OV7670 Camera Driver
I'm having some trouble getting a device pointer for the OV7670 Camera. I've ported the OV7725 driver. It appears as if the program exits the driver before setting the I2C address:
drv_data->i2c = device_get_binding(DT_INST_BUS_LABEL(0));
printk("HERE!!!!!!!!!!!!!!!!!!!\n");
if (drv_data->i2c == NULL) {
LOG_ERR("Failed to get pointer to %s device!",
DT_INST_LABEL(0));
return -EINVAL;
drv_data->i2c_addr = DT_INST_REG_ADDR(0);
I'm pretty sure I'm doing something but not entirely sure where.
    We do not have this camera sensor  So it is hard to test anything, but based on your description, it seems like you are missing KConfig settings being enabled.
    What kind of trouble are you seeing? is it a compilation error or other run time errors?
  • I havce a very basic application where I'm trying to get a device pointer to the camera using device_get_binding() but it's not working. When I try to print out DT_INST_REG_ADDR(0) I'm getting this error missinglog_strdup(). Does that mean it isn't picking the I2C address from my board overay?
  • Yes it seems that your I2C address that you mentioned in the device tree does not seem to be visible to your project. Check if those settings in the board overlay are shielded by some other config settings that you missed to enable.
  • Oh I forgot I was using CONFIG_I2C=y instead of CONFIG_I2C_0=y to debug. The runtime error that the main.c is returning dev=null after  device_get_binding("ov7670")
    const struct device *dev = device_get_binding("ov7670");
    if (dev == NULL) {
    printk("Error: Could not get ov7670 device binding\n");
    return 0;
    This is the camera init function
    static int ov7670_init_0(const struct device *dev)
    	struct ov7670_data *drv_data = dev->data;
        printk("HERE!!!!!!! %s !!!!!!!!!!!!\n",DT_INST_REG_ADDR(0));
    			DT_INST_LABEL(0));
    		return -EINVAL;
        drv_data->i2c_addr = device_get_binding(DT_INST_REG_ADDR(0));
    	return ov7670_init(dev);
  • Can you please also attach your dts file so that i get a better picture in how your declared your instances.
