I2S
 * Copyright (c) 2015 - 2021, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup i2s_example_main main.c
 * @ingroup i2s_example
 * @brief I2S Example Application main file.
 * This file contains the source code for a sample application using I2S.
#include <stdio.h>
#include "nrf_drv_i2s.h"
#include "nrf_delay.h"
#include "app_error.h"
#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include"nrf_drv_qspi.h"
//I2S definations
#define LED_OK      BSP_BOARD_LED_0
#define LED_ERROR   BSP_BOARD_LED_1
#define I2S_SDIN_PIN   NRF_GPIO_PIN_MAP(0,28)
#define I2S_SDOUT_PIN  NRF_GPIO_PIN_MAP(0,29)
#define I2S_CLOCK_PIN  NRF_GPIO_PIN_MAP(0,31)
#define I2S_DATA_BLOCK_WORDS   256
static uint32_t m_buffer_rx[2][I2S_DATA_BLOCK_WORDS];
static uint32_t m_buffer_tx[2][I2S_DATA_BLOCK_WORDS];
// Delay time between consecutive I2S transfers performed in the main loop
// (in milliseconds).
#define PAUSE_TIME          500
// Number of blocks of data to be contained in each transfer.
#define BLOCKS_TO_TRANSFER  20
static uint8_t volatile m_blocks_transferred     = 0;
static uint8_t          m_zero_samples_to_ignore = 0;
static uint16_t         m_sample_value_to_send;
static uint16_t         m_sample_value_expected;
static bool             m_error_encountered;
static uint32_t       * volatile mp_block_to_fill  = NULL;
static uint32_t const * volatile mp_block_to_check = NULL;
//Qspi definitions
#define QSPI_STD_CMD_WRSR   0x01    //Write status register
#define QSPI_STD_CMD_RSTEN  0x66
#define QSPI_STD_CMD_RST    0x99
#define  QSPI_DATA_SIZE 256
#define WAIT_FOR_PERIPH() do { \
        while (!m_finished) {} \
        m_finished = false;    \
    } while (0)
static volatile bool m_finished = false;
//static uint8_t m_buffer_tx[ QSPI_DATA_SIZE];
//static uint8_t m_buffer_rx[ QSPI_DATA_SIZE];
static void qspi_handler(nrf_drv_qspi_evt_t event, void * p_context)
    UNUSED_PARAMETER(event);
    UNUSED_PARAMETER(p_context);
    m_finished = true;
static void configure_memory()
    uint8_t temporary = 0x40;
    uint32_t err_code;
    nrf_qspi_cinstr_conf_t cinstr_cfg = {
        .opcode    = QSPI_STD_CMD_RSTEN,
        .length    = NRF_QSPI_CINSTR_LEN_1B,
        .io2_level = true,
        .io3_level = true,
        .wipwait   = true,
        .wren      = true
    // Send reset enable
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, NULL, NULL);
    // Send reset command
    cinstr_cfg.opcode = QSPI_STD_CMD_RST;
    // Switch to qspi mode
    cinstr_cfg.opcode = QSPI_STD_CMD_WRSR;
    cinstr_cfg.length = NRF_QSPI_CINSTR_LEN_2B;
    err_code = nrf_drv_qspi_cinstr_xfer(&cinstr_cfg, &temporary, NULL);
void Qspi(void)
      ret_code_t error;
      srand(0);
      nrf_drv_qspi_config_t qspi_config = NRF_DRV_QSPI_DEFAULT_CONFIG;
   /*   for(uint16_t i = 0; i < 2; i++)
        m_buffer_rx[i] = rand();
      error = nrf_drv_qspi_init(&qspi_config,qspi_handler,NULL);
      APP_ERROR_CHECK(error);
      configure_memory();
      m_finished = false;
      error = nrf_drv_qspi_erase(NRF_QSPI_ERASE_LEN_64KB,0);
      WAIT_FOR_PERIPH();
     error = nrf_drv_qspi_write(m_buffer_tx, QSPI_DATA_SIZE, 0);
     WAIT_FOR_PERIPH();
      error = nrf_drv_qspi_read(m_buffer_rx,QSPI_DATA_SIZE,0);
      WAIT_FOR_PERIPH();
      if(memcmp(m_buffer_tx,m_buffer_rx,QSPI_DATA_SIZE)== 0)
        bsp_board_led_on(BSP_BOARD_LED_3);
       nrf_drv_qspi_uninit();
static void prepare_tx_data(uint32_t * p_block)
    // These variables will be both zero only at the very beginning of each
    // transfer, so we use them as the indication that the re-initialization
    // should be performed.
    if (m_blocks_transferred == 0 && m_zero_samples_to_ignore == 0)
        // Number of initial samples (actually pairs of L/R samples) with zero
        // values that should be ignored - see the comment in 'check_samples'.
        m_zero_samples_to_ignore = 2;
        m_sample_value_to_send   = 0xCAFE;
        m_sample_value_expected  = 0xCAFE;
        m_error_encountered      = false;
    // [each data word contains two 16-bit samples]
    uint16_t i;
    for (i = 0; i < I2S_DATA_BLOCK_WORDS; ++i)
        uint16_t sample_l = m_sample_value_to_send - 1;
        uint16_t sample_r = m_sample_value_to_send + 1;
        ++m_sample_value_to_send;
        uint32_t * p_word = &p_block[i];
        ((uint16_t *)p_word)[0] = sample_l;
        ((uint16_t *)p_word)[1] = sample_r;
static bool check_samples(uint32_t const * p_block)
    uint16_t i;
        uint32_t const * p_word = &p_block[i];
        uint16_t actual_sample_l = ((uint16_t const *)p_word)[0];
        uint16_t actual_sample_r = ((uint16_t const *)p_word)[1];
        // Normally a couple of initial samples sent by the I2S peripheral
        // will have zero values, because it starts to output the clock
        // before the actual data is fetched by EasyDMA. As we are dealing
        // with streaming the initial zero samples can be simply ignored.
        if (m_zero_samples_to_ignore > 0 &&
            actual_sample_l == 0 &&
            actual_sample_r == 0)
            --m_zero_samples_to_ignore;
            uint16_t expected_sample_l = m_sample_value_expected - 1;
            uint16_t expected_sample_r = m_sample_value_expected + 1;
            ++m_sample_value_expected;
            if (actual_sample_l != expected_sample_l ||
                actual_sample_r != expected_sample_r)
                NRF_LOG_INFO("%3u: %04x/%04x, expected: %04x/%04x (i: %u)",
                    m_blocks_transferred, actual_sample_l, actual_sample_r,
                    expected_sample_l, expected_sample_r, i);
                return false;
    NRF_LOG_INFO("%3u: OK", m_blocks_transferred);
    return true;
static void check_rx_data(uint32_t const * p_block)
    ++m_blocks_transferred;
    if (!m_error_encountered)
        m_error_encountered = !check_samples(p_block);
    if (m_error_encountered)
        bsp_board_led_off(LED_OK);
        bsp_board_led_invert(LED_ERROR);
        bsp_board_led_off(LED_ERROR);
        bsp_board_led_invert(LED_OK);
static void data_handler(nrf_drv_i2s_buffers_t const * p_released,
                         uint32_t                      status)
    // 'nrf_drv_i2s_next_buffers_set' is called directly from the handler
    // each time next buffers are requested, so data corruption is not
    // expected.
    ASSERT(p_released);
    // When the handler is called after the transfer has been stopped
    // (no next buffers are needed, only the used buffers are to be
    // released), there is nothing to do.
    if (!(status & NRFX_I2S_STATUS_NEXT_BUFFERS_NEEDED))
        return;
    // First call of this handler occurs right after the transfer is started.
    // No data has been transferred yet at this point, so there is nothing to
    // check. Only the buffers for the next part of the transfer should be
    // provided.
    if (!p_released->p_rx_buffer)
        nrf_drv_i2s_buffers_t const next_buffers = {
            .p_rx_buffer = m_buffer_rx[1],
            .p_tx_buffer = m_buffer_tx[1],
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(&next_buffers));
        mp_block_to_fill = m_buffer_tx[1];
        mp_block_to_check = p_released->p_rx_buffer;
        // The driver has just finished accessing the buffers pointed by
        // 'p_released'. They can be used for the next part of the transfer
        // that will be scheduled now.
        APP_ERROR_CHECK(nrf_drv_i2s_next_buffers_set(p_released));
        // The pointer needs to be typecasted here, so that it is possible to
        // modify the content it is pointing to (it is marked in the structure
        // as pointing to constant data because the driver is not supposed to
        // modify the provided data).
        mp_block_to_fill = (uint32_t *)p_released->p_tx_buffer;
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info)
    bsp_board_leds_on();
    app_error_save_and_stop(id, pc, info);
    uint32_t err_code = NRF_SUCCESS;
    err_code = NRF_LOG_INIT(NULL);
    NRF_LOG_INFO("I2S loopback example started.");
    nrf_drv_i2s_config_t config = NRF_DRV_I2S_DEFAULT_CONFIG;
    // In Master mode the MCK frequency and the MCK/LRCK ratio should be
    // set properly in order to achieve desired audio sample rate (which
    // is equivalent to the LRCK frequency).
    // For the following settings we'll get the LRCK frequency equal to
    // 15873 Hz (the closest one to 16 kHz that is possible to achieve).
    config.sdin_pin  = I2S_SDIN_PIN;
    config.sdout_pin = I2S_SDOUT_PIN;
    config.mck_setup = NRF_I2S_MCK_32MDIV21;
    config.ratio     = NRF_I2S_RATIO_96X;
    config.channels  = NRF_I2S_CHANNELS_STEREO;
    err_code = nrf_drv_i2s_init(&config, data_handler);
    for (;;)
        prepare_tx_data(m_buffer_tx[0]);
        nrf_drv_i2s_buffers_t const initial_buffers = {
            .p_tx_buffer = m_buffer_tx[0],
            .p_rx_buffer = m_buffer_rx[0],
        err_code = nrf_drv_i2s_start(&initial_buffers, I2S_DATA_BLOCK_WORDS, 0);
        do {
            // Wait for an event.
            __WFE();
            // Clear the event register.
            __SEV();
            __WFE();
            if (mp_block_to_fill)
                prepare_tx_data(mp_block_to_fill);
            if (mp_block_to_check)
                check_rx_data(mp_block_to_check);
        } while (m_blocks_transferred < BLOCKS_TO_TRANSFER);
        nrf_drv_i2s_stop();
        NRF_LOG_FLUSH();
        bsp_board_leds_off();
        nrf_delay_ms(PAUSE_TIME);
i am trying to store the audio streaming data to the qspi i am using inmp441 mic module but confused with the word select pin?
