NRF_ERROR_RESOURCES caused by sd_ble_gap_data_length_update()
Hi all,
I am currently developing on the development board nRF52832, SDK16.0 and SD132v7.2.0.
My development board acts as a slave, while an app that tries to connect to it acts as a master. I set following values for the respective parameters:
// <o> NRF_SDH_BLE_GAP_EVENT_LENGTH - GAP event length.
// <i> The time set aside for this connection on every connection interval in 1.25 ms units.
#ifndef NRF_SDH_BLE_GAP_EVENT_LENGTH
#define NRF_SDH_BLE_GAP_EVENT_LENGTH 320
// <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
#ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 185
// <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
#ifndef NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE
#define NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE 1408
So, i tried to establish a connection from the app to my development board and i got the following comment:
<error> nrf_ble_gatt: sd_ble_gap_data_length_update() (request) on connection 0x0 returned NRF_ERROR_RESOURCES.
<error> nrf_ble_gatt: The requested TX/RX packet length is too long by 62/62 octets.
By using the sniffer i also figuredthat the development board does not respond to LL_LENGTH_REQ sent out from the Master.
Based on this i took a deeper look and figured out that this error is caused by the function: data_length_update(uint16_t conn_handle, uint16_t data_length). I modified this function in following way and it seems to work:
static ret_code_t data_length_update(uint16_t conn_handle, uint16_t data_length)
    NRF_LOG_DEBUG("Updating data length to %u on connection 0x%x.",
                  data_length, conn_handle);
    ble_gap_data_length_params_t const dlp =
        .max_rx_octets  = data_length,
        .max_tx_octets  = data_length,
        .max_rx_time_us = BLE_GAP_DATA_LENGTH_AUTO,
        .max_tx_time_us = BLE_GAP_DATA_LENGTH_AUTO,
    ble_gap_data_length_params_t updated_dlp = {0};
    ble_gap_data_length_limitation_t dll = {0};
    ret_code_t err_code = sd_ble_gap_data_length_update(conn_handle, &dlp, &dll);
    if( err_code == NRF_ERROR_RESOURCES)
      updated_dlp.max_rx_octets = dlp.max_rx_octets - dll.rx_payload_limited_octets;
      updated_dlp.max_rx_octets = dlp.max_tx_octets - dll.tx_payload_limited_octets;
      updated_dlp.max_rx_time_us = BLE_GAP_DATA_LENGTH_AUTO;
      updated_dlp.max_tx_time_us = BLE_GAP_DATA_LENGTH_AUTO;
      err_code = sd_ble_gap_data_length_update(conn_handle, &updated_dlp, &dll);
    if (err_code != NRF_SUCCESS)
        NRF_LOG_ERROR("sd_ble_gap_data_length_update() (request) on connection 0x%x returned %s.",
                      conn_handle, nrf_strerror_get(err_code));
        if (   (dll.tx_payload_limited_octets != 0)
            || (dll.rx_payload_limited_octets != 0))
            NRF_LOG_ERROR("The requested TX/RX packet length is too long by %u/%u octets.",
                          dll.tx_payload_limited_octets, dll.rx_payload_limited_octets);
        if (dll.tx_rx_time_limited_us != 0)
            NRF_LOG_ERROR("The requested combination of TX and RX packet lengths "
                          "is too long by %u microseconds.",
                          dll.tx_rx_time_limited_us);
    return err_code;
So i basically added a new variable (ble_gap_data_length_limitation_t dll = {0};), adjusted max_rx_octets and max_tx_octets and passed it as parameter for sd_ble_gap_data_length_update() function. My development board is responding now with LL_LENGTH_RSP and the adjusted RX and TX octets. Based on the Figure in Data Length Upate Procedure i would expect that the development board replies with LL_LENGTH_REQ:
Did i misunderstood somethink and is the way how i implemented it correct or is there a better solution available?
Thanks in advace.
BR,
Karl
  • Hi Karl
    What is the NRF_SDH_BLE_GAP_DATA_LENGTH parameter set to in your sdk_config.h file?
    Best regards
    Torbjørn
  • Hi Torbjørn,
    thanks for your response. NRF_SDH_BLE_GAP_DATA_LENGTH is currently set to 251, so to the maximum value.
    BR,
    Karl
  • Hi Karl
    On second thought I guess it is the NRF_SDH_BLE_GATT_MAX_MTU_SIZE parameter that is too low here, and the peer device is requesting a larger value.
    Can you show me the code you use to initialize the nrf_ble_gatt module?
    Normally you would tell this module how large MTU you can accept, like in this excerpt from the ble_app_uart example:
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        ret_code_t err_code;
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    Then the nrf_ble_gatt module should take care of the rest.
    Best regards
    Torbjørn
  • Hi Torbjørn,
    that is the function that initializes the GATT module:
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
      ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    The reason we reduced NRF_SDH_BLE_GATT_MAX_MTU_SIZE to 185 is to save RAM memory.
    Can't you agree on the smaller MTU size with the peer? Not sure, but I think I read somewhere that an MTU size agreement is made based on the smaller MTU size of one of the participants?
    Based on the figure send above i think it should be possible to find an agreement, am i right?
    Karl
  • Hi Karl
    It should be possible to negotiate a smaller MTU size, yes, but you need to configure the GATT library with your desired MTU size.
    Can you try to add the nrf_ble_gatt_att_mtu_periph_set(..) function call, as I showed in my snippet below, to your gatt_init() implementation?
    Best regards
    Torbjørn
