MCU Boot for secondary slot, fw_validation_info magic
I'm using a combination of B0 and MCU Boot.
I want to build MCU Boot for secondary slot to try upgrading it.
I pass CONFIG_BUILD_S1_VARIANT=y to the build system and it produces the following .elf files in the build/mcuboot:
/build/mcuboot/zephyr/zephyr_prebuilt.elf
./build/mcuboot/zephyr/s1_image_prebuilt.elf
./build/mcuboot/zephyr/zephyr.elf
./build/mcuboot/zephyr/s1_image.elf
As I understand, the last file, s1_image.elf, is the image that should be written to the secondary slot. If I write it there, B0 sees it, but fails to verify: "Could not find valid firmware validation info". Note, I build mcuboot for slot 1 with version which is bigger than that of the mcuboot in slot 0, so B0 tries to boot it first.
Indeed, magic array in the fw_validation_info contains 0xFFFFFFFF instead of expected 0x281ee6de, 0x86518483, 0x00013502.
At what stage is this validation magic code written?
Is it done via validation_data.py?
What is the correct way to generate mcuboot image for slot 1?
Thanks
    Could you please list the files generated in the build\zephyr folder ?
    Do you have the .bin file ? I'm not sure why you use the .elf file here. Have you tried the merged.hex file ?
    Did you compile only the MCUBoot for slot1 or you built the application with the CONFIG_BUILD_S1_VARIANT=y ?
    Could you show how you test and verify the image ?
  • Hi Hung,
    My goal is to upgrade mcuboot, leaving B0 and app untouched. I'm following ideas from Adding Upgradeable Bootloader
    I build peripheral_hr_coded sample project using this command line:
    west build -b nrf5340dk_nrf5340_cpuapp -- -DCONFIG_BUILD_S1_VARIANT=y
    Then I program the board using
    west flash --erase
    At this stage I see on the terminal that B0 bootloade boots code from slot 0:
    Attempting to boot slot 0.
    Attempting to boot from address 0xc200.
    Verifying signature against key 0.
    Hash: 0xd3...cd
    Firmware signature verified.
    Firmware version 3
    So far everything is as expected. Note that Firmware version is 3. Next I change the mcuboot version number by setting CONFIG_FW_INFO_FIRMWARE_VERSION=4 and rebuild using west build as before.
    At this stage I expect to find .hex/.bin/.elf of an mcuboot which I could load into slot 1. After doing so, slot 0 would contain version 3 and slot 1 would contain verison 4 of the mcuboot. The B0 should pick mcuboot verison 4 from slot 1.
    I'm guessing here, but file named "build/mcuboot/zephyr/s1_image.elf" looks like the mcuboot built for slot1. I load it on the board with
    nrfjprog --program ./build/mcuboot/zephyr/s1_image.elf --sectorerase
    B0 bootloader sees this image and since it has higher version numer, it tries to verify it first. Fails with "Could not find valid firmware validation info". Looks like some build step is missing. But which one?
    There are too many files in the build ... but here are .bin/.hex/.elf that I have there
    > find build/ -type f -name "*bin"
    build/mcuboot/zephyr/zephyr.bin
    build/mcuboot/zephyr/s1_isrList.bin
    build/mcuboot/zephyr/isrList.bin
    build/b0/zephyr/zephyr.bin
    build/b0/zephyr/isrList.bin
    build/hci_rpmsg/b0n/zephyr/zephyr.bin
    build/hci_rpmsg/b0n/zephyr/isrList.bin
    build/hci_rpmsg/zephyr/zephyr.bin
    build/hci_rpmsg/zephyr/signed_by_b0_app.bin
    build/hci_rpmsg/zephyr/isrList.bin
    build/zephyr/app_update.bin
    build/zephyr/signed_by_b0_s0_image.bin
    build/zephyr/zephyr.bin
    build/zephyr/app_to_sign.bin
    build/zephyr/signed_by_mcuboot_and_b0_s1_image_update.bin
    build/zephyr/signed_by_mcuboot_and_b0_s1_image_to_sign.bin
    build/zephyr/signed_by_mcuboot_and_b0_s0_image_update.bin
    build/zephyr/net_core_app_to_sign.bin
    build/zephyr/net_core_app_update.bin
    build/zephyr/signed_by_b0_s1_image.bin
    build/zephyr/signed_by_mcuboot_and_b0_s0_image_to_sign.bin
    build/zephyr/isrList.bin
    >find build/ -type f -name "*hex"
    build/mcuboot/zephyr/zephyr.hex
    build/b0/zephyr/zephyr.hex
    build/hci_rpmsg/b0n/zephyr/zephyr.hex
    build/hci_rpmsg/zephyr/zephyr.hex
    build/hci_rpmsg/zephyr/b0n_container.hex
    build/hci_rpmsg/zephyr/merged_CPUNET.hex
    build/hci_rpmsg/zephyr/signed_by_b0_app.hex
    build/hci_rpmsg/zephyr/app.hex
    build/hci_rpmsg/zephyr/provision.hex
    build/zephyr/merged_domains.hex
    build/zephyr/s0_image.hex
    build/zephyr/GENERATED_CP_APPLICATION_merged_domains.hex
    build/zephyr/spm_app.hex
    build/zephyr/zephyr.hex
    build/zephyr/signed_by_mcuboot_and_b0_s0_image_signed.hex
    build/zephyr/b0_container.hex
    build/zephyr/merged.hex
    build/zephyr/app_moved_test_update.hex
    build/zephyr/signed_by_mcuboot_and_b0_s0_image_test_update.hex
    build/zephyr/net_core_app_test_update.hex
    build/zephyr/app_signed.hex
    build/zephyr/signed_by_mcuboot_and_b0_s1_image_signed.hex
    build/zephyr/mcuboot_primary.hex
    build/zephyr/GENERATED_CP_NETWORK_merged_domains.hex
    build/zephyr/net_core_app_moved_test_update.hex
    build/zephyr/net_core_app_signed.hex
    build/zephyr/signed_by_mcuboot_and_b0_s1_image_test_update.hex
    build/zephyr/s1.hex
    build/zephyr/signed_by_b0_s1_image.hex
    build/zephyr/s0.hex
    build/zephyr/signed_by_b0_s0_image.hex
    build/zephyr/signed_by_mcuboot_and_b0_s1_image_moved_test_update.hex
    build/zephyr/signed_by_mcuboot_and_b0_s0_image_moved_test_update.hex
    build/zephyr/mcuboot_primary_app.hex
    build/zephyr/app_test_update.hex
    build/zephyr/s1_image.hex
    build/zephyr/provision.hex
    > find build/ -type f -name "*elf"
    build/b0/zephyr/zephyr_prebuilt.elf
    build/b0/zephyr/zephyr.elf
    build/hci_rpmsg/b0n/zephyr/zephyr_prebuilt.elf
    build/hci_rpmsg/b0n/zephyr/zephyr.elf
    build/hci_rpmsg/zephyr/zephyr_prebuilt.elf
    build/hci_rpmsg/zephyr/zephyr.elf
    build/zephyr/zephyr_prebuilt.elf
    build/zephyr/zephyr.elf
    Thanks for your help.
  • Hi Rtscts,
    I assume you have used CONFIG_SECURE_BOOT=y, CONFIG_BOOTLOADER_MCUBOOT=y in your prj.conf ?
    I think what caused the issue here is that you haven't specify which private key to be used for b0 to sign the MCUBoot. When you don't specific the key(s) it will generate new key pair and this explain why b0 can't verify the image
    I tested here with a key that I generated using
    python3 bootlooader/mcuboot/scripts/imgtool.py keygen -t ecdsa-p256 -k mykey.pem
    And then add this into my prj.conf:
    CONFIG_SB_SIGNING_KEY_FILE="D:\\mykey.pem"
    After that I can build, flash merged.hex (show version 1) and then change the version, build again and flash the signed_by_b0_s1_image.hex file and then it can be verified and I have Firmware version 2:
