UART communication using nRH52840
  1. I am a newbee to nrf 52840..I saw lot of documents and got confused on where to start ..indly guide me on this
  2. we are trying nrf52840 dev kit as we are using nrf52840 in our custom board
  3. Let me know how can start for UART communciation using this dev Kit
  4. Kindly let me know the procedures
  5. Also if I plan to use custom board for this..let me know how we can program for incoming BLE msg to be sent via UART..
Kindly let me know
Thanks and regards
Ravi chandran
    Kindly let me know what combination I should choose S140 with nrfSDK_V17??..if so I am not able to see any Segger IDE getting installed...nor any example files kindly guide me here.
    regards
    Ravi
  • Hello Ravi, sorry about the wait. Its hard to avoid some delay during the holidays.
    As it has been 20 days, I guess I should start off asking if you have already managed to sort this out on your own?
    Otherwise, when starting off you do have the choice between our two SDKs, nRF5 SDK and nRF Connect SDK. On tips on what to choose, see here!
    As you did mention Visual Studio and nRF Connect in your previous replies, I assume that is what you would prefer to use? In that case I would recommend that you look here for a tutorial on how to get started with NCS. And here on how to continue with VS.
    Let me know if there is anything else.
    Elfving
  • Hi Elfving,
    Thanks for your reply.we are using NRF52840 development kit for our BLE test .
    Our requirement is as follows
    1. we would like to configure the nRF developement board with particular UART so that what ever message comes in will go through the BLE and comes through UART to PC.
    can we use your nRF connect APP to check whether message is passed on??
    How do you configure and choose the UART and  make this work?
    2. Later in our custom board we have used nRF52840 along with STM which is connected via UART,we want messages to go through the UART to BLE and from there to air so that other devices picks this up.
    Thats our final requirement.
    Kindly let us know what are all the steps needs to be followed to acheive using development board.
    do we need to create an hex file to flash..let us know.which are all the necessary IDE required so that we can configure and test the same.
    Kindly guide us .
    Thanks and regards
    Ravi chandran
  • Hi Elfving,
    I would like to add to the above queries that I need BLE to run along with whatever comes as input to BLE should be sent to the STM which is connected via UART and what ever comes to BLE through UART will be sent outside the BLE.It has to be a 22 way communication.
    for this to test how can I enable BLE stack + configure UART and create a hex file and then test as follows
    1.nrfconnect App(send msg)-> connects to nRF 52840 dev board -> reaches UART and then displays in laptop using putty/teraterm/termite
    2. send msg via Putty/teraterm/termite->to  nRF 52840 dev board-> send to nRf connect App
    FIrst I need to create a hex fie for this
    psedo code
    enable BLE
    configure respective UART 2
    if(msg received through UART)
    send to APP
    if(msg received from App)
    send to UART2 to STM
    this is the sort of code we need to build and test.let me know how do we proceed with this.
    what are all the tools ,any IDE where we can configue and run directly let me know
    Thanks and regards
    Ravi chamdram
  • Hello Ravi!
    First of all, have you taken a look at the tutorials? Have you decided on whether you want to use nRF5SDK or NCS? And have you taken a look at the UART example, for instance this?
    Elfving
