sample net_sockets_can does not start correctly
Hi I try to build the sample
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/1.7.1/zephyr/samples/net/sockets/can/README.html
but i get this this error.
*** Booting Zephyr OS build v2.6.99-ncs1-1 ***
Flash regions Domain Permissions
00 01 0x00000 0x10000 Secure rwxl
02 31 0x10000 0x100000 Non-Secure rwxl
Non-secure callable region 0 placed in flash region 1 with size 32.
SRAM region Domain Permissions
00 07 0x00000 0x10000 Secure rwxl
08 31 0x10000 0x40000 Non-Secure rwxl
Peripheral Domain Status
00 NRF_P0 Non-Secure OK
01 NRF_CLOCK Non-Secure OK
02 NRF_RTC0 Non-Secure OK
03 NRF_RTC1 Non-Secure OK
04 NRF_NVMC Non-Secure OK
05 NRF_UARTE1 Non-Secure OK
06 NRF_UARTE2 Secure SKIP
07 NRF_TWIM2 Non-Secure OK
08 NRF_SPIM3 Non-Secure OK
09 NRF_TIMER0 Non-Secure OK
10 NRF_TIMER1 Non-Secure OK
11 NRF_TIMER2 Non-Secure OK
12 NRF_SAADC Non-Secure OK
13 NRF_PWM0 Non-Secure OK
14 NRF_PWM1 Non-Secure OK
15 NRF_PWM2 Non-Secure OK
16 NRF_PWM3 Non-Secure OK
17 NRF_WDT Non-Secure OK
18 NRF_IPC Non-Secure OK
19 NRF_VMC Non-Secure OK
20 NRF_FPU Non-Secure OK
21 NRF_EGU1 Non-Secure OK
22 NRF_EGU2 Non-Secure OK
23 NRF_DPPIC Non-Secure OK
24 NRF_REGULATORS Non-Secure OK
25 NRF_PDM Non-Secure OK
26 NRF_I2S Non-Secure OK
27 NRF_GPIOTE1 Non-Secure OK
SPM: NS image at 0x10000
SPM: NS MSP at 0x200182b8
SPM: NS reset vector at 0x17071
SPM: prepare to jump to Non-Secure image.
[00:00:00.201,782] <dbg> mcp2515_can.socket_can_init: Init socket CAN device 0x2 a680 (SOCKET_CAN_1) for dev 0x2a6b0 (CAN_1)
[00:00:00.217,376] <dbg> net_core.net_init: (main): Priority 90
[00:00:00.225,982] <dbg> net_core.l3_init: (main): Network L3 init done
[00:00:00.235,290] <dbg> mcp2515_can.socket_can_iface_init: Init CAN interface 0 x200149f8 dev 0x2a680
uart:~$ *** Booting Zephyr OS build v2.6.99-ncs1-1 ***
[00:00:00.252,014] <inf> net_socket_can_sample: sleeping for 2 seconds
[00:00:02.261,352] <err> net_socket_can_sample: Cannot create 1st CAN socket (-106)
[00:00:02.271,972] <err> net_socket_can_sample: Cannot start CAN application (-106)
uart:~$
  • Bellow you can see the two differnt settings for debug and the outputs i get.
    When copiling i get also a warning that i added in the bottom.
    (My final goal is to read data from CANBUS and send to AWS)
    CONFIG_CAN=y
    CONFIG_CAN_MAX_FILTER=5
    CONFIG_CAN_MCP2515=y
    CONFIG_ENTROPY_CC3XX=n
    CONFIG_SPI=y
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_SOCKETS_CAN=y
    CONFIG_NET_SOCKETS_POSIX_NAMES=y
    CONFIG_NET_IPV6=n
    CONFIG_NET_IPV4=n
    CONFIG_NET_MGMT=n
    CONFIG_NET_TCP=n
    CONFIG_NET_UDP=n
    CONFIG_NET_DEFAULT_IF_CANBUS_RAW=y
    CONFIG_NET_PKT_RX_COUNT=30
    CONFIG_NET_PKT_TX_COUNT=30
    CONFIG_NET_BUF_RX_COUNT=30
    CONFIG_NET_BUF_TX_COUNT=30
    #CONFIG_TEST_RANDOM_GENERATOR=y
    CONFIG_NET_SHELL=y
    CONFIG_LOG=y
    CONFIG_NET_LOG=y
    CONFIG_LOG_MODE_IMMEDIATE=y
    CONFIG_NET_SOCKETS_LOG_LEVEL_DBG=y
    CONFIG_CAN_LOG_LEVEL_DBG=y
    #CONFIG_NET_CONTEXT_LOG_LEVEL_DBG=y
    #CONFIG_NET_CORE_LOG_LEVEL_DBG=y
    #CONFIG_NET_CONN_LOG_LEVEL_DBG=y
    # Use smaller buffers for net_buf as CANBUS packets are quite small.
    CONFIG_NET_BUF_DATA_SIZE=64
    CONFIG_NET_BUF_USER_DATA_SIZE=0
    CONFIG_CAN=y
    CONFIG_SPI=y
    CONFIG_NETWORKING=y
    CONFIG_NET_IPV6=n
    CONFIG_NET_IPV4=n
    CONFIG_NET_MGMT=n
    CONFIG_NET_TCP=n
    CONFIG_NET_UDP=n
    CONFIG_NET_SHELL=y
    CONFIG_LOG=y
    CONFIG_NET_LOG=y
    [98/219] Building C object CMakeFiles/app.dir/src/main.c.obj
    c:\NordicApp\net_sockets_can\src\main.c:101:13: warning: 'rx' defined but not used [-Wunused-function]
    101 | static void rx(int *can_fd, int *do_close_period,
    [99/219] Linking C static library app\libapp.a
  • Hi
    Sorry for the slow response, I have been out in extended Christmas leave for the last month or so.
    Are you still having issues with this?
    If yes, have you made any new discoveries, or is the issue still the same as when you last posted?
    Best regards
    Torbjørn
  • Hi Torbjørn
    Then i have to say welcome back and i hope you had a nice time.
    I´m still in the same position as written in my last post.
  • Hi
    Are you able to share the full build log with me, after doing a pristine build?
    Best regards
    Torbjørn
  • > Executing task: nRF Connect: Generate config [email protected] for c:\NordicApp\net_sockets_can <
    Building net_sockets_can
    west build --build-dir c:\NordicApp\net_sockets_can\build c:\NordicApp\net_sockets_can --pristine --board [email protected] -- -DCMAKE_EXPORT_COMPILE_COMMANDS:BOOL=On -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DBOARD_ROOT:STRING="c:/NordicApp/net_sockets_can"
    Including boilerplate (Zephyr base): C:/NordicSemi/v1.8.0/zephyr/cmake/app/boilerplate.cmake
    -- Application: C:/NordicApp/net_sockets_can
    -- Zephyr version: 2.7.0 (C:/NordicSemi/v1.8.0/zephyr), build: v2.7.0-ncs1
    -- Found Python3: C:/NordicSemi/v1.8.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Found west (found suitable version "0.12.0", minimum required is "0.7.1")
    -- Board: nrf9160dk_nrf9160_ns, Revision: 0.9.0 (Active: 0.7.0)
    -- Cache files will be written to: C:/NordicSemi/v1.8.0/zephyr/.cache
    -- Found dtc: C:/NordicSemi/v1.8.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (c:/NordicSemi/v1.8.0/toolchain/opt)
    -- Found BOARD.dts: C:/NordicSemi/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns.dts
    -- Found devicetree overlay: C:/NordicApp/net_sockets_can/nrf9160dk_nrf9160_ns.overlay
    -- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/zephyr/dts.cmake
    warning: Experimental symbol NET_SOCKETS_OFFLOAD is enabled.
    warning: Experimental symbol NET_SOCKETS_CAN is enabled.
    Parsing C:/NordicSemi/v1.8.0/zephyr/Kconfig
    Loaded configuration 'C:/NordicSemi/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_ns_defconfig'
    Merged configuration 'C:/NordicApp/net_sockets_can/prj.conf'
    Merged configuration 'C:/NordicApp/net_sockets_can/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/NordicApp/net_sockets_can/build/zephyr/.config'
    Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 9.2.1
    -- The CXX compiler identification is GNU 9.2.1
    -- Found assembler: C:/NordicSemi/v1.8.0/toolchain/opt/bin/arm-none-eabi-gcc.exe
    Changed board to secure nrf9160dk_nrf9160 (NOT NS)
    === child image spm -  begin ===
    -- Application: C:/NordicSemi/v1.8.0/nrf/samples/spm
    -- Board: nrf9160dk_nrf9160, Revision: 0.7.0
    -- Found toolchain: gnuarmemb (C:/NordicSemi/v1.8.0/toolchain/opt)
    -- Found BOARD.dts: C:/NordicSemi/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160.dts
    -- Found devicetree overlay: C:/NordicSemi/v1.8.0/nrf/samples/spm/nrf9160dk_nrf9160.overlay
    -- Generated zephyr.dts: C:/NordicApp/net_sockets_can/build/spm/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/device_extern.h
    -- Including generated dts.cmake file: C:/NordicApp/net_sockets_can/build/spm/zephyr/dts.cmake
    Loaded configuration 'C:/NordicSemi/v1.8.0/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160_defconfig'
    Merged configuration 'C:/NordicSemi/v1.8.0/nrf/samples/spm/prj.conf'
    Merged configuration 'C:/NordicSemi/v1.8.0/nrf/samples/spm/boards/nrf9160dk_nrf9160.conf'
    Merged configuration 'C:/NordicSemi/v1.8.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/NordicApp/net_sockets_can/build/spm/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/.config'
    Kconfig header saved to 'C:/NordicApp/net_sockets_can/build/spm/zephyr/include/generated/autoconf.h'
    CMake Warning at C:\NordicSemi\v1.8.0\zephyr\CMakeLists.txt:1662 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NordicApp/net_sockets_can/build/spm
    === child image spm -  end ===
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    -- Configuring done
    -- Generating done
    [1/226] Creating directories for 'spm_subimage'
    [2/226] No download step for 'spm_subimage'
    [3/226] No update step for 'spm_subimage'
    [4/226] No patch step for 'spm_subimage'
    [5/226] No configure step for 'spm_subimage'
    [5/226] Performing build step for 'spm_subimage'
    [1/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/des.c.obj
    [2/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/debug.c.obj
    [3/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/arc4.c.obj
    [4/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/aria.c.obj
    [5/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/aesni.c.obj
    [6/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/cipher_wrap.c.obj
    [7/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/ctr_drbg.c.obj
    [8/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/blowfish.c.obj
    [9/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/cipher.c.obj
    [10/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/base64.c.obj
    [11/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/camellia.c.obj
    [12/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/error.c.obj
    [13/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/asn1write.c.obj
    [14/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/asn1parse.c.obj
    [15/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/entropy_poll.c.obj
    [16/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/havege.c.obj
    [17/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/gcm.c.obj
    [18/218] Generating objects/cc3xx.mon
    [19/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/md4.c.obj
    [20/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/entropy.c.obj
    [21/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/hmac_drbg.c.obj
    [22/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/hkdf.c.obj
    [23/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/md2.c.obj
    [24/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/nist_kw.c.obj
    [25/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/md5.c.obj
    [26/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/md.c.obj
    [27/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/padlock.c.obj
    [28/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pk.c.obj
    [29/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pk_wrap.c.obj
    [30/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pkparse.c.obj
    [31/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/bignum.c.obj
    [32/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pkcs12.c.obj
    [33/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/oid.c.obj
    [34/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/ripemd160.c.obj
    [35/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/platform_util.c.obj
    [36/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/timing.c.obj
    [37/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pkwrite.c.obj
    [38/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/pkcs5.c.obj
    [39/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/version_features.c.obj
    [40/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/platform.c.obj
    [41/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/xtea.c.obj
    [42/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/version.c.obj
    [43/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_slot_management.c.obj
    [44/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto.c.obj
    [45/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_client.c.obj
    [46/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_rsa.c.obj
    [47/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_ecp.c.obj
    [48/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_storage.c.obj
    [49/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/replacements/pem.c.obj
    [50/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/CMakeFiles/mbedcrypto_base_vanilla.dir/C_/NordicSemi/v1.8.0/mbedtls/library/psa_crypto_driver_wrappers.c.obj
    [51/218] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
    [52/218] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/mbedtls/shared/CMakeFiles/mbedcrypto_shared.dir/C_/NordicSemi/v1.8.0/mbedtls/library/sha512.c.obj
    [53/218] Generating include/generated/driver-validation.h
    [54/218] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
    [55/218] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [56/218] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto.a
    [57/218] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [58/218] Generating include/generated/offsets.h
    [59/218] Generating linker_zephyr_prebuilt.cmd
    [60/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [61/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [62/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [63/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [64/218] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [65/218] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [66/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [67/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [68/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [69/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [70/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [71/218] Linking C static library zephyr\arch\common\libisr_tables.a
    [72/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [73/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [74/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [75/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [76/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [77/218] Linking C static library zephyr\arch\common\libarch__common.a
    [78/218] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [79/218] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [80/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [81/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [82/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [83/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [84/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [85/218] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [86/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [87/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/tz/CMakeFiles/arch__arm__core__aarch32__cortex_m__tz.dir/arm_core_tz.c.obj
    [88/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [89/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [90/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [91/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [92/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [93/218] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [94/218] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\tz\libarch__arm__core__aarch32__cortex_m__tz.a
    [95/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [96/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [97/218] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [98/218] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [99/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [100/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [101/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [102/218] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [103/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [104/218] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [105/218] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [106/218] Building C object CMakeFiles/app.dir/src/main.c.obj
    [107/218] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [108/218] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [109/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [110/218] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [111/218] Linking C static library app\libapp.a
    [112/218] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [113/218] Building C object zephyr/boards/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
    [114/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [115/218] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [116/218] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [117/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [118/218] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [119/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [120/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [121/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [122/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [123/218] Linking C static library zephyr\boards\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [124/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [125/218] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [126/218] Linking C static library zephyr\lib\posix\liblib__posix.a
    [127/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [128/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [129/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [130/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [131/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [132/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [133/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [134/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [135/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [136/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [137/218] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [138/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [139/218] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [140/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [141/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [142/218] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [143/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [144/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [145/218] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [146/218] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
    [147/218] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [148/218] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [149/218] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
    [150/218] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
    [151/218] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [152/218] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
    [153/218] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
    [154/218] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
    [155/218] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [156/218] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [157/218] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrf/subsys/spm/spm.c.obj
    [158/218] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrf/subsys/spm/secure_services.c.obj
    [159/218] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
    [160/218] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [161/218] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [162/218] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.8.0/nrf/drivers/entropy/entropy_cc310.c.obj
    [163/218] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [164/218] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [165/218] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [166/218] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [167/218] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [168/218] Linking C static library zephyr\libzephyr.a
    [169/218] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [170/218] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [171/218] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [172/218] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [173/218] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [174/218] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [175/218] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [176/218] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [177/218] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [178/218] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
    [179/218] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [180/218] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [181/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [182/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [183/218] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [184/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [185/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [186/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [187/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [188/218] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_uarte.c.obj
    [189/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [190/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [191/218] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [192/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [193/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [194/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [195/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [196/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [197/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [198/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [199/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [200/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [201/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [202/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [203/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [204/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [205/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [206/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [207/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [208/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [209/218] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [210/218] Linking C static library zephyr\kernel\libkernel.a
    [211/218] Linking C executable zephyr\zephyr_prebuilt.elf
    [212/218] Generating linker.cmd
    [213/218] Generating isr_tables.c, isrList.bin
    [214/218] Generating dev_handles.c
    [215/218] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [216/218] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [217/218] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [218/218] Linking C executable zephyr\zephyr.elf
               FLASH:         64 KB        64 KB    100.00%
                SRAM:       11832 B        64 KB     18.05%
            IDT_LIST:          0 GB         2 KB      0.00%
    [9/226] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
    [11/226] No install step for 'spm_subimage'
    [12/226] Completed 'spm_subimage'
    [13/226] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [14/226] Generating include/generated/offsets.h
    [15/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_log_backend.c.obj
    [16/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm_ctrl.c.obj
    [17/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_wildcard.c.obj
    [18/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
    [19/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_history.c.obj
    [20/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/power.c.obj
    [21/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [22/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
    [23/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
    [24/226] Generating linker_zephyr_prebuilt.cmd
    [25/226] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [26/226] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [27/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [28/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [29/226] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrf/subsys/nonsecure/secure_services_ns.c.obj
    [30/226] Building C object zephyr/CMakeFiles/zephyr.dir/C_/NordicSemi/v1.8.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [31/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [32/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy/policy_residency.c.obj
    [33/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [34/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [35/226] Linking C static library zephyr\arch\common\libisr_tables.a
    [36/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [37/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [38/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [39/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
    [40/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [41/226] Linking C static library zephyr\arch\common\libarch__common.a
    [42/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [43/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [44/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [45/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [46/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [47/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [48/226] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [49/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [50/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [51/226] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [52/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [53/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [54/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [55/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [56/226] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [57/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [58/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [59/226] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [60/226] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [61/226] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [62/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [63/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [64/226] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [65/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [66/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [67/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [68/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [69/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [70/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [71/226] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [72/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [73/226] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [74/226] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [75/226] Building C object zephyr/CMakeFiles/zephyr_prebuilt.dir/misc/empty_file.c.obj
    [76/226] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [77/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [78/226] Building C object zephyr/boards/arm/nrf9160dk_nrf9160/CMakeFiles/boards__arm__nrf9160dk_nrf9160.dir/nrf52840_reset.c.obj
    [79/226] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [80/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [81/226] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
    [82/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [83/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [84/226] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
    [85/226] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [86/226] Linking C static library zephyr\boards\arm\nrf9160dk_nrf9160\libboards__arm__nrf9160dk_nrf9160.a
    [87/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [88/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [89/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [90/226] Linking C static library zephyr\lib\posix\liblib__posix.a
    [91/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [92/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [93/226] Building C object CMakeFiles/app.dir/src/main.c.obj
    [94/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [95/226] Linking C static library app\libapp.a
    [96/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [97/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [98/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [99/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [100/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [101/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [102/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [103/226] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [104/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [105/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [106/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/util/fnmatch/fnmatch.c.obj
    [107/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [108/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [109/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [110/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/ring_buffer.c.obj
    [111/226] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [112/226] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [113/226] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [114/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_list.c.obj
    [115/226] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [116/226] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [117/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
    [118/226] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [119/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [120/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [121/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [122/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/devmem_service.c.obj
    [123/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/kernel_service.c.obj
    [124/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cmds.c.obj
    [125/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/modules/device_service.c.obj
    [126/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [127/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_fprintf.c.obj
    [128/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_ops.c.obj
    [129/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_utils.c.obj
    [130/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_cmds.c.obj
    [131/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_uart.c.obj
    [132/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell.c.obj
    [133/226] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/shell/shell_help.c.obj
    [134/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [135/226] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [136/226] Building C object zephyr/subsys/net/l2/canbus/CMakeFiles/subsys__net__l2__canbus.dir/canbus_raw.c.obj
    [137/226] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [138/226] Linking C static library zephyr\subsys\net\l2\canbus\libsubsys__net__l2__canbus.a
    [139/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [140/226] Linking C static library zephyr\libzephyr.a
    [141/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/canbus_socket.c.obj
    [142/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [143/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [144/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_pkt.c.obj
    [145/226] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [146/226] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [147/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_context.c.obj
    [148/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_shell.c.obj
    [149/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_tc.c.obj
    [150/226] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [151/226] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [152/226] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [153/226] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [154/226] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [155/226] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [156/226] Building C object zephyr/drivers/can/CMakeFiles/drivers__can.dir/can_common.c.obj
    [157/226] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/NordicSemi/v1.8.0/nrf/drivers/entropy/entropy_cc310.c.obj
    [158/226] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/connection.c.obj
    [159/226] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
    [160/226] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [161/226] Building C object zephyr/drivers/can/CMakeFiles/drivers__can.dir/can_shell.c.obj
    [162/226] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [163/226] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [164/226] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [165/226] Linking C static library zephyr\subsys\net\ip\libsubsys__net__ip.a
    [166/226] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/errno_sanity.c.obj
    [167/226] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [168/226] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/shmem_sanity.c.obj
    [169/226] Building C object zephyr/drivers/can/CMakeFiles/drivers__can.dir/can_mcp2515.c.obj
    [170/226] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [171/226] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [172/226] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [173/226] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [174/226] Linking C static library zephyr\drivers\can\libdrivers__can.a
    [175/226] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [176/226] Building C object modules/nrf/subsys/fw_info/CMakeFiles/..__nrf__subsys__fw_info.dir/fw_info.c.obj
    [177/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [178/226] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf91_sockets.c.obj
    [179/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [180/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [181/226] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [182/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [183/226] Linking C static library modules\nrf\subsys\fw_info\lib..__nrf__subsys__fw_info.a
    [184/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [185/226] Linking C static library modules\nrf\lib\nrf_modem_lib\lib..__nrf__lib__nrf_modem_lib.a
    [186/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [187/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [188/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [189/226] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/NordicSemi/v1.8.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [190/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [191/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [192/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [193/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [194/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [195/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [196/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [197/226] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [198/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [199/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [200/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [201/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [202/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [203/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [204/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [205/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [206/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/pipes.c.obj
    [207/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [208/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [209/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [210/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [211/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [212/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [213/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [214/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [215/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [216/226] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [217/226] Linking C static library zephyr\kernel\libkernel.a
    [218/226] Linking C executable zephyr\zephyr_prebuilt.elf
    [219/226] Generating linker.cmd
    [220/226] Generating isr_tables.c, isrList.bin
    [221/226] Generating dev_handles.c
    [222/226] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [223/226] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [224/226] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [225/226] Linking C executable zephyr\zephyr.elf
               FLASH:      128768 B       960 KB     13.10%
                SRAM:       27872 B     178968 B     15.57%
    [226/226] Generating zephyr/merged.hex
    Terminal will be reused by tasks, press any key to close it.
