NCS IS_ENABLED macro and unit tests
Hello everyone,
I have added some unit tests to my project and some of them are failing because it seems like the IS_ENABLED macro is not evaluated correct. Even though I added the respective Kconfig define to the target_compile_options. The module has a number of Kconfig options to en-/disable certain functionality. In the code I check with the IS_ENABLED macro if such an option is enabled and then do something. You can find a basic example of what I have done in the archive below.
6153.app.zip
For the basic setup I followed this guide:
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.7.1/nrf/ug_unity_testing.html
Has anyone experienced a similar issue and has a solution for it?
Thanks in advance!
  • I was able to pass all the test by adding this line to app/tests/app_startup/prj.conf:
    CONFIG_COMPILER_OPT="-DCONFIG_APP_STARTUP_TIMEOUT_ENABLE=1 -DCONFIG_APP_STARTUP_TIMEOUT_INTERVAL=200 -DCONFIG_APP_STARTUP_TIMEOUT_DURATION=1000"
    First I tried using -DCONFIG_APP_STARTUP_TIMEOUT_ENABLE=y, but then IS_ENABLED(CONFIG_APP_STARTUP_TIMEOUT_ENABLE) would not evaulate to true.
    Simon
  • Hello Simon,
    thanks for your help, that's exactly what I needed.
    David
