Using LIS3dh with Thingy52
Hi
I am a student and this is my first project working on BLE. Please keep that in mind.
The end goal is to create a fingerprinting system with a Thingy (nRF6936) as a node. This Thingy currently broadcasts a UUID for gateways to pick up without a connection. The RSSI can then be derived inside the gateways. I am using the 17.1.0 nRF5 SDK
To increase the accuracy, I want to add accelerometer data inside the advertisement packet. Also, I want to make it more low power by sending very slow advertisements when the node isn't moving.
I couldn't find any drivers for the LIS3dh that work on Thingies. That means I have to use SPI or I²C?
The problem with this is that I need the pin layout of the Thingy to speak to the accelerometer directly.
Where can I find these?
I have included the code of my beacon.
 glass_beacon.zip
  • Hi
    When I was searching for drivers before, I was looking for LIS3DH.
    However, I just found that LIS2DH drivers are compatible(ref) with the LIS3DH.
    In the nRF Connect SDK, there is a LIS2DH: Motion Sensor Monitor sample.
    In the nRF 5 SDK, there is a driver for the LIS2DH as well, see this previous case.
    I am sorry that I did not spot this compatibility earlier. I hope that this could still be of some use.
    Sigurd Hellesvik
  • The following code reads the whoAmI value from the lis2dh12 sensor inside the thingy52. I'm just leaving it here for people who are having the same trouble as me in the future.
    Greetings
    Willem
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "lis2dh12.h"
    #include "nrf_twi_mngr.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID             0
    #define MAX_PENDING_TRANSACTIONS    33
    #define LIS2DH12_MIN_QUEUE_SIZE     32
    NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
    NRF_TWI_SENSOR_DEF(m_nrf_twi_sensor, &m_nrf_twi_mngr, LIS2DH12_MIN_QUEUE_SIZE);
    LIS2DH12_INSTANCE_DEF(m_lis2dh12, &m_nrf_twi_sensor, LIS2DH12_BASE_ADDRESS_HIGH);
    static uint8_t m_sample = 0;
    void print_identity(ret_code_t r, void *p_register_data)
        NRF_LOG_INFO("Identity: %d", *((uint8_t *)p_register_data));
        uint32_t err;
        nrf_drv_twi_config_t const config = {
           .scl                = 15,
           .sda                = 14,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_LOWEST,
           .clear_bus_init     = false
        NRF_LOG_INFO("TWI sensor example started.");
        NRF_LOG_FLUSH();
        err = nrf_twi_mngr_init(&m_nrf_twi_mngr, &config);
        APP_ERROR_CHECK(err);
        err = nrf_twi_sensor_init(&m_nrf_twi_sensor);
        err = lis2dh12_init(&m_lis2dh12);
        NRF_LOG_INFO("Here.");
        NRF_LOG_FLUSH();
        while (true)
            nrf_delay_ms(100);
            err = lis2dh12_who_am_i_read(&m_lis2dh12, print_identity, &m_sample);
            NRF_LOG_INFO("Who am I: %x", m_sample);
            NRF_LOG_FLUSH();
    Greetings
    Willem
    #include <stdio.h>
    #include "boards.h"
        uint32_t err;
           .scl                = 15,
           .sda                = 14,
        NRF_LOG_FLUSH();
        NRF_LOG_FLUSH();
        while (true)
            nrf_delay_ms(100);
            NRF_LOG_FLUSH();
