I'm having some trouble getting a device pointer for the OV7670 Camera. I've ported the OV7725 driver. It appears as if the program exits the driver before setting the I2C address:
I'm pretty sure I'm doing something but not entirely sure where.
sure
&i2c0 {
status = "okay";
ov7670@43 {
compatible = "ovti,ov7670";
label = "ov7670";
reg = <0x43>;
data-gpios = <&gpio0 0 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 1 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 5 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 6 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 7 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 8 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 9 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>,
<&gpio0 10 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
vsync-gpios = < &gpio0 15 (GPIO_PULL_UP | GPIO_ACTIVE_LOW) >;
hsync-gpios = < &gpio0 14 (GPIO_PULL_UP | GPIO_ACTIVE_LOW) >;
pclk-gpios = < &gpio0 13 (GPIO_PULL_UP | GPIO_ACTIVE_LOW) >;
xclk-gpios = < &gpio0 12 (GPIO_PULL_UP | GPIO_ACTIVE_LOW) >;
};description: OV7670 CMOS video sensor
compatible: "ovti,ov7670"
properties:
reset-gpios:
type: phandle-array
required: false
description: |
The RESETn pin is asserted to disable the sensor causing a hard
reset. The sensor receives this as an active-low signal.
data-gpios:
type: phandle-array
required: false
vsync-gpios:
type: phandle-array
required: false
hsync-gpios:
type: phandle-array
required: false
pclk-gpios:
type: phandle-array
required: false
xclk-gpios:
type: phandle-array
required: false
include: i2c-device.yamlI have reviewed your changes and nothing seems to comeout as the culprit for this behavior.
if you have "zephyr_library()" in your CMakeLists.txt file, and check if your driver is properly initialized. You can do this by starting your program in the debug mode to see if the driver exits with no errors.
