Example code to write to UICR
I am trying to store data to the UICR using SDK16, mesh SDK 4.2.0 and the nRF52840 chip.
I want to write to the UICR once on runtime and never again. To avoid messing with the softdevice, I am trying to write to the UICR before calling ble_stack_init() and after __LOG_INIT to get logs working.
This is the code:
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
uint32_t * consumer0 = (uint32_t *) 0x10001080;
*consumer0 = 0x00000005;
NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "%d\n", *consumer0);
NVIC_SystemReset();
So we put the NVMC in Write enable, wait for it to be ready, write to consumer0, put it in Read enable, wait for it to be ready and reset the device. I can see 5 logged to Segger console.
Then I comment what I don't need:
//NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen;
//while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
//*consumer0 = 0x00000005;
//NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren;
//NVIC_SystemReset();
And I see -1 logged to Segger console, meaning the flash still has the 0xFFFF on that position. I can confirm it on Segger Memory explorer that 10001080 is never filled with the data I wanted. Am I doing something wrong?
  • Thank you Thorsrud.
    It is all clear now.
    If you are using the newest revision ICs, you need to recover first with for instance nrfjprog: nrfjprog --recover. This will disable APPROTECT in the UICR and add a small
    So, for the newest revision ICs, I must perform the firmware flash operation and setting the device id in three  the steps. Step 1 will erase all user flash memory and disables the readback protection mechanism if enabled. Step 2 will write the device id in the UICR customer[0] location. Finally, step 3 will flash the firmware without erasing the UICR. The firmware will then re-enable the readback protection mechanism at boot-up.
    Step 1: Disable APPROTECT:  nrfjprog --recover
    Step 2: Flash device id:            nrfjprog --memwr 0x10001080 --val <device id>
    Step 3: Flash firmware:             nrfjprog --program merged.hex –-sectorerase --reset
    Am I right?
    Kind regards
    Mohamed
  • Yes, that looks correct (note that if you want to debug/program after step 3, it is a requirement that the firmware continues to enable debugger access. That is the default behavior with the SDK though, so it should be good).
    I forgot about this post before, but you can read a bit more in Working with the nRF52 Series' improved APPROTECT if you want more details.
  • Thank you for sharing the link.
    Understood. The three steps mentioned above are for a production environment. We do all development and debugging in Segger Embedded Studio.
    Kind regards
    Mohamed
  • Hi Thorsrud,
    I have installed nrfjprog v10:15 on another machine running Windows 10 64-bits and I am running into this problem,
    C:\>nrfjprog -v
    ERROR: JLinkARM DLL is invalid. Please reinstall latest JLinkARM DLL.
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    C:\>nrfjprog -v --log
    WARNING: Logging is unavailable. nrfjprog.exe does not have write
    WARNING: permission for the log file
    He has installed it twice but he is still facing the same problem.
    Thank you for your help.
    Kind regards
    Mohamed
    I am not immediately able to explain that. Please open a new question/thread for this as it is not directly related to the original topic in this thread.
