NRF52840 Dongle not working properly
I have a problem with my nrf dongle i have working example on the DK and i could not put this onto the dongle. I tried dedicated examples and they are not working too. For example ble app blinky the softdevice and the app file were good, device had green light however when i tried to connect via my phone (nrf connect app) it could not connect and the dongle changed its light to red and was not able to detect by nrf connect on PC. Also i could not programm the bootloader (open_bootloader) from examples for PCA 10059. I do not know what to do next.
     * Copyright (c) 2017 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup usbd_ble_uart_example main.c
     * @ingroup  usbd_ble_uart_example
     * @brief    USBD CDC ACM over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service
     * and USBD CDC ACM library.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_usbd.h"
    #include "nrf_drv_clock.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_drv_power.h"
    #include "app_error.h"
    #include "app_util.h"
    #include "app_usbd_core.h"
    #include "app_usbd.h"
    #include "app_usbd_string_desc.h"
    #include "app_usbd_cdc_acm.h"
    #include "app_usbd_serial_num.h"
    #define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
    #define LED_BLE_NUS_RX   (BSP_BOARD_LED_1)
    #define LED_CDC_ACM_CONN (BSP_BOARD_LED_2)
    #define LED_CDC_ACM_RX   (BSP_BOARD_LED_3)
    #define LED_BLINK_INTERVAL 800
    static int  frame_counter;
    APP_TIMER_DEF(m_blink_ble);
    APP_TIMER_DEF(m_blink_cdc);
     * @brief App timer handler for blinking the LEDs.
     * @param p_context LED to blink.
     static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
    void blink_handler(void * p_context)
        bsp_board_led_invert((uint32_t) p_context);
    #define ENDLINE_STRING "\r\n"
    // USB DEFINES START
    static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                        app_usbd_cdc_acm_user_event_t event);
    #define CDC_ACM_COMM_INTERFACE  0
    #define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
    #define CDC_ACM_DATA_INTERFACE  1
    #define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
    #define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
    static char m_cdc_data_array[BLE_NUS_MAX_DATA_LEN];
    /** @brief CDC_ACM class instance */
    APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                                cdc_acm_user_ev_handler,
                                CDC_ACM_COMM_INTERFACE,
                                CDC_ACM_DATA_INTERFACE,
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
                                APP_USBD_CDC_COMM_PROTOCOL_AT_V250);
    // USB DEFINES END
    // BLE DEFINES START
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    //#define APP_FEATURE_NOT_SUPPORTED       BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2        /**< Reply when unsupported features are requested. */
    #define DEVICE_NAME                     "Nordic_UART"                      /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms). Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms). Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< GATT module instance. */
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static char m_nus_data_array[BLE_NUS_MAX_DATA_LEN];
    // BLE DEFINES END
     * @brief Function for assert macro callback.
     *          how your product is supposed to react in case of an assert.
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /** @brief Function for initializing the timer module. */
    static void timers_init(void)
        err_code = app_timer_create(&m_blink_ble, APP_TIMER_MODE_REPEATED, blink_handler);
        err_code = app_timer_create(&m_blink_cdc, APP_TIMER_MODE_REPEATED, blink_handler);
     * @brief Function for the GAP initialization.
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
     * @brief Function for handling the data from the Nordic UART Service.
     * @details This function processes the data received from the Nordic UART BLE Service and sends
     *          it to the USBD CDC ACM module.
     * @param[in] p_evt Nordic UART Service event.
            bsp_board_led_invert(LED_BLE_NUS_RX);
            NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on CDC ACM.");
            memcpy(m_nus_data_array, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
            // Add endline characters
            uint16_t length = p_evt->params.rx_data.length;
            if (length + sizeof(ENDLINE_STRING) < BLE_NUS_MAX_DATA_LEN)
                memcpy(m_nus_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                length += sizeof(ENDLINE_STRING);
            // Send data through CDC ACM
            ret_code_t ret = app_usbd_cdc_acm_write(&m_app_cdc_acm,
                                                    m_nus_data_array,
                                                    length);
            if(ret != NRF_SUCCESS)
                NRF_LOG_INFO("CDC ACM unavailable, data received: %s", m_nus_data_array);
    /** @brief Function for initializing services that will be used by the application. */
        uint32_t       err_code;
        ble_nus_init_t nus_init = {0};
     * @brief Function for handling errors from the Connection Parameters module.
        uint32_t err_code;
    /** @brief Function for initializing the Connection Parameters module. */
     * @brief Function for putting the chip into sleep mode.
     * @note This function does not return.
        // Prepare wakeup buttons.
    /** @brief Function for starting advertising. */
     * @brief Function for handling advertising events.
     * @details This function is called for advertising events which are passed to the application.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                err_code = app_timer_start(m_blink_ble,
                                           APP_TIMER_TICKS(LED_BLINK_INTERVAL),
                                           (void *) LED_BLE_NUS_CONN);
            case BLE_ADV_EVT_IDLE:
                NRF_LOG_INFO("Advertising timeout, restarting.")
                advertising_start();
     * @brief Function for handling BLE events.
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("BLE NUS connected");
                err_code = app_timer_stop(m_blink_ble);
                bsp_board_led_on(LED_BLE_NUS_CONN);
                size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
                err_code = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
                if (err_code == NRF_SUCCESS)
                    ++frame_counter;
                NRF_LOG_INFO("BLE NUS disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported.
            case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
                ble_gap_data_length_params_t dl_params;
                // Clearing the struct will effectively set members to @ref BLE_GAP_DATA_LENGTH_AUTO.
                memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
                err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
            case BLE_EVT_USER_MEM_REQUEST:
                err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
            case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
                ble_gatts_evt_rw_authorize_request_t  req;
                ble_gatts_rw_authorize_reply_params_t auth_reply;
                req = p_ble_evt->evt.gatts_evt.params.authorize_request;
                if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
                    if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ)     ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
                        (req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
                        if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
                            auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
                        auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
                        err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
        &auth_reply);
            } break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
                // No implementation needed.
     * @brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /** @brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /** @brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @brief Function for handling events from the BSP module.
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
    /** @brief Function for initializing the Advertising functionality. */
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    /** @brief Function for initializing buttons and LEDs. */
    static void buttons_leds_init(void)
        uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /** @brief Function for initializing the nrf_log module. */
    static void log_init(void)
    /** @brief Function for placing the application in low power state while waiting for events. */
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
     * @brief Function for handling the idle state (main loop).
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        power_manage();
    // USB CODE START
    static bool m_usb_connected = false;
    /** @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t */
        app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
        switch (event)
            case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
                /*Set up the first transfer*/
                ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                       m_cdc_data_array,
                                                       1);
                UNUSED_VARIABLE(ret);
                ret = app_timer_stop(m_blink_cdc);
                APP_ERROR_CHECK(ret);
                bsp_board_led_on(LED_CDC_ACM_CONN);
                NRF_LOG_INFO("CDC ACM port opened");
            case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
                NRF_LOG_INFO("CDC ACM port closed");
                if (m_usb_connected)
                    ret_code_t ret = app_timer_start(m_blink_cdc,
                                                     (void *) LED_CDC_ACM_CONN);
            case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
                ret_code_t ret;
                static uint8_t index = 0;
                index++;
                do
                    if ((m_cdc_data_array[index - 1] == '\n') ||
                        (m_cdc_data_array[index - 1] == '\r') ||
                        (index >= (m_ble_nus_max_data_len)))
                        if (index > 1)
                            bsp_board_led_invert(LED_CDC_ACM_RX);
                            NRF_LOG_HEXDUMP_DEBUG(m_cdc_data_array, index);
                            do
                                    memcpy(m_cdc_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
                                ret = ble_nus_data_send(&m_nus,
                                                        (uint8_t *) m_cdc_data_array,
                                                        &length,
                                                        m_conn_handle);
                                if (ret == NRF_ERROR_NOT_FOUND)
                                    NRF_LOG_INFO("BLE NUS unavailable, data received: %s", m_cdc_data_array);
                                if (ret == NRF_ERROR_RESOURCES)
                                    NRF_LOG_ERROR("BLE NUS Too many notifications queued.");
                                if ((ret != NRF_ERROR_INVALID_STATE) && (ret != NRF_ERROR_BUSY))
                            while (ret == NRF_ERROR_BUSY);
                        index = 0;
                    /*Get amount of data transferred*/
                    size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                    NRF_LOG_DEBUG("RX: size: %lu char: %c", size, m_cdc_data_array[index - 1]);
                    /* Fetch data until internal buffer is empty */
                                                &m_cdc_data_array[index],
                                                1);
                    if (ret == NRF_SUCCESS)
                        index++;
                while (ret == NRF_SUCCESS);
    static void usbd_user_ev_handler(app_usbd_event_type_t event)
        switch (event)
            case APP_USBD_EVT_DRV_SUSPEND:
            case APP_USBD_EVT_DRV_RESUME:
            case APP_USBD_EVT_STARTED:
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
            case APP_USBD_EVT_POWER_DETECTED:
                NRF_LOG_INFO("USB power detected");
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                NRF_LOG_INFO("USB power removed");
                ret_code_t err_code = app_timer_stop(m_blink_cdc);
                bsp_board_led_off(LED_CDC_ACM_CONN);
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                NRF_LOG_INFO("USB ready");
                ret_code_t err_code = app_timer_start(m_blink_cdc,
                m_usb_connected = true;
                app_usbd_start();
    // USB CODE END
    /** @brief Application main function. */
        ret_code_t ret;
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler
        // Initialize.
        log_init();
        timers_init();
        buttons_leds_init();
        app_usbd_serial_num_generate();
        ret = nrf_drv_clock_init();
        NRF_LOG_INFO("USBD BLE UART example started.");
        ret = app_usbd_init(&usbd_config);
        app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
        ret = app_usbd_class_append(class_cdc_acm);
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        ret = app_usbd_power_events_enable();
        // Enter main loop.
        for (;;)
            while (app_usbd_event_queue_process())
                /* Nothing to do */
                ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
                    ++frame_counter;
            //idle_state_handle();
    With pleasure it took me 9 hours yesterday and still the same problem. There is no ble_lbs_init() in sdk confis LBS is disabled and still it appears.
  • I see no reason why the LBS service should be part of this project from the main.c file. What SDK example did you base your project on? The ble_app_uart nor the usbd_ble_uart example projects have the lbs service enabled by default.
    To make sure that you are connecting to the correct board, can you try changing the Device name on your Dongle, and connect to the new name to check that the lbs service is still present.
    Simon
  • Now i see that my phone see everything as LBS service, hrs uart etc. Reinstalling app (NRF connect) do not work, the problem is still the same. I use iPhone X. Do you have any advice for this?
  • I have one more question i made it working but i do not know how to write a new line and all my data is transfered into a single line on serial port i tried 0x0A sign (new line sign) but it did not work
  • Hi
    I asked one of my colleagues that works with the iOS version of the nRFConnect app, and apparently, the iPhone/iOS caches services, etc. until you do service discovery again. You can try erasing bonding information entirely on the phone side to make sure it's not cached anymore, and then try reinstalling the app and make sure service discovery is being done upon the new connection.
    Simon
