Is CTS pull-up configuration supported by UART driver of Zephyr for nRF5340 ??
I got the following error if I include cts-pull-up
devicetree error: 'cts-pull-up' appears in /soc/peripheral@50000000/uart@9000 in nrf5340dk_nrf5340_cpuapp.dts.pre.tmp, but is not declared in 'properties:' in /opt/nordic/ncs/v1.7.0/zephyr/dts/bindings/serial/nordic,nrf-uarte.yaml
I look into the
and I can't find cts-pull-up
How can I fix it ??
include: uart-controller.yaml
properties:
reg:
required: true
interrupts:
required: true
tx-pin:
type: int
required: true
description: |
The TX pin to use.
For pins P0.0 through P0.31, use the pin number. For example,
to use P0.16 for TX, set:
tx-pin = <16>;
For pins P1.0 through P1.31, add 32 to the pin number. For
example, to use P1.2 for TX, set:
tx-pin = <34>; /* 32 + 2 */
rx-pin:
type: int
required: false
description: |
The RX pin to use. The pin numbering scheme is the same as the
tx-pin property's.
rts-pin:
type: int
required: false
description: |
The RTS pin to use. The pin numbering scheme is the same as the
tx-pin property's.
cts-pin:
type: int
required: false
description: |
The CTS pin to use. The pin numbering scheme is the same as the
tx-pin property's.
current-speed:
description: |
Initial baud rate setting for UART. Only a fixed set of baud
rates are selectable on these devices.
enum:
- 1200
- 2400
- 4800
- 9600
- 14400
- 19200
- 28800
- 31250
- 38400
- 56000
- 57600
- 76800
- 115200
- 230400
- 250000
- 460800
- 921600
- 1000000
