect app
Ok, so you were able to solve the issue with the INVALID_STATE error?
Your issue is enabling notifications on two different services?
Br,
Joakim
