FREETOS + NUS high throput application crash the BLE stack without error
CONFIGURACION:
NRF52 + SDK15 + SD132 + FREERTOS + NUS.
I have a task sending many packages to a central. I'm having an aboslutly aleatory behaviour:
- At some time (could be seconds or minutes) the tramsmition stops and I start to get NRF_ERROR_RESOURCES. Next, the device is disconnected but I don't get the BLE_GAP_EVT_DISCONNECTED or BLE_GATTC_EVT_TIMEOUT events in the ble event handler.
-Besides the device desappears in the scan, I have had tryed to restart advertising without succed.
- I'm not receving any error in the peer, and the program is still running correctly, but it looks like the SD is not responding anymore.
- I have tried a lot of debbuging strategies and different configuration without succed, the only temporaly solution was a NVIC_system_restart with a timeout in the comunication task.
Could you give me a clue of what could be happening? Update the sdk could be a solution for this problem?
I let you two involved functions: ble_transmition_test is the one that I'm using to reproduce the issue. I'm calling it from a freertos task with low priority.
uint32_t ble_string_send(uint8_t *data, uint16_t len)
	uint32_t err_code;
	uint16_t time_out = 10;
	uint16_t m_len = 0;
	if (len == 0)
		return 0;
	if (ble_state == BLE_DISCONNECTED)
		return 0;
	if (len > m_ble_nus_max_data_len)
		m_len = m_ble_nus_max_data_len;
		m_len = len;
	do
		err_code = ble_nus_data_send(&m_nus, data, &m_len, m_conn_handle);
		time_out--;
	} while ((err_code == NRF_ERROR_BUSY || err_code == NRF_ERROR_RESOURCES)  && time_out);
	if (err_code == NRF_SUCCESS)
		return m_len;
		return 0;
void ble_transmition_test(void)
	uint32_t i = 0;
	while(1)
		uint16_t len = sprintf((char*) ble_tx_data, "%u,%.2f,%d,[%.1f,%.1f,%.1f,%d],%d\r\n", i, (float) 20.0, 1,0.066, 1.0,2.0,10,90);
		uint8_t retrys = 100;
		while (ble_string_send(ble_tx_data, len) < len && retrys)
			vTaskDelay(20);
			retrys--;
		vTaskDelay(10);
		i++;
		uint8_t err_code;
        case BLE_GAP_EVT_CONNECTED:
						ble_state = BLE_CONNECTED;
						ble_state = BLE_DISCONNECTED;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
				case BLE_GATTS_EVT_HVN_TX_COMPLETE:
						send_wait = false;
							NRF_LOG_INFO("Send ends");
				case BLE_GAP_EVT_ADV_SET_TERMINATED:
					//command_to_hmi.type = HMI_COMMAND_SLEEP;
            // No implementation needed.
  • Unfortunately I am not familiar with FreeRTOS, but if you are not getting a disconnect event, are you sure the code is running at all and not for instance stuck in app_error_fault_handler() or waiting indefinitely for ble_nus_data_send(), after looking at the code it may seem as that is the case. The NRF_ERROR_RESOURCES simply means that the softdevice buffer is full, and the application should wait for BLE_GATTS_EVT_HVN_TX_COMPLETE event before trying again. So I suggest to change your code a bit, either ignore NRF_ERROR_RESOURCES (which means packet will be lost) or the application need to buffer the packet on NRF_ERROR_RESOURCES event, and try again on BLE_GATTS_EVT_HVN_TX_COMPLETE event. You may also consider changing the connection interval (make it shorter) to allow more throughput in general. You may also try to configure NRF_SDH_CLOCK_LF_ACCURACY 1 to see if your problem is related to LFCLK accuracy of any kind.
    Kenneth
  • Hi! I have tried also what you have said about the BLE_GATTS_EVT_HVN_TX_COMPLETE, with the same result. As I've said, I can see se program runging ok, it is not stuck in any fault hanlder.
    About that, I'm using the sintetic LF clock with this accuracy: NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM. Am I to change the accuracy? I'm not sure if that couyld be the problem, but I'm noticing that the vtaskDelay (freertos task delay)is kind imprecise.
