how to set the duty cycle in pwm?
how to set the sequence values in pwm driver library?
* Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup pwm_example_main main.c
* @ingroup pwm_example
* @brief PWM Example Application main file.
* This file contains the source code for a sample application using PWM.
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "nrf_drv_clock.h"
#include "nrf_delay.h"
#define OUTPUT_PIN LED_1
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
// Declare variables holding PWM sequence values. In this example only one channel is used
nrf_pwm_values_individual_t seq_values[] = {0, 0, 0, 0};
nrf_pwm_sequence_t const seq =
.values.p_individual = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
// Set duty cycle between 0 and 100%
void pwm_update_duty_cycle(uint8_t duty_cycle)
// Check if value is outside of range. If so, set to 100%
if(duty_cycle >= 100)
seq_values->channel_0 = 100;
seq_values->channel_0 = duty_cycle;
nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
static void pwm_init(void)
nrf_drv_pwm_config_t const config0 =
.output_pins =
OUTPUT_PIN, // channel 0
NRF_DRV_PWM_PIN_NOT_USED, // channel 1
NRF_DRV_PWM_PIN_NOT_USED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED, // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.base_clock = NRF_PWM_CLK_1MHz,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 1000,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
// Init PWM without error handler
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
static void Low_freq_clk(void)
ret_code_t err_code = nrf_drv_clock_init();
// Start clock for accurate frequencies
// Wait for clock to start
while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
// Low_freq_clk();
pwm_init();
pwm_update_duty_cycle(500);
for (;;)
/* for(int i = 0; i <= 100; i++)
nrf_delay_ms(10);
pwm_update_duty_cycle(i);
// pwm_update_duty_cycle(50);*/
whe i try to update the duty cycle to 50% for the above code but duty cyle was not updated?
/** @file
#include <stdio.h>
#include <string.h>
#include "boards.h"
#include "bsp.h"
.repeats = 0,
.end_delay = 0
if(duty_cycle >= 500)
seq_values->channel_0 = 500;
.output_pins =
.base_clock = NRF_PWM_CLK_500kHz,
.top_value = 500,
// Low_freq_clk();
pwm_init();
pwm_update_duty_cycle(300);
for (;;)
nrf_delay_ms(10);
i want to generate the pwm of 1khz and i want to set the duty cycle to 40% i have made changes to the code but duty cycle was not updated properly?
/** @file
#include <stdio.h>
#include <string.h>
#include "boards.h"
#include "bsp.h"
.repeats = 0,
.end_delay = 0
.output_pins =
.top_value = 100,
// Low_freq_clk();
pwm_init();
for (;;)
nrf_delay_ms(10);
if i change the top value to get 1khz pwm wave and when i try to change the duty cycle was not updated properly?
I would like to create 6 PWM signals with different duty cycles and the same frequency (20kHz) with pwm library is it possible?
Hi
Did you figure out the problems of setting the right values?
Essentially you need to set values between 0 - COUNTERTOP, and then the duty cycle is set as the value you set divided by COUNTERTOP.
As an example, if you have a COUNTERTOP value of 10000 and set a value of 2000 you should get a duty cycle of 20%.
venkatesha kj said:I would like to create 6 PWM signals with different duty cycles and the same frequency (20kHz) with pwm library is it possible?
Yes, this is possible, but since each PWM controller can only control 4 outputs you need to enable two different PWM controllers to support 6 outputs.
Essentially you need to create one more instance type, and use an index other than 0, like this for instance:
// Create a second PWM instance to allow 2 additional PWM channels (for a total of 6) static nrf_drv_pwm_t m_pwm1 = NRF_DRV_PWM_INSTANCE(1);
Best regards
Torbjørn
Hi
Best regards
Torbjørn
