We are trying to work pc-ble-driver on Windows with CODED PHY.
it works with 1Mb PHY but not with CODED PHY.
I changed the MAX CONNECITON INTERVAL to 500, but getting error on connection of NRF_ERROR_RESOURCES.
Using nrf52840 dongle on Windows PC with connectivity FW "connectivity_4.1.4_usb_with_s140_6.1.1.hex"
Using pc-ble-driver Release 4.1.4 branch.
Attached my "main.c" used with "heart_rate_collector_sd_api_v6.exe"
Moshe
* copyright (c) 2012 - 2018, nordic semiconductor asa
* all rights reserved.
* redistribution and use in source and binary forms, with or without modification,
* 1. redistributions of source code must retain the above copyright notice, this
* list of conditions and the following disclaimer.
* 2. redistributions in binary form, except as embedded into a nordic
* semiconductor asa integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/**@example examples/heart_rate_collector
* @brief Heart Rate Collector Sample Application main file.
* This file contains the source code for a sample application that acts as a BLE Central device.
* This application scans for a Heart Rate Sensor device and reads it's heart rate data.
* https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.service.heart_rate.xml
* Structure of this file
* - Includes
* - Definitions
* - Global variables
* - Global functions
* - Event functions
* - Event dispatcher
* - Main
/** Includes */
#include "ble.h"
#include "sd_rpc.h"
#include <stdbool.h>
#include <stdio.h>
#include <string.h>
/** Definitions */
#define DEFAULT_BAUD_RATE 1000000 /**< The baud rate to be used for serial communication with nRF5 device. */
#ifdef _WIN32
#define DEFAULT_UART_PORT_NAME "COM10"
#ifdef __APPLE__
#define DEFAULT_UART_PORT_NAME "/dev/tty.usbmodem00000"
#ifdef __linux__
#define DEFAULT_UART_PORT_NAME "/dev/ttyACM0"
enum
UNIT_0_625_MS = 625, /**< Number of microseconds in 0.625 milliseconds. */
UNIT_1_25_MS = 1250, /**< Number of microseconds in 1.25 milliseconds. */
UNIT_10_MS = 10000 /**< Number of microseconds in 10 milliseconds. */
#define MSEC_TO_UNITS(TIME, RESOLUTION) (((TIME) * 1000) / (RESOLUTION))
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 milliseconds. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 milliseconds. */
#define SCAN_TIMEOUT 0x50 /**< Scan timeout between 0x01 and 0xFFFF in seconds, 0x0 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(500, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
//#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
//#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY 0 /**< Slave Latency in number of connection events. */
#define CONNECTION_SUPERVISION_TIMEOUT MSEC_TO_UNITS(8000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
#define TARGET_DEV_NAME "Moshe" /**< Connect to a peripheral using a given advertising name here. */
//#define TARGET_DEV_NAME "KLA_substrate-id-1" /**< Connect to a peripheral using a given advertising name here. */
// moshe #define TARGET_DEV_NAME "Nordic_HRM" /**< Connect to a peripheral using a given advertising name here. */
#define MAX_PEER_COUNT 1 /**< Maximum number of peer's application intends to manage. */
#define BLE_UUID_HEART_RATE_SERVICE 0x180D /**< Heart Rate service UUID. */
#define BLE_UUID_HEART_RATE_MEASUREMENT_CHAR 0x2A37 /**< Heart Rate Measurement characteristic UUID. */
#define BLE_UUID_CCCD 0x2902
#define BLE_CCCD_NOTIFY 0x01
#define STRING_BUFFER_SIZE 50
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
/** Global variables */
static uint8_t m_connected_devices = 0;
static uint16_t m_connection_handle = 0;
static uint16_t m_service_start_handle = 0;
static uint16_t m_service_end_handle = 0;
static uint16_t m_hrm_char_handle = 0;
static uint16_t m_hrm_cccd_handle = 0;
static bool m_connection_is_in_progress = false;
static adapter_t * m_adapter = NULL;
#if NRF_SD_BLE_API >= 5
static uint32_t m_config_id = 1;
#if NRF_SD_BLE_API >= 6
static uint8_t mp_data[255] = { 0 };
// moshestatic uint8_t mp_data[100] = { 0 };
static ble_data_t m_adv_report_buffer;
static const ble_gap_scan_params_t m_scan_param =
1, // moshe // Set if accept extended advertising packetets.
0, // Set if report inomplete reports.
0, // Set if active scanning.
#if NRF_SD_BLE_API < 6
0, // Set if selective scanning.
BLE_GAP_SCAN_FP_ACCEPT_ALL,
BLE_GAP_PHY_CODED, //moshe
//BLE_GAP_PHY_1MBPS | BLE_GAP_PHY_CODED,
#if NRF_SD_BLE_API == 2
NULL, // Set white-list.
#if NRF_SD_BLE_API == 3 || NRF_SD_BLE_API == 5
0, // Set adv_dir_report.
(uint16_t)SCAN_INTERVAL,
(uint16_t)SCAN_WINDOW,
(uint16_t)SCAN_TIMEOUT
, { 0 } // Set chennel mask.
static const ble_gap_conn_params_t m_connection_param =
(uint16_t)MIN_CONNECTION_INTERVAL,
(uint16_t)MAX_CONNECTION_INTERVAL,
(uint16_t)SLAVE_LATENCY,
(uint16_t)CONNECTION_SUPERVISION_TIMEOUT
/** Global functions */
/**@brief Function for handling error message events from sd_rpc.
* @param[in] adapter The transport adapter.
* @param[in] code Error code that the error message is associated with.
* @param[in] message The error message that the callback is associated with.
static void status_handler(adapter_t * adapter, sd_rpc_app_status_t code, const char * message)
printf("Status: %d, message: %s\n", (uint32_t)code, message);
fflush(stdout);
/**@brief Function for handling the log message events from sd_rpc.
* @param[in] severity Level of severity that the log message is associated with.
* @param[in] message The log message that the callback is associated with.
static void log_handler(adapter_t * adapter, sd_rpc_log_severity_t severity, const char * message)
switch (severity)
case SD_RPC_LOG_ERROR:
printf("Error: %s\n", message);
fflush(stdout);
case SD_RPC_LOG_WARNING:
printf("Warning: %s\n", message);
fflush(stdout);
case SD_RPC_LOG_INFO:
printf("Info: %s\n", message);
fflush(stdout);
printf("Log: %s\n", message);
fflush(stdout);
/**@brief Function for initializing serial communication with the target nRF5 Bluetooth slave.
* @param[in] serial_port The serial port the target nRF5 device is connected to.
* @return The new transport adapter.
static adapter_t * adapter_init(char * serial_port, uint32_t baud_rate)
physical_layer_t * phy;
data_link_layer_t * data_link_layer;
transport_layer_t * transport_layer;
phy = sd_rpc_physical_layer_create_uart(serial_port,
baud_rate,
SD_RPC_FLOW_CONTROL_NONE,
SD_RPC_PARITY_NONE);
data_link_layer = sd_rpc_data_link_layer_create_bt_three_wire(phy, 250);
transport_layer = sd_rpc_transport_layer_create(data_link_layer, 1500);
return sd_rpc_adapter_create(transport_layer);
/**@brief Function for converting a BLE address to a string.
* @param[in] address Bluetooth Low Energy address.
* @param[out] string_buffer The serial port the target nRF5 device is connected to.
static void ble_address_to_string_convert(ble_gap_addr_t address, uint8_t * string_buffer)
const int address_length = 6;
char temp_str[3];
for (int i = address_length - 1; i >= 0; --i)
sprintf(temp_str, "%02X", address.addr[i]);
strcat((char *)string_buffer, temp_str);
* @brief Parses advertisement data, providing length and location of the field in case
* matching data is found.
* @param[in] Type of data to be looked for in advertisement data.
* @param[in] Advertisement report length and pointer to report.
* @param[out] If data type requested is found in the data report, type data length and
* pointer to data will be populated here.
* @retval NRF_SUCCESS if the data type is found in the report.
* @retval NRF_ERROR_NOT_FOUND if the data type could not be found.
static uint32_t adv_report_parse(uint8_t type, data_t * p_advdata, data_t * p_typedata)
uint32_t index = 0;
uint8_t * p_data;
p_data = p_advdata->p_data;
while (index < p_advdata->data_len)
uint8_t field_length = p_data[index];
uint8_t field_type = p_data[index + 1];
if (field_type == type)
p_typedata->p_data = &p_data[index + 2];
p_typedata->data_len = field_length - 1;
return NRF_SUCCESS;
index += field_length + 1;
return NRF_ERROR_NOT_FOUND;
/**@brief Function for searching a given name in the advertisement packets.
* @details Use this function to parse received advertising data and to find a given
* name in them either as 'complete_local_name' or as 'short_local_name'.
* @param[in] p_adv_report advertising data to parse.
* @param[in] name_to_find name to search.
* @return true if the given name was found, false otherwise.
static bool find_adv_name(const ble_gap_evt_adv_report_t *p_adv_report, const char * name_to_find)
uint32_t err_code;
data_t adv_data;
data_t dev_name;
// Initialize advertisement report for parsing
adv_data.p_data = (uint8_t *)p_adv_report->data.p_data;
adv_data.data_len = p_adv_report->data.len;
#else
adv_data.p_data = (uint8_t *)p_adv_report->data;
adv_data.data_len = p_adv_report->dlen;
//search for advertising names
err_code = adv_report_parse(BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME,
&adv_data,
&dev_name);
if (err_code == NRF_SUCCESS)
if (memcmp(name_to_find, dev_name.p_data, dev_name.data_len )== 0)
return true;
// Look for the short local name if it was not found as complete
err_code = adv_report_parse(BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME,
&adv_data,
&dev_name);
if (err_code != NRF_SUCCESS)
return false;
return true;
return false;
* @return NRF_SUCCESS on success, otherwise an error code.
static uint32_t ble_stack_init()
uint32_t err_code;
uint32_t * app_ram_base = NULL;
#if NRF_SD_BLE_API <= 3
ble_enable_params_t ble_enable_params;
memset(&ble_enable_params, 0, sizeof(ble_enable_params));
ble_enable_params.gatt_enable_params.att_mtu = GATT_MTU_SIZE_DEFAULT;
#elif NRF_SD_BLE_API < 3
ble_enable_params.gatts_enable_params.attr_tab_size = BLE_GATTS_ATTR_TAB_SIZE_DEFAULT;
ble_enable_params.gatts_enable_params.service_changed = false;
ble_enable_params.common_enable_params.p_conn_bw_counts = NULL;
ble_enable_params.common_enable_params.vs_uuid_count = 1;
ble_enable_params.gap_enable_params.periph_conn_count = 1;
ble_enable_params.gap_enable_params.central_conn_count = 1;
ble_enable_params.gap_enable_params.central_sec_count = 1;
err_code = sd_ble_enable(m_adapter, &ble_enable_params, app_ram_base);
#else
err_code = sd_ble_enable(m_adapter, app_ram_base);
switch (err_code) {
case NRF_SUCCESS:
case NRF_ERROR_INVALID_STATE:
printf("BLE stack already enabled\n");
fflush(stdout);
printf("Failed to enable BLE stack. Error code: %d\n", err_code);
fflush(stdout);
return err_code;
#if NRF_SD_BLE_API < 5
/**@brief Set BLE option for the BLE role and connection bandwidth.
* @return NRF_SUCCESS on option set successfully, otherwise an error code.
static uint32_t ble_options_set()
ble_opt_t opt;
ble_common_opt_t common_opt;
common_opt.conn_bw.role = BLE_GAP_ROLE_CENTRAL;
common_opt.conn_bw.conn_bw.conn_bw_rx = BLE_CONN_BW_HIGH;
common_opt.conn_bw.conn_bw.conn_bw_tx = BLE_CONN_BW_HIGH;
opt.common_opt = common_opt;
return sd_ble_opt_set(m_adapter, BLE_COMMON_OPT_CONN_BW, &opt);
#else
return NRF_ERROR_NOT_SUPPORTED;
/**@brief Function for setting configuration for the BLE stack.
static uint32_t ble_cfg_set(uint8_t conn_cfg_tag)
const uint32_t ram_start = 0; // Value is not used by ble-driver
uint32_t error_code;
ble_cfg_t ble_cfg;
// Configure the connection roles.
memset(&ble_cfg, 0, sizeof(ble_cfg));
ble_cfg.gap_cfg.role_count_cfg.adv_set_count = BLE_GAP_ADV_SET_COUNT_DEFAULT;
ble_cfg.gap_cfg.role_count_cfg.periph_role_count = 0;
ble_cfg.gap_cfg.role_count_cfg.central_role_count = 1;
ble_cfg.gap_cfg.role_count_cfg.central_sec_count = 0;
error_code = sd_ble_cfg_set(m_adapter, BLE_GAP_CFG_ROLE_COUNT, &ble_cfg, ram_start);
if (error_code != NRF_SUCCESS)
printf("sd_ble_cfg_set() failed when attempting to set BLE_GAP_CFG_ROLE_COUNT. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
memset(&ble_cfg, 0x00, sizeof(ble_cfg));
ble_cfg.conn_cfg.conn_cfg_tag = conn_cfg_tag;
ble_cfg.conn_cfg.params.gatt_conn_cfg.att_mtu = 150;
error_code = sd_ble_cfg_set(m_adapter, BLE_CONN_CFG_GATT, &ble_cfg, ram_start);
printf("sd_ble_cfg_set() failed when attempting to set BLE_CONN_CFG_GATT. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
return NRF_SUCCESS;
/**@brief Start scanning (GAP Discovery procedure, Observer Procedure).
* @return NRF_SUCCESS on successfully initiating scanning procedure, otherwise an error code.
static uint32_t scan_start()
m_adv_report_buffer.p_data = mp_data;
m_adv_report_buffer.len = sizeof(mp_data);
uint32_t error_code = sd_ble_gap_scan_start(m_adapter, &m_scan_param
, &m_adv_report_buffer
printf("Scan start failed with error code: %d\n", error_code);
fflush(stdout);
} else
printf("Scan started\n");
fflush(stdout);
return error_code;
/**@brief Function called upon connecting to BLE peripheral.
* @details Initiates primary service discovery.
static uint32_t service_discovery_start()
uint32_t err_code;
uint16_t start_handle = 0x01;
ble_uuid_t srvc_uuid;
printf("Discovering primary services\n");
fflush(stdout);
srvc_uuid.type = BLE_UUID_TYPE_BLE;
srvc_uuid.uuid = BLE_UUID_HEART_RATE_SERVICE;
// Initiate procedure to find the primary BLE_UUID_HEART_RATE_SERVICE.
err_code = sd_ble_gattc_primary_services_discover(m_adapter,
m_connection_handle, start_handle,
&srvc_uuid);
printf("Failed to initiate or continue a GATT Primary Service Discovery procedure\n");
fflush(stdout);
return err_code;
/**@brief Function called upon discovering a BLE peripheral's primary service(s).
* @details Initiates service's (m_service) characteristic discovery.
static uint32_t char_discovery_start()
ble_gattc_handle_range_t handle_range;
printf("Discovering characteristics\n");
fflush(stdout);
handle_range.start_handle = m_service_start_handle;
handle_range.end_handle = m_service_end_handle;
return sd_ble_gattc_characteristics_discover(m_adapter, m_connection_handle, &handle_range);
/**@brief Function called upon discovering service's characteristics.
* @details Initiates heart rate monitor (m_hrm_char_handle) characteristic's descriptor discovery.
static uint32_t descr_discovery_start()
printf("Discovering characteristic's descriptors\n");
fflush(stdout);
if (m_hrm_char_handle == 0)
printf("No heart rate measurement characteristic handle found\n");
fflush(stdout);
handle_range.start_handle = m_hrm_char_handle;
return sd_ble_gattc_descriptors_discover(m_adapter, m_connection_handle, &handle_range);
/**@brief Function that write's the HRM characteristic's CCCD.
static uint32_t hrm_cccd_set(uint8_t value)
ble_gattc_write_params_t write_params;
uint8_t cccd_value[2] = {value, 0};
printf("Setting HRM CCCD\n");
fflush(stdout);
if (m_hrm_cccd_handle == 0)
printf("Error. No CCCD handle has been found\n");
fflush(stdout);
write_params.handle = m_hrm_cccd_handle;
write_params.len = 2;
write_params.p_value = cccd_value;
write_params.write_op = BLE_GATT_OP_WRITE_REQ;
write_params.offset = 0;
return sd_ble_gattc_write(m_adapter, m_connection_handle, &write_params);
/** Event functions */
/**@brief Function called on BLE_GAP_EVT_CONNECTED event.
* @details Update connection state and proceed to discovering the peer's GATT services.
* @param[in] p_ble_gap_evt GAP event.
static void on_connected(const ble_gap_evt_t * const p_ble_gap_evt)
printf("Connection established\n");
fflush(stdout);
m_connected_devices++;
m_connection_handle = p_ble_gap_evt->conn_handle;
service_discovery_start();
/**@brief Function called on BLE_GAP_EVT_ADV_REPORT event.
* @details Create a connection if received advertising packet corresponds to desired BLE device.
* @param[in] p_ble_gap_evt Advertising Report Event.
static void on_adv_report(const ble_gap_evt_t * const p_ble_gap_evt)
uint32_t err_code;
uint8_t str[STRING_BUFFER_SIZE] = {0};
// Log the Bluetooth device address of advertisement packet received.
ble_address_to_string_convert(p_ble_gap_evt->params.adv_report.peer_addr, str);
if (str[0] == 'D' || str[0] == 'd')
printf("Received advertisement report with device address: 0x%s\n", str);
fflush(stdout);
if (find_adv_name(&p_ble_gap_evt->params.adv_report, TARGET_DEV_NAME))
if (m_connected_devices >= MAX_PEER_COUNT || m_connection_is_in_progress)
return;
for(int uu=0;uu<10;uu++){
err_code = sd_ble_gap_connect(m_adapter,
&(p_ble_gap_evt->params.adv_report.peer_addr),
&m_scan_param,
&m_connection_param
, m_config_id
printf("Connection Request Failed, reason %d\n", err_code);
fflush(stdout);
//return;
m_connection_is_in_progress = true;
else {
err_code = sd_ble_gap_scan_start(m_adapter, NULL, &m_adv_report_buffer);
printf("Scan start failed with error code: %d\n", err_code);
fflush(stdout);
fflush(stdout);
/**@brief Function called on BLE_GAP_EVT_TIMEOUT event.
* @param[in] ble_gap_evt_t Timeout Event.
static void on_timeout(const ble_gap_evt_t * const p_ble_gap_evt)
if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
else if (p_ble_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
scan_start();
/**@brief Function called on BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP event.
* @details Update service state and proceed to discovering the service's GATT characteristics.
* @param[in] p_ble_gattc_evt Primary Service Discovery Response Event.
static void on_service_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
int count;
int service_index;
const ble_gattc_service_t * service;
printf("Received service discovery response\n");
fflush(stdout);
if (p_ble_gattc_evt->gatt_status != NRF_SUCCESS)
printf("Service discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
fflush(stdout);
return;
count = p_ble_gattc_evt->params.prim_srvc_disc_rsp.count;
if (count == 0)
printf("Service not found\n");
fflush(stdout);
return;
if (count > 1)
printf("Warning, discovered multiple primary services. Ignoring all but the first\n");
service_index = 0; /* We expect to discover only the Heart Rate service as requested. */
service = &(p_ble_gattc_evt->params.prim_srvc_disc_rsp.services[service_index]);
if (service->uuid.uuid != BLE_UUID_HEART_RATE_SERVICE)
printf("Unknown service discovered with UUID: 0x%04X\n", service->uuid.uuid);
fflush(stdout);
return;
m_service_start_handle = service->handle_range.start_handle;
m_service_end_handle = service->handle_range.end_handle;
printf("Discovered heart rate service. UUID: 0x%04X, "
"start handle: 0x%04X, end handle: 0x%04X\n",
service->uuid.uuid, m_service_start_handle, m_service_end_handle);
fflush(stdout);
char_discovery_start();
/**@brief Function called on BLE_GATTC_EVT_CHAR_DISC_RSP event.
* @details Update characteristic state and proceed to discovering the characteristicss descriptors.
* @param[in] p_ble_gattc_evt Characteristic Discovery Response Event.
static void on_characteristic_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
int count = p_ble_gattc_evt->params.char_disc_rsp.count;
printf("Characteristic discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
fflush(stdout);
return;
printf("Received characteristic discovery response, characteristics count: %d\n", count);
fflush(stdout);
for (int i = 0; i < count; i++)
printf("Characteristic handle: 0x%04X, UUID: 0x%04X\n",
p_ble_gattc_evt->params.char_disc_rsp.chars[i].handle_decl,
p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid);
fflush(stdout);
if (p_ble_gattc_evt->params.char_disc_rsp.chars[i].uuid.uuid ==
BLE_UUID_HEART_RATE_MEASUREMENT_CHAR)
m_hrm_char_handle = p_ble_gattc_evt->params.char_disc_rsp.chars[i].handle_decl;
descr_discovery_start();
/**@brief Function called on BLE_GATTC_EVT_DESC_DISC_RSP event.
* @details Update CCCD descriptor state and proceed to prompting user to toggle notifications.
* @param[in] p_ble_gattc_evt Descriptor Discovery Response Event.
static void on_descriptor_discovery_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
int count = p_ble_gattc_evt->params.desc_disc_rsp.count;
printf("Descriptor discovery failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
fflush(stdout);
return;
printf("Received descriptor discovery response, descriptor count: %d\n", count);
fflush(stdout);
printf("Descriptor handle: 0x%04X, UUID: 0x%04X\n",
p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle,
p_ble_gattc_evt->params.desc_disc_rsp.descs[i].uuid.uuid);
fflush(stdout);
if (p_ble_gattc_evt->params.desc_disc_rsp.descs[i].uuid.uuid == BLE_UUID_CCCD)
m_hrm_cccd_handle = p_ble_gattc_evt->params.desc_disc_rsp.descs[i].handle;
printf("Press enter to toggle notifications on the HRM characteristic\n");
fflush(stdout);
/**@brief Function called on BLE_GATTC_EVT_WRITE_RSP event.
* @param[in] p_ble_gattc_evt Write Response Event.
static void on_write_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
printf("Received write response.\n");
fflush(stdout);
printf("Error. Write operation failed. Error code 0x%X\n", p_ble_gattc_evt->gatt_status);
fflush(stdout);
/**@brief Function called on BLE_GATTC_EVT_HVX event.
* @details Logs the received heart rate measurement.
* @param[in] p_ble_gattc_evt Handle Value Notification/Indication Event.
static void on_hvx(const ble_gattc_evt_t * const p_ble_gattc_evt)
if (p_ble_gattc_evt->params.hvx.handle >= m_hrm_char_handle ||
p_ble_gattc_evt->params.hvx.handle <= m_hrm_cccd_handle) // Heart rate measurement.
// We know the heart rate reading is encoded as 2 bytes [flag, value].
printf("Received heart rate measurement: %d\n", p_ble_gattc_evt->params.hvx.data[1]);
else // Unknown data.
printf("Un-parsed data received on handle: %04X\n", p_ble_gattc_evt->params.hvx.handle);
fflush(stdout);
/**@brief Function called on BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST event.
* @details Update GAP connection parameters.
* @param[in] p_ble_gap_evt Connection Parameter Update Event.
static void on_conn_params_update_request(const ble_gap_evt_t * const p_ble_gap_evt)
uint32_t err_code = sd_ble_gap_conn_param_update(m_adapter, m_connection_handle,
&(p_ble_gap_evt->
params.conn_param_update_request.conn_params));
printf("Conn params update failed, err_code %d\n", err_code);
fflush(stdout);
#if NRF_SD_BLE_API >= 3
/**@brief Function called on BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST event.
* @details Replies to an ATT_MTU exchange request by sending an Exchange MTU Response to the client.
* @param[in] p_ble_gatts_evt Exchange MTU Request Event.
static void on_exchange_mtu_request(const ble_gatts_evt_t * const p_ble_gatts_evt)
uint32_t err_code = sd_ble_gatts_exchange_mtu_reply(
m_adapter,
GATT_MTU_SIZE_DEFAULT);
#else
BLE_GATT_ATT_MTU_DEFAULT);
printf("MTU exchange request reply failed, err_code %d\n", err_code);
fflush(stdout);
/**@brief Function called on BLE_GATTC_EVT_EXCHANGE_MTU_RSP event.
* @details Logs the new BLE server RX MTU size.
* @param[in] p_ble_gattc_evt Exchange MTU Response Event.
static void on_exchange_mtu_response(const ble_gattc_evt_t * const p_ble_gattc_evt)
uint16_t server_rx_mtu = p_ble_gattc_evt->params.exchange_mtu_rsp.server_rx_mtu;
printf("MTU response received. New ATT_MTU is %d\n", server_rx_mtu);
fflush(stdout);
/** Event dispatcher */
/**@brief Function for handling the Application's BLE Stack events.
* @param[in] p_ble_evt Bluetooth stack event.
static void ble_evt_dispatch(adapter_t * adapter, ble_evt_t * p_ble_evt)
if (p_ble_evt == NULL)
printf("Received an empty BLE event\n");
fflush(stdout);
return;
case BLE_GAP_EVT_CONNECTED:
on_connected(&(p_ble_evt->evt.gap_evt));
printf("Disconnected, reason: 0x%02X\n",
p_ble_evt->evt.gap_evt.params.disconnected.reason);
fflush(stdout);
m_connected_devices--;
case BLE_GAP_EVT_ADV_REPORT:
on_adv_report(&(p_ble_evt->evt.gap_evt));
case BLE_GAP_EVT_TIMEOUT:
on_timeout(&(p_ble_evt->evt.gap_evt));
case BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP:
on_service_discovery_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_CHAR_DISC_RSP:
on_characteristic_discovery_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_DESC_DISC_RSP:
on_descriptor_discovery_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_WRITE_RSP:
on_write_response(&(p_ble_evt->evt.gattc_evt));
case BLE_GATTC_EVT_HVX:
on_hvx(&(p_ble_evt->evt.gattc_evt));
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
on_conn_params_update_request(&(p_ble_evt->evt.gap_evt));
case BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST:
on_exchange_mtu_request(&(p_ble_evt->evt.gatts_evt));
case BLE_GATTC_EVT_EXCHANGE_MTU_RSP:
on_exchange_mtu_response(&(p_ble_evt->evt.gattc_evt));
printf("Received an un-handled event with ID: %d\n", p_ble_evt->header.evt_id);
fflush(stdout);
/** Main */
/**@brief Function for application main entry.
* @param[in] argc Number of arguments (program expects 0 or 1 arguments).
* @param[in] argv The serial port of the target nRF5 device (Optional).
int main(int argc, char * argv[])
char * serial_port = DEFAULT_UART_PORT_NAME;
uint32_t baud_rate = DEFAULT_BAUD_RATE;
uint8_t cccd_value = 0;
if (argc > 1)
serial_port = argv[1];
printf("Serial port used: %s\n", serial_port);
printf("Baud rate used: %d\n", baud_rate);
fflush(stdout);
m_adapter = adapter_init(serial_port, baud_rate);
sd_rpc_log_handler_severity_filter_set(m_adapter, SD_RPC_LOG_INFO);
error_code = sd_rpc_open(m_adapter, status_handler, ble_evt_dispatch, log_handler);
printf("Failed to open nRF BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
ble_cfg_set(m_config_id);
error_code = ble_stack_init();
return error_code;
error_code = ble_options_set();
return error_code;
error_code = scan_start();
return error_code;
// Endlessly loop.
for (;;)
char c = (char)getchar();
if (c == 'q' || c == 'Q')
error_code = sd_rpc_close(m_adapter);
printf("Failed to close nRF BLE Driver. Error code: 0x%02X\n", error_code);
fflush(stdout);
return error_code;
printf("Closed\n");
fflush(stdout);
return NRF_SUCCESS;
// Toggle notifications on the HRM characteristic every time user input is received.
cccd_value ^= BLE_CCCD_NOTIFY;
hrm_cccd_set(cccd_value);
