I’m trying to use the Power Profiler app v3.2.0 under nRFConnect for Desktop v3.9.1 with a PPK 1 attached to an nRF52 DK board (containing the 52832 processor), but am having trouble trying to get the ble app beacon example code in the nRF5 SDK v17.0.2 to flash the DK board via the Programmer app v2.0.1 such that the Power Profiler app will run. I’ve followed the User Guide for PPK1 v1.1.1.0, cutting the SB9 bridge, plugging the USB cable into the DK board, and setting the Power, DUT, and COM switches on the PPK board to the DK position, then switched the DK Power switch to ON. I’ve also installed JLink during the installation of NRF Connect v3.9.1. It does successfully connect to my Windows 10 Pro PC.
I can run Power Profiler with whatever firmware is installed when I bring that app up. A green LED is solid on the PPK board while a green LED flashes on the DK board. I’m seeing around 400 uA being drawn on average with the graph showing periodic spikes to 7 mA.
I then switch to the Programmer app and drag and drop the hex file for the ble app beacon example after I’ve built it for the project in the pca10040/s132 directory. It shows up at 0x00026000 – 0x0002A3C1, 0x0002A3C4 - 0x0002B08D, and 0x0002B090 – 0x0002B0F3 in the File Memory Layout. When I select and read the nRF52 DK device, the existing application shows up at 0x00010000 - 0x0001000F while the MBR or application appears at 0x00000000 to 0x00007323. Under Device, I click on “Erase & write”. The log indicates the "Device is loaded and ready for further operation".
When I exit the Programmer app, and switch to Power Profiler, then select device nRF52 DK, a message pops up: “Device must be programmed, do you want to proceed?" I thought I had just programmed the device. If I click on Yes, it evidently loads the original default app. If I click on No, eventually a “Failed to start PPK” appears in the log.
If I rebuild the ble app beacon with ble_stack_init(), advertising_init(), and advertising_start() commented out, then flash the hex file to the nRF52 device with the Programmer app, I still get the same popup message about the device needing to be programmed when I run the Power Profiler app, and when I click on Yes, the LED on the DK is still blinking as before with the same plot appearing. It’s as if there is some PPK code missing in the ble app beacon as I’ve built it.
Is there something I must do to the source code under the nRF5 SDK to initialize/configure profiling to get it to run under the Power Profiler app? I realize there is a Profiler library (https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/libraries/others/profiler.html#profiler), but it is apparently integrated into the Zephyr shell. We are not using that, just the nRF5 SDK.
Thanks in advance for your help.
