nRF5340 DK not detecting in Windows10
I am completely new with the development kit nRF5340, I have plugged in the USB and turn it ON, the status after that as follows,
- LED5 is blinking continuesly
- LED1, 2, 3, 4 are blinking one by one (in periodic order)
- Power Source in VDD
SW10 is set to OFF and SW6 is set to right
I have followed all the instruction based on the previous chat on tis topic, nRF5340 DK - Windows not detecting DK - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
but not yet solved.
I appreciate greatly for you help.
Thanks and Regards,
Sreejith
  • Sreejith Sundh said:
    Is this problem with my PC (I mean some required serial drivers)?
    Not that I know of. Having the command line tools should be enough. And you tried different PC's as well, so I would assume that the PC an be ruled out.
    I could not see any ids for serial numbers of all the debuggers connected to the computer.
    Could you elaborate a bit more on this?
    Elfving
  • I meant, I have tried with the command as you mentioned before to get those serial numbers of all the debuggers connected to the computer (nrfjprog -i), So it was an empty response, is that indicating nothing detected on my pc?
    Thanks
  • Yeah there doesn't seem to be detected any external programmers/debuggers. Where you expecting more than the DK? Do you have a lot of other boards connected to the computer?
    And speaking of that previous thread that you mentioned, did you also try the suggestions from this list?
    Elfving
  • Yes, I have tried all the procedures which mentioned in the list. No any other boards connected to this computer. The PC has two OS 1. Windows and 2. Ubuntu... sometime I have the issues with using Headphones and Video camera (Video not work with Windows and headphone not work with Ubuntu).
  • So when it comes to step 1, have you also tried turning it off and on with the switch a few times? Simply getting it to turn on by inserting the USB might make it easy to overlook that the Power switch might not be completely in the right position.
    When it comes to step 2, did you try a somewhat shorter cable as well? If the cables are too long, there also might be a problem.
    If you have installed NCS then you should have the correct drivers for the DK, but even without you should be able to open the DK as a flash drive.
    How did step 4 work out for you?
    Elfving
