how to set the duty cycle in pwm?
how to set the sequence values in pwm driver library?
A COUNTERTOP value smaller
than the compare setting will result in a state where no PWM edges are generated this is true . but i am having doubt that COUNTERTOP value is used to set the duty cycle right?
Hi
Did you figure out the problems of setting the right values?
Essentially you need to set values between 0 - COUNTERTOP, and then the duty cycle is set as the value you set divided by COUNTERTOP.
As an example, if you have a COUNTERTOP value of 10000 and set a value of 2000 you should get a duty cycle of 20%.
venkatesha kj said:I would like to create 6 PWM signals with different duty cycles and the same frequency (20kHz) with pwm library is it possible?
Yes, this is possible, but since each PWM controller can only control 4 outputs you need to enable two different PWM controllers to support 6 outputs.
Essentially you need to create one more instance type, and use an index other than 0, like this for instance:
// Create a second PWM instance to allow 2 additional PWM channels (for a total of 6) static nrf_drv_pwm_t m_pwm1 = NRF_DRV_PWM_INSTANCE(1);
Best regards
Torbjørn
