nRF52810 passkey entry
Hi Sir/Miss,
I try to implement static passkey in my project. Which is using nRF52810.
The SDK version is 17.0.2.
Softdevice is S112.
My project is based to develop on NUS.
I want to use central device to enter passkey to do pairing and bonding.
It's just like ble_app_gls example.
I refer ble_app_template example to add peer_manager and fds in project.
Reference this to do it.
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  1                                           /**< Man In The Middle protection required (applicable when display module is detected). */
#define SEC_PARAM_LESC                  0//1                                           /**< LE Secure Connections enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_DISPLAY_ONLY                /**< Display I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
And, add setup static passkey code between ble_stack_init() and advertising_start()
When I use dongle to connect nrf52810 in nRF connect, it doesn't pop up passkey entry window on it. It's connected directly.
It's different with glucose example.
How do I set it up?
Thank you.
    You should also increase the security level on your service characteristics to make pairing/bonding required. The NUS service characteristics are set to "SEC_OPEN" by default, which means the client can access them without securing the connecting first.
    The security level can be set to 'SEC_MITM' when passkey pairing is supported.
    For protection against passive eavesdropping (from a BT sniffer) you should also consider enabling the LESC bit. This require that you integrate the neccessary crypto libraries as in the ble_app_gls example and call the nrf_ble_lesc_request_handler() function from your main loop.
    Vidar
    Thank you for your reply.
    There are still few questions about your tips.
    1.  I changed access to SEC_MITM in your yellow remark. After using nRF connect, it can't access these characteristics directly. Because it doesn't display passkey entry window. Does it not work in passkey?
      void gap_params_init(uint8_t *dev_name, uint8_t len)
          uint32_t                err_code;
                                                dev_name,
                                                len);
          // static passkey
          ble_opt_t ble_opt;
          uint8_t passkey[] = "123456";
          ble_opt.gap_opt.passkey.p_passkey = passkey;
          err_code = sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &ble_opt);
    2. Do you mean when device enables MITM which should also enable crypto function to get full protection?
    3. I try to import below file to project which source is reference glucose example.
             add nrf_rng.c
            But, IDE displays two errors. Does it mean I import wrong file to cause RAM size not enough?
    1. Please make sure you are not handling the following events in main.c::ble_event_handler():
     - BLE_GAP_EVT_SEC_PARAMS_REQUEST
     - BLE_GATTS_EVT_SYS_ATTR_MISSING
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
    #if !PEER_MANAGER_ENABLED
                // Pairing not supported
    #endif // !PEER_MANAGER_ENABLED
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    The peer manager is responsible for handling these events when enabled.
    2. Yes. The encryption keys are sent on-air in cleartext when you use legacy pairing. This means that a BT sniffer can fetch the encryption key if it's listening during key exchange.
    3. Yes, it looks like you have run out of RAM. Maybe you are including the wrong crypto libraries. I suggest you use the ble_app_hrs/pca10040e project as a reference for which crypto related configuration settings and source files to use for this chip variant.
    Vidar
    1. In my project, I add #if !PEER_MANAGER_ENABLED and #endif between BLE_GAP_EVT_SEC_PARAMS_REQUEST and BLE_GATTS_EVT_SYS_ATTR_MISSING in main.c. The nRF connect still can't pop up passkey entry window. I also import these files and modify on ble_app_uart example (PCA10040e). The result is same. Please help to solve it. Thank you.
     * Copyright (c) 2014 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "fds.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SEC_PARAM_LESC                  1                                           /**< LE Secure Connections enabled. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static pm_peer_id_t m_peer_to_be_deleted = PM_PEER_ID_INVALID;
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        // static passkey
        ble_opt_t ble_opt;
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        ret_code_t err_code;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_disconnect_on_sec_failure(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
            case PM_EVT_CONN_SEC_SUCCEEDED:
                pm_conn_sec_status_t conn_sec_status;
                // Check if the link is authenticated (meaning at least MITM).
                err_code = pm_conn_sec_status_get(p_evt->conn_handle, &conn_sec_status);
                if (conn_sec_status.mitm_protected)
                    NRF_LOG_INFO("Link secured. Role: %d. conn_handle: %d, Procedure: %d",
                                 ble_conn_state_role(p_evt->conn_handle),
                                 p_evt->conn_handle,
                                 p_evt->params.conn_sec_succeeded.procedure);
                    // The peer did not use MITM, disconnect.
                    NRF_LOG_INFO("Collector did not use MITM, disconnecting");
                    err_code = pm_peer_id_get(m_conn_handle, &m_peer_to_be_deleted);
                    err_code = sd_ble_gap_disconnect(m_conn_handle,
            } break;
            case PM_EVT_CONN_SEC_FAILED:
                //advertising_start(false);
    void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            } break;
    #if PEER_MANAGER_ENABLED
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        advertising_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    23271.sdk_config.h
     * Copyright (c) 2012 - 2020, Nordic Semiconductor ASA
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(BLE_NUS)
    #include "ble.h"
    #include "ble_srv_common.h"
    #define NRF_LOG_MODULE_NAME ble_nus
    #if BLE_NUS_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       BLE_NUS_CONFIG_LOG_LEVEL
    #define NRF_LOG_INFO_COLOR  BLE_NUS_CONFIG_INFO_COLOR
    #define NRF_LOG_DEBUG_COLOR BLE_NUS_CONFIG_DEBUG_COLOR
    #else // BLE_NUS_CONFIG_LOG_ENABLED
    #define NRF_LOG_LEVEL       0
    #endif // BLE_NUS_CONFIG_LOG_ENABLED
    NRF_LOG_MODULE_REGISTER();
    #define BLE_UUID_NUS_TX_CHARACTERISTIC 0x0003               /**< The UUID of the TX Characteristic. */
    #define BLE_UUID_NUS_RX_CHARACTERISTIC 0x0002               /**< The UUID of the RX Characteristic. */
    #define BLE_NUS_MAX_RX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the RX Characteristic (in bytes). */
    #define BLE_NUS_MAX_TX_CHAR_LEN        BLE_NUS_MAX_DATA_LEN /**< Maximum length of the TX Characteristic (in bytes). */
    #define NUS_BASE_UUID                  {{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}} /**< Used vendor specific UUID. */
    /**@brief Function for handling the @ref BLE_GAP_EVT_CONNECTED event from the SoftDevice.
     * @param[in] p_nus     Nordic UART Service structure.
     * @param[in] p_ble_evt Pointer to the event received from BLE stack.
    static void on_connect(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_nus_evt_t              evt;
        ble_gatts_value_t          gatts_val;
        uint8_t                    cccd_value[2];
        ble_nus_client_context_t * p_client = NULL;
        err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage,
                                     p_ble_evt->evt.gap_evt.conn_handle,
                                     (void *) &p_client);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("Link context for 0x%02X connection handle could not be fetched.",
                          p_ble_evt->evt.gap_evt.conn_handle);
        /* Check the hosts CCCD value to inform of readiness to send data using the RX characteristic */
        memset(&gatts_val, 0, sizeof(ble_gatts_value_t));
        gatts_val.p_value = cccd_value;
        gatts_val.len     = sizeof(cccd_value);
        gatts_val.offset  = 0;
        err_code = sd_ble_gatts_value_get(p_ble_evt->evt.gap_evt.conn_handle,
                                          p_nus->tx_handles.cccd_handle,
                                          &gatts_val);
        if ((err_code == NRF_SUCCESS)     &&
            (p_nus->data_handler != NULL) &&
            ble_srv_is_notification_enabled(gatts_val.p_value))
            if (p_client != NULL)
                p_client->is_notification_enabled = true;
            memset(&evt, 0, sizeof(ble_nus_evt_t));
            evt.type        = BLE_NUS_EVT_COMM_STARTED;
            evt.p_nus       = p_nus;
            evt.conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
            evt.p_link_ctx  = p_client;
            p_nus->data_handler(&evt);
    /**@brief Function for handling the @ref BLE_GATTS_EVT_WRITE event from the SoftDevice.
    static void on_write(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_nus_evt_t                 evt;
        ble_nus_client_context_t    * p_client;
        ble_gatts_evt_write_t const * p_evt_write = &p_ble_evt->evt.gatts_evt.params.write;
                                     p_ble_evt->evt.gatts_evt.conn_handle,
                          p_ble_evt->evt.gatts_evt.conn_handle);
        evt.p_nus       = p_nus;
        evt.conn_handle = p_ble_evt->evt.gatts_evt.conn_handle;
        if ((p_evt_write->handle == p_nus->tx_handles.cccd_handle) &&
            (p_evt_write->len == 2))
                if (ble_srv_is_notification_enabled(p_evt_write->data))
                    p_client->is_notification_enabled = false;
                    evt.type                          = BLE_NUS_EVT_COMM_STOPPED;
                if (p_nus->data_handler != NULL)
        else if ((p_evt_write->handle == p_nus->rx_handles.value_handle) &&
                 (p_nus->data_handler != NULL))
            evt.type                  = BLE_NUS_EVT_RX_DATA;
            evt.params.rx_data.p_data = p_evt_write->data;
            evt.params.rx_data.length = p_evt_write->len;
            // Do Nothing. This event is not relevant for this service.
    /**@brief Function for handling the @ref BLE_GATTS_EVT_HVN_TX_COMPLETE event from the SoftDevice.
    static void on_hvx_tx_complete(ble_nus_t * p_nus, ble_evt_t const * p_ble_evt)
        ble_nus_evt_t              evt;
            return;
        if ((p_client->is_notification_enabled) && (p_nus->data_handler != NULL))
            evt.type        = BLE_NUS_EVT_TX_RDY;
            evt.p_nus       = p_nus;
    void ble_nus_on_ble_evt(ble_evt_t const * p_ble_evt, void * p_context)
        if ((p_context == NULL) || (p_ble_evt == NULL))
            return;
        ble_nus_t * p_nus = (ble_nus_t *)p_context;
                on_connect(p_nus, p_ble_evt);
            case BLE_GATTS_EVT_WRITE:
                on_write(p_nus, p_ble_evt);
            case BLE_GATTS_EVT_HVN_TX_COMPLETE:
                on_hvx_tx_complete(p_nus, p_ble_evt);
    uint32_t ble_nus_init(ble_nus_t * p_nus, ble_nus_init_t const * p_nus_init)
        ble_uuid_t            ble_uuid;
        ble_uuid128_t         nus_base_uuid = NUS_BASE_UUID;
        ble_add_char_params_t add_char_params;
        VERIFY_PARAM_NOT_NULL(p_nus);
        VERIFY_PARAM_NOT_NULL(p_nus_init);
        // Initialize the service structure.
        p_nus->data_handler = p_nus_init->data_handler;
        /**@snippet [Adding proprietary Service to the SoftDevice] */
        // Add a custom base UUID.
        err_code = sd_ble_uuid_vs_add(&nus_base_uuid, &p_nus->uuid_type);
        VERIFY_SUCCESS(err_code);
        ble_uuid.type = p_nus->uuid_type;
        ble_uuid.uuid = BLE_UUID_NUS_SERVICE;
        // Add the service.
        err_code = sd_ble_gatts_service_add(BLE_GATTS_SRVC_TYPE_PRIMARY,
                                            &ble_uuid,
                                            &p_nus->service_handle);
        // Add the RX Characteristic.
        memset(&add_char_params, 0, sizeof(add_char_params));
        add_char_params.uuid                     = BLE_UUID_NUS_RX_CHARACTERISTIC;
        add_char_params.uuid_type                = p_nus->uuid_type;
        add_char_params.max_len                  = BLE_NUS_MAX_RX_CHAR_LEN;
        add_char_params.init_len                 = sizeof(uint8_t);
        add_char_params.is_var_len               = true;
        add_char_params.char_props.write         = 1;
        add_char_params.char_props.write_wo_resp = 1;
        add_char_params.read_access  = SEC_MITM;
        add_char_params.write_access = SEC_MITM;
        err_code = characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->rx_handles);
            return err_code;
        // Add the TX Characteristic.
        /**@snippet [Adding proprietary characteristic to the SoftDevice] */
        add_char_params.uuid              = BLE_UUID_NUS_TX_CHARACTERISTIC;
        add_char_params.max_len           = BLE_NUS_MAX_TX_CHAR_LEN;
        add_char_params.char_props.notify = 1;
        add_char_params.cccd_write_access = SEC_MITM;
        return characteristic_add(p_nus->service_handle, &add_char_params, &p_nus->tx_handles);
    uint32_t ble_nus_data_send(ble_nus_t * p_nus,
                               uint8_t   * p_data,
                               uint16_t  * p_length,
                               uint16_t    conn_handle)
        ble_gatts_hvx_params_t     hvx_params;
        err_code = blcm_link_ctx_get(p_nus->p_link_ctx_storage, conn_handle, (void *) &p_client);
        if ((conn_handle == BLE_CONN_HANDLE_INVALID) || (p_client == NULL))
            return NRF_ERROR_NOT_FOUND;
        if (!p_client->is_notification_enabled)
        if (*p_length > BLE_NUS_MAX_DATA_LEN)
            return NRF_ERROR_INVALID_PARAM;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_nus->tx_handles.value_handle;
        hvx_params.p_data = p_data;
        hvx_params.p_len  = p_length;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        return sd_ble_gatts_hvx(conn_handle, &hvx_params);
    #endif // NRF_MODULE_ENABLED(BLE_NUS)
    Are you able to share the full project so I can try to debug it here?
