Many warnings in the NRF SDK 17.1.0 when compiling with armgcc Makefile
Until now we compiled our company project using SEGGER Embedded Studio command line tool 'emBuild' that was called from a custom Makefile like this:
emBuild -verbose -config "Debug_1" $(EMPROJECT_FILE)
But we would like to stop relying on SES and build our project with armgcc + Makefile directly.
So I set up a Makefile using the available examples of the sdk and made our project compile using it, so far it works great except one issue, there are many warnings (hundreds) in the SDK.
Most of these warnings come from the same two places in the code:
1. NRF_MODULE_ENABLED
For each call in any file of the sdk to this macro there is one warning generated that looks like this (-Wexpansion-to-defined):
In file included from ../components/libraries/log/nrf_log_ctrl.h:58,
                 from ../components/libraries/log/nrf_log_str_formatter.h:53,
                 from ../components/libraries/log/src/nrf_log_backend_serial.c:43:
../components/libraries/log/src/nrf_log_ctrl_internal.h: At top level:
../components/libraries/log/src/nrf_log_ctrl_internal.h:50:1: warning: this use of "defined" may not be portable [-Wexpansion-to-defined]
   50 | #if NRF_MODULE_ENABLED(NRF_LOG)
2. SVCALL
For each call in any file of the sdk to this macro there is one warning generated that looks like this (-Wunused-parameter):
Compiling file: nrf_log_backend_uart.c
In file included from ../components/softdevice/s140/headers/nrf52/nrf_mbr.h:50,
                 from ../components/libraries/util/app_util.h:133,
                 from ../components/libraries/util/sdk_common.h:61,
                 from ../components/libraries/log/src/nrf_log_backend_uart.c:40:
../components/softdevice/s140/headers/nrf52/nrf_mbr.h: In function 'sd_mbr_command':
../components/softdevice/s140/headers/nrf52/nrf_mbr.h:257:67: warning: unused parameter 'param' [-Wunused-parameter]
  257 | SVCALL(SD_MBR_COMMAND, uint32_t, sd_mbr_command(sd_mbr_command_t* param));
../components/softdevice/s140/headers/nrf_svc.h:76:22: note: in definition of macro 'SVCALL'
   76 |   static return_type signature                          \
How can we get rid of these warnings ? They make seeing our code's warnings and errors impossible to see.
Thanks you,
Yohann
