GATT CONN TERMINATE LOCAL HOST occurs when bonding with Android
Hello.
I am developing using nrf52832 (S132 v7.0.1, SDK v17.0.0).
Since I want to bond with Android, I have created a central code that summarizes the functions that I think are necessary by referring to various sample sources.
On Android, a pairing request is displayed, but when I press connect, it becomes GATT CONN TERMINATE LOCAL HOST and I cannot bond.
Does anyone know how to deal with it?
I can't use nRF Sniffer because I don't have two boards.
Best regards.
  • Hello.
    Does that mean I have to register NUS GATT?
    It is possible to connect with Android, and I think it is a matter of bonding at that time. So I think GATT has nothing to do with it.
    If I need GATT, I have to add it to nRF Connect, but I don't know the data structure. Is there any material that describes the configuration?
    Best regards.
  • Hi
    What kind of error do you see when trying to bond with your Android peripheral. Can you show me a screenshot of how you've set up the Android advertiser?
    Please also note that, by default the ble_app_uart_c example project does not support bonding, so it makes sense that you won't be able to bond an Android device to it. If you try using the ble_app_hrs_c example where SEC_PARAM_BOND is set to 1, and bonding is implemented, that should work better.
    Simon
  • Hello.
    sorry for being late.
    I compared the project where my bonding fails with ble_app_hrs_c, but I still don't understand why it fails.
    Do you have any advertisements?
    Best regards.
  • Have you included the pm_evt_handler() function and peer manager library files in your project in order to include and add bonding to your project? Just setting the SEC_PARAM_BOND to 1 won't be sufficient in a project that hasn't implemented the peer manager at all.
    Simon
  • Hello.
    I have included the peer manager and pm_evt_handler () in my project with the code settings below. Is there anything else I need?
    #define SEC_PARAM_BOND            1                                /**< Perform bonding. */
    #define SEC_PARAM_MITM            0                                /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC            1                                /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS        0                                /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES BLE_GAP_IO_CAPS_NONE             /**< No I/O capabilities. */
    #define SEC_PARAM_OOB             0                                /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE    7                                /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE    16                               /**< Maximum encryption key size. */
    static void peer_manager_init(void)
        ret_code_t err_code;
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
        return;
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_conn_sec_config_t conn_sec_config;
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id) {
            case PM_EVT_BONDED_PEER_CONNECTED:
            case PM_EVT_CONN_SEC_START:
            case PM_EVT_CONN_SEC_SUCCEEDED:
            case PM_EVT_CONN_SEC_FAILED:
            case PM_EVT_CONN_SEC_CONFIG_REQ:
                // Even true didn't make sense.
                conn_sec_config.allow_repairing = false;
                pm_conn_sec_config_reply(p_evt->conn_handle, &conn_sec_config);
            case PM_EVT_CONN_SEC_PARAMS_REQ:
            case PM_EVT_STORAGE_FULL:
            case PM_EVT_ERROR_UNEXPECTED:
            case PM_EVT_PEER_DATA_UPDATE_SUCCEEDED:
            case PM_EVT_PEER_DATA_UPDATE_FAILED:
            case PM_EVT_PEER_DELETE_SUCCEEDED:
            case PM_EVT_PEER_DELETE_FAILED:
            case PM_EVT_PEERS_DELETE_FAILED:
            case PM_EVT_LOCAL_DB_CACHE_APPLIED:
            case PM_EVT_LOCAL_DB_CACHE_APPLY_FAILED:
            case PM_EVT_SERVICE_CHANGED_IND_SENT:
            case PM_EVT_SERVICE_CHANGED_IND_CONFIRMED:
            case PM_EVT_SLAVE_SECURITY_REQ:
            case PM_EVT_FLASH_GARBAGE_COLLECTED:
            case PM_EVT_FLASH_GARBAGE_COLLECTION_FAILED:
        return;
    Best regards.
