maximum amount of data can be sent through ble_lbs service
hello,
 i am using nrf52832 with our customized board and i am trying to send 427 characters string at a time using lbs service but it only accepts 200 characters in single time is there any way to send a 427 character string in single time
//i have changed my lbs c file like this
uint32_t ble_lbs_init(ble_lbs_t * p_lbs, const ble_lbs_init_t * p_lbs_init)
uint32_t err_code;
ble_uuid_t ble_uuid;
ble_add_char_params_t add_char_params;
// Initialize service structure.
p_lbs->led_write_handler = p_lbs_init->led_write_handler;
p_lbs->button_write = p_lbs_init->button_write_handler;
// Add service.
ble_uuid128_t base_uuid = {LBS_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_lbs->uuid_type);
VERIFY_SUCCESS(err_code);
ble_uuid.type = p_lbs->uuid_type;
ble_uuid.uuid = LBS_UUID_SERVICE;
err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY, &ble_uuid, &p_lbs->service_handle);
// Add Button characteristic.
memset(&add_char_params, 0, sizeof(add_char_params));
add_char_params.uuid = LBS_UUID_BUTTON_CHAR;
add_char_params.uuid_type = p_lbs->uuid_type;
add_char_params.init_len = sizeof(uint8_t);
add_char_params.max_len = sizeof(uint8_t)*247;
add_char_params.is_var_len = true;
// add_char_params.char_props.read = 1;
add_char_params.char_props.notify = 1;
add_char_params.char_props.indicate = 1;
// add_char_params.char_props.write = 1;
// add_char_params.read_access = SEC_OPEN;
add_char_params.cccd_write_access = SEC_OPEN;
err_code = characteristic_add(p_lbs->service_handle,
&add_char_params,
&p_lbs->button_char_handles);
if (err_code != NRF_SUCCESS)
return err_code;
// Add LED characteristic.
add_char_params.uuid = LBS_UUID_LED_CHAR;
// add_char_params.char_props.notify = 1;
add_char_params.write_access = SEC_OPEN;
// add_char_params.cccd_write_access = SEC_OPEN;
return characteristic_add(p_lbs->service_handle, &add_char_params, &p_lbs->led_char_handles);
//changes i have done in sdk config
// <i> Requested BLE GAP data length to be negotiated.
#ifndef NRF_SDH_BLE_GAP_DATA_LENGTH
#define NRF_SDH_BLE_GAP_DATA_LENGTH 251
// <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
#ifndef NRF_SDH_BLE_PERIPHERAL_LINK_COUNT
#define NRF_SDH_BLE_PERIPHERAL_LINK_COUNT 1
// <o> NRF_SDH_BLE_CENTRAL_LINK_COUNT - Maximum number of central links.
#ifndef NRF_SDH_BLE_CENTRAL_LINK_COUNT
#define NRF_SDH_BLE_CENTRAL_LINK_COUNT 0
// <o> NRF_SDH_BLE_TOTAL_LINK_COUNT - Total link count.
// <i> Maximum number of total concurrent connections using the default configuration.
#ifndef NRF_SDH_BLE_TOTAL_LINK_COUNT
#define NRF_SDH_BLE_TOTAL_LINK_COUNT 2
// <o> NRF_SDH_BLE_GAP_EVENT_LENGTH - GAP event length.
// <i> The time set aside for this connection on every connection interval in 1.25 ms units.
#ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
#define NRF_SDH_BLE_GAP_EVENT_LENGTH 200
// <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
#ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
// <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
#ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
#define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
thanks and regards
manikandan v
