nrf9160 I2C Master Mode Callbacks
Hello everyone,
I am trying to implement the OPTIGA Trust M from Infineon with the nrf9160. Unfortunately I encountered some problems regarding this topic.
I am trying to communicate with the Optiga Chip via I2C in Master Mode and I am trying to use the Optiga library acquired here: Library.
So far I successfully got the device binding for the I2C_1 with the following configurations:
prj.conf :
# Enable I2C/TWI
CONFIG_I2C=y
CONFIG_I2C_1=y
 i2c-init:
optiga_pal_i2c_context_0.p_i2c_hw_config = device_get_binding("I2C_1");
  optiga_pal_i2c_context_0.slave_address = 0x30;
  if (optiga_pal_i2c_context_0.p_i2c_hw_config == NULL)
    printk("\nERROR: I2C device binding \n");
    return;
  ret = i2c_configure(optiga_pal_i2c_context_0.p_i2c_hw_config, (I2C_SPEED_FAST<<1) | I2C_MODE_MASTER);
  if(ret != PAL_I2C_EVENT_SUCCESS)
    printk("\nERROR: I2C Master and Speed set failed.\n");
    return;
So far this seams to be working. Unfortunately the Optiga library needs certain callbacks, which are end_of_transmit and end_of_receive.
The drivers/i2c.h library only lists such callbacks for slave configuration, but not for the Master configuration.
So my question is if there are such callbacks for the I2C Master mode.
Andreas
