The data rate is very low when I using the bootloader
I using the application download the update firmware, and using the bootloader erase and write the firmware to flash. And I changed the bootloader code, remove all the BLE related codes, and the bootloader just check if need update the firmware, if not it will start the application. I meet a problem now: the firmware will finish the transfer in 4 minutes if I using the application only, but it will using 25 minutes if I using the bootloader launch the application.
I think I made mistake, how can I fix it? Thanks.
