No callbacks from pstorage
I'm following the official tutorial for using pstorage and this the simplest test code I've come up with:
static pstorage_handle_t base_handle;
static void test_pstorage_cb_handler(pstorage_handle_t * p_handle,
                                     uint8_t             op_code,
                                     uint32_t            result,
                                     uint8_t           * p_data,
                                     uint32_t            data_len)
void pstorage_test(void)
    uint32_t res;
    res = pstorage_init();
    APP_ERROR_CHECK(res);
    pstorage_module_param_t param;
    memset(&param, 0, sizeof(param));
    param.block_size  = 24;
    param.block_count = 10;
    param.cb          = test_pstorage_cb_handler;
    res = pstorage_register(&param, &base_handle);
    pstorage_handle_t block_handle;
    res = pstorage_block_identifier_get(&base_handle, fault_id, &block_handle);
    res = pstorage_clear(&block_handle, 24 * 10);
Despite all function call returning NRF_SUCCESS, I never get callbacks and pstorage_access_status_get() continuously returns 1.
What could I be doing wrong?
EDIT:
My main():
    timers_init();
    gpiote_init();
    ble_stack_init();
    bsp_module_init();
    scheduler_init();
    gap_params_init();
    advertising_init();
    services_init();
    conn_params_init();
    sec_params_init();
    pstorage_test();
    while (1) app_sched_execute();
