The Bluetooth Core specification states that:
Direct Test Mode shall be set up using one of two alternate methods: 1. over HCI (as defined in Section 2) or 2. through a 2-wire UART interface (as defined in Section 3) Each DUT shall implement one of the two Direct Test Mode methods in order to test the Low Energy PHY layer.
Per Bluetooth Core Specification Version 5.2 | Vol 6, Part F, Section 1.
The nRF5 SDK, v17.1.0, DTM Example states the following:
main.c may be replaced with other interface implementations, such as an HCI interface, USB, or another interface required by the Upper Tester.
According to the Bluetooth Core Spec, USB (or some other interface) may not be used, correct? At least, this is how I understand the Core Spec quote above.
The are also some previous threads that discuss alternative interfaces, here on the DevZone, such as in this thread. I also found a related issue with Nordic's Direct Test Mode application.
In the end, is it up to the test house to sign off on the interface of choice, ignoring / bypassing Bluetooth Core specs?
