hello We have a project request nrf51822 radio transmitter -> nrf52832 radio receiver
Hello
nRF5_SDK_11.0.0_89a8197\examples\peripheral\radio\
transmitter\pca10028\arm5_no_packs\transmitter_pca10028.uvprojx
// Radio config
NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_0dBm << RADIO_TXPOWER_TXPOWER_Pos);
NRF_RADIO->FREQUENCY = 7UL; // Frequency bin 7, 2407MHz
NRF_RADIO->MODE = (RADIO_MODE_MODE_Nrf_2Mbit << RADIO_MODE_MODE_Pos);
nRF5_SDK_15.3.0_59ac345\examples\peripheral\radio\receiver\pca10040\blank\arm5_no_packs\receiver_pca10040.uvprojx
// Radio config
Can not communicate with each other
Is it because the device does not support it or is it
my circuit board/software problem?
We mainly want to ask whether communication is possible or not under normal circumstances?
I'm sorry because our project is very confidential
As a last resort
That’s why I'll add trouble directly to you
    nRF51 is on-air compatible with nRF52-series devices.
    Have you started the HFCLK on both ends?
    Have you tried running the radio example on both devices from the same SDK to see how that behaves?
    Håkon
  • Thank you. Wait for me to try more and find out the reasons! Check it out! As long as the equipment designed by your company's chip supports it, it's OK!
  • Hello! I'm sorry!
    I use nrf51822 transmitter -> nrf52832 receiver but still can’t communicate
    Please help me to suggest how to modify it?
    I have confirmed that there is no problem with the clock several times
    nrf51822 16M
    nrf52832 32M
    nRF5_SDK_11.0.0_89a8197\examples\peripheral\radio\transmitter\pca10028\arm5_no_packs\transmitter_pca10028.uvprojx
    nRF5_SDK_11.0.0_89a8197\examples\peripheral\radio\receiver\pca10040\arm5_no_packs\receiver_pca10040.uvprojx
    /**@brief Function for initialization oscillators.
    void clock_initialization()
    /* Start 16 MHz crystal oscillator */
    /* Wait for the external oscillator to start up */
    while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
    // Do nothing.
    /* Start low frequency crystal oscillator for app_timer(used by bsp)*/
    NRF_CLOCK->LFCLKSRC = (CLOCK_LFCLKSRC_SRC_RC << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
    // Do nothing.
    void radio_configure()
    // Radio config
    NRF_RADIO->TXPOWER = (RADIO_TXPOWER_TXPOWER_Pos4dBm << RADIO_TXPOWER_TXPOWER_Pos);
    // Radio address config
    NRF_RADIO->PREFIX0 =
    ((uint32_t)swap_bits(0xC3) << 24) // Prefix byte of address 3 converted to nRF24L series format
    | ((uint32_t)swap_bits(0xC2) << 16) // Prefix byte of address 2 converted to nRF24L series format
    | ((uint32_t)swap_bits(0xC1) << 8) // Prefix byte of address 1 converted to nRF24L series format
    | ((uint32_t)swap_bits(0xC0) << 0); // Prefix byte of address 0 converted to nRF24L series format
    NRF_RADIO->PREFIX1 =
    ((uint32_t)swap_bits(0xC7) << 24) // Prefix byte of address 7 converted to nRF24L series format
    | ((uint32_t)swap_bits(0xC6) << 16) // Prefix byte of address 6 converted to nRF24L series format
    | ((uint32_t)swap_bits(0xC4) << 0); // Prefix byte of address 4 converted to nRF24L series format
    NRF_RADIO->BASE0 = bytewise_bitswap(0x01234567UL); // Base address for prefix 0 converted to nRF24L series format
    NRF_RADIO->BASE1 = bytewise_bitswap(0x89ABCDEFUL); // Base address for prefix 1-7 converted to nRF24L series format
    NRF_RADIO->TXADDRESS = 0x00UL; // Set device address 0 to use when transmitting
    NRF_RADIO->RXADDRESSES = 0x01UL; // Enable device address 0 to use to select which addresses to receive
    // Packet configuration
    NRF_RADIO->PCNF0 = (PACKET_S1_FIELD_SIZE << RADIO_PCNF0_S1LEN_Pos) |
    (PACKET_S0_FIELD_SIZE << RADIO_PCNF0_S0LEN_Pos) |
    (PACKET_LENGTH_FIELD_SIZE << RADIO_PCNF0_LFLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    NRF_RADIO->PCNF1 = (RADIO_PCNF1_WHITEEN_Disabled << RADIO_PCNF1_WHITEEN_Pos) |
    (RADIO_PCNF1_ENDIAN_Big << RADIO_PCNF1_ENDIAN_Pos) |
    (PACKET_BASE_ADDRESS_LENGTH << RADIO_PCNF1_BALEN_Pos) |
    (PACKET_STATIC_LENGTH << RADIO_PCNF1_STATLEN_Pos) |
    (PACKET_PAYLOAD_MAXSIZE << RADIO_PCNF1_MAXLEN_Pos); //lint !e845 "The right argument to operator '|' is certain to be 0"
    // CRC Config
    NRF_RADIO->CRCCNF = (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos); // Number of checksum bits
    if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_Two << RADIO_CRCCNF_LEN_Pos))
    NRF_RADIO->CRCINIT = 0xFFFFUL; // Initial value
    NRF_RADIO->CRCPOLY = 0x11021UL; // CRC poly: x^16+x^12^x^5+1
    else if ((NRF_RADIO->CRCCNF & RADIO_CRCCNF_LEN_Msk) == (RADIO_CRCCNF_LEN_One << RADIO_CRCCNF_LEN_Pos))
    NRF_RADIO->CRCINIT = 0xFFUL; // Initial value
    NRF_RADIO->CRCPOLY = 0x107UL; // CRC poly: x^8+x^2^x^1+1
  • Hello
    Trouble you again
    I can receive the data in the test now!
    But only the first few bytes can be received!
    #define PACKET_BASE_ADDRESS_LENGTH (4UL) //!< Packet base address length field size in bytes
    #define PACKET_STATIC_LENGTH (10UL) //!< Packet static length in bytes
    //#define PACKET_STATIC_LENGTH (200UL) // TEST Can only receive 50 bytes
    #define PACKET_PAYLOAD_MAXSIZE (PACKET_STATIC_LENGTH) //!< Packet payload maximum size in bytes
    //====================transmitter=======================//
    uint32_t packet[Count]={0};
    uint32_t Count=0;
    for(Count=0;Count < 10 ; Count++)
    packet[Count] = Count+1;
    packet
    [ 0 ] | 1
    [ 1 ] | 2
    [ 2 ] | 3
    [ 3 ] | 4
    [ 4 ] | 5
    [ 5 ] | 6
    [ 6 ] | 7
    [ 7 ] | 8
    [ 8 ] | 9
    [ 9 ] | 10
    //====================receiver=======================//
    but
    nrf52832 receiver
    packet
    [ 0 ]   1
    [ 1 ]   2
    [ 2 ]   3
    [ 3 ]   0
    [ 4 ]   0
    [ 5 ]   0
    [ 6 ]   0
    [ 7 ]   0
    [ 8 ]   0
    [ 9 ]   0
