nRF Connect Programmer v2.0.1 hangs device if "Auto read memory" checked or "Read" button is pressed
I found the following problem with Programmer v2.0.1, using either a Nordic DK or a Segger J-Trace as the programming device (on Mac OS 11.6, and with nRF Connect 3.9.1):
With "Auto read memory" checked:
  • Load hex file
  • Erase & write
  • Device resets after programming, but after reading the device appears to paused like it hit a breakpoint
  • The target device (nRF52833) is still in a strange state even after closing the programming device, or exiting the Programmer altogether
  • Only manually resetting or power cycling the target device will bring it back to life
The same thing happens if I simply open the programming device (Nordic DK or J-Trace) with the "Auto read memory" checked.
With "Auto read memory" unchecked and the Nordic DK used as a programmer:
  • Programming works, the target chip is reset and it runs normally
  • Strangely, the target memory appears to be read automatically after programming, even though "Auto read memory" is unchecked.  The target memory map is updated.  (Is this showing based on what was just programmed rather than from a manual read?  This is new functionality, if so.)
  • However, manual reads by pushing the Read button cause the processor to lock up in the same way as when "Auto read memory" is checked.  Like above, the only way to recover is to cycle power, manually reset on the target board, or to reprogram with "Auto read memory" unchecked and make sure not to press the Read button.
This may be a separate issue, but the Reset button seems to always be disabled, so that isn't an option.
It appears there is something wrong with the reads initiated by the Read button, or by "Auto read memory".
    I have forwarded this to the developers, and they are looking into it. I will get back to you when I have an update.
    Marte
    I just want to update you on the progress of this.
    According to the developers this is not a bug, but more of a user experience (UX) design decision. However, they understand that this might cause confusion, as this differs from how the Programmer worked before. Therefore, they are working on adding a checkbox setting similar to "Auto read memory", and checking that box will make the Programmer work similarly to what it did in nRF Connect for Desktop v3.7 and earlier.
    Additionally, the issue with the Reset button is a bug, and they are working on fixing this.
    I do not have a time frame for when this will be fixed and implemented, but they are currently working on it, so hopefully soon.
    Marte
    Programmer v2.2.0 is now released with these added features and fixes.
    Marte
