peripheral_dis logs:
SDK Environment: nRF Connect SDK v1.7.1
Target: Decawave DWM1001-DEV. This uses the nRF52832
If I add CONFIG_LOG=y to "prj.conf" in the zephyr sample peripheral_dis, when run I get the following:
** Booting Zephyr OS build v2.6.99-ncs1-1  ***
[00:00:00.000,366] <inf> sdc_hci_driver: SoftDevice Controller build revision:
                                         3f 47 70 8e 81 95 4e 86  9d d3 a2 95 88 f6 30 0a |?Gp...N. ......0.
                                         7f 53 49 fd                                      |.SI.
[00:00:00.002,746] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.005,371] <err> bt_gatt: Failed to save Database Hash (err -2)
Bluetooth initialized
Advertising successfully started
Why is "<err> bt_gatt: Failed to save Database Hash (err -2)" being logged?
I have attached the complete project.
I initially built this with west build -b decawave_dwm1001_dev2 -d build2 -- -DBOARD_ROOT=\ncs\myapps\peripheral_dis_test
peripheral_dis_test.zip
    Sorry for the delay. From the team:
    This error will not affect real-world applications.
    The source of the error is the use of CONFIG_SETTINGS_NONE=y in prj.conf. Selecting this causes the settings subsystem to return an error when attempting to write settings. The Bluetooth Host is logging this error. `CONFIG_LOG=y` simply enables printing this error. A real-world application would not use CONFIG_SETTINGS_NONE=y.
    However, we should not allow an error to occur in our samples. Possible resolutions:
    • We could make CONFIG_SETTINGS_NONE black hole the write and return success.
    • Use a real Settings back end in the sample. This may be the better option since CONFIG_SETTINGS_NONE is an undocumented feature.
    -Amanda
  • Thanks, now I know where the error is coming from.
    I would like to think that I could start building a real-world application using a sample as a starting point. Based on this I would much prefer the second option. Although I do recognize the aim to keep samples as simple as possible.
  • Referring to Persistent storage
    Would this seem reasonable for "prj.conf"
    CONFIG_BT=y
    CONFIG_BT_PERIPHERAL=y
    CONFIG_BT_DIS=y
    CONFIG_BT_DIS_PNP=n
    CONFIG_BT_DIS_MODEL="Zephyr Model"
    CONFIG_BT_DIS_MANUF="Zephyr"
    CONFIG_BT_DIS_SERIAL_NUMBER=y
    CONFIG_BT_DIS_FW_REV=y
    CONFIG_BT_DIS_HW_REV=y
    CONFIG_BT_DIS_SW_REV=y
    CONFIG_BT_DIS_SERIAL_NUMBER_STR="Zephyr Serial"
    CONFIG_BT_DIS_FW_REV_STR="Zephyr Firmware"
    CONFIG_BT_DIS_HW_REV_STR="Zephyr Hardware"
    CONFIG_BT_DIS_SW_REV_STR="Zephyr Software"
    CONFIG_BT_DEVICE_NAME="DIS peripheral"
    # Below is setup to let DIS information be read from settings
    CONFIG_SETTINGS_RUNTIME=y
    CONFIG_BT_SETTINGS=y
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_FLASH_MAP=y
    CONFIG_NVS=y
    CONFIG_SETTINGS=y
    CONFIG_BT_DIS_SETTINGS=y
    CONFIG_BT_DIS_STR_MAX=21
    CONFIG_DEBUG_THREAD_INFO=y
    CONFIG_LOG=y
    Does anything else need to change? The sample peripheral_dis already calls settings_load()
  • Looks fine from my side. Let me know if you have any issues regarding that.
    -Amanda
