Current state of supporting Apple M1
As mentioned here I installed the Intel versions:
But flashing the sample is not possible due to this error:
-- west flash: using runner nrfjprog
-- runners.nrfjprog: mass erase requested
-- runners.nrfjprog: Flashing file: /opt/nordic/ncs/v1.6.1/zephyr/samples/basic/blinky/build/zephyr/zephyr.hex
ERROR: Unable to connect to a debugger.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /opt/nordic/ncs/v1.6.1/zephyr/samples/basic/blinky/build/zephyr/zephyr.hex --chiperase -f NRF52 --snr 685260830
The terminal process terminated with exit code: 33.
  "platform": {
    "os": "darwin",
    "osVersion": "Darwin Kernel Version 21.1.0: Wed Oct 13 17:33:01 PDT 2021; root:xnu-8019.41.5~1/RELEASE_ARM64_T6000",
    "osKernel": "21.1.0",
    "vscode": "1.63.0",
    "electron": "13.5.2",
    "node": "v14.16.0"
  "system": {
    "date": "2021-12-14T11:21:43.740Z",
    "vscodeRoot": "/Applications/Visual Studio Code.app/Contents/Resources/app",
    "vscodeUptime": "00:00:13",
    "osUptime": "458:27:55",
    "cpu": {
      "model": "Apple M1 Pro",
      "speed": "24 MHz",
      "count": 5
    "memory": {
      "total": "32.00 GB",
      "free": "0.03 GB"
  "workspace": {
    "name": "blinky",
    "workspaceFile": null,
    "folders": [
      "/opt/nordic/ncs/v1.6.1/zephyr/samples/basic/blinky"
  "extensions": {
    "internal": {
        "version": "2021.11.221",
        "path": "/Users/stuermer/.vscode/extensions/nordic-semiconductor.nrf-connect-2021.11.221",
        "isActive": true
      "nordic-semiconductor.nrf-terminal": null,
      "nordic-semiconductor.devicetree": null,
      "nordic-semiconductor.kconfig": null
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.7.1",
      "ms-vscode.js-debug": "1.62.0",
      "ms-vscode.js-debug-companion": "1.0.15",
      "ms-vscode.references-view": "0.0.81",
      "ms-vscode.vscode-js-profile-table": "0.0.18",
      "hancel.serialport-helper": "0.0.13"
  "tools": {
    "/Applications/SEGGER/JLink/JLinkExe": "7.58e",
    "/usr/local/bin/nrfjprog": "10.15.1",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/cmake": "3.21.1",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/west": "0.11.0",
    "/usr/bin/python": "3.9.6",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/ninja": "1.10.2",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/gperf": "3.1",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/dtc": "1.6.1",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/arm-none-eabi-gcc": "9-2019-q4-major",
    "/opt/nordic/ncs/v1.6.1/toolchain/bin/gn": "1935"
  "connectedDevices": [],
  "config": {
      "topdir": "${nrf-connect.sdk:1.6.1}",
      "toolchain": {
        "path": "${nrf-connect.toolchain:1.6.1}"
      "ozonePath": "",
      "applications": [
        "${workspaceFolder}"
      "jlink": {
        "rtosPlugin": ""
      "kconfig": {
        "interface": null
      "welcome": {
        "showOnStartup": false
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "enableTelemetry": true
  "environment": {
    "westExe": "/opt/nordic/ncs/v1.6.1/toolchain/bin/west",
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "GIT_EXEC_PATH": "/opt/nordic/ncs/v1.6.1/toolchain/Cellar/git/2.32.0_1/libexec/git-core",
      "HOME": "/Users/stuermer",
      "PATH": "/opt/nordic/ncs/v1.6.1/toolchain/bin:......[REMOVED FOR PUBLIC]",
      "ZEPHYR_BASE": "/opt/nordic/ncs/v1.6.1/zephyr",
      "GNUARMEMB_TOOLCHAIN_PATH": "/opt/nordic/ncs/v1.6.1/toolchain",
      "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
      "USER": "stuermer"
    "toolchainPath": "/opt/nordic/ncs/v1.6.1/toolchain",
    "toolchainBinPath": "/opt/nordic/ncs/v1.6.1/toolchain/bin",
    "toolchainVersion": "1.6.1"
  "terminal": {
    "shell": null,
    "defaultProfile": null
  • Using the nRF-Command-Line-Tools 10.15.1 with J-Link V7.58b for M1 will result in the following error:
    ERROR: JLinkARM DLL load failed.
    Try again. If it keeps failing, please ERROR: reinstall latest JLinkARM from Segger webpage.
    But it enables flashing via an external command line using the nrfjprog command directly.
    You need to select the intel variant (x86 / x86_64) when installing the J-link drivers for nrfjprog to work when invoked through West. Please try this and let me know if you still get the same error.
    Vidar
